Plexamp on Mac: Stop after current album
I’m a newbie to Plexamp and loving it so far.
On my Mac, it appears to automatically choose something else to play when the current item ends. Is there a way to get it not to do that? Sometimes I’m playing an album as I go to sleep, or want time to think about what I just heard before something else starts…
this is a feature that was recently added to the new version
Settings -> Playback -> Autoplay
from this menu you can disable/enable and select how autoplay decisions are made if it is enabled
Or you can also swipe to get the left-most card, which is the Silence card :slight_smile:
Thanks!
Well, Settings -> Playback -> Autoplay looks like it’s working for albums.
If I’m just playing a track, though, whether I have the toggle on or off, it still says “Enabled / Silence is not golden.” and it continues on to the next track on the album. Should this work for a single track? Have I missed something?
And how would I swipe to a card on a Mac desktop without a touch screen?
single tracks are essentially the equivalent of an album, b/c we queue up the track around the album.
What does that mean?
if you play a track, the entire album is queued around the track which is playing, so that if you hit :previous_track_button: or :next_track_button: it moves around in the album.
So if I queue up a single track, I queue up the entire album? If I queue up one track, I only want the one track. How do I keep this from happening?
there’s no way at the moment. if you have a queue already there, you can add a single track to it.
Huh. So it this the right place to file a Plexamp feature request? If so, I think a switch like that for Autoplaying albums would be an obvious (and simple?) improvement.
i think in the future we’ll allow queuing a single track when there’s no play queue, so if you play it, it would add the entire album, but if you add to queue it would just add/play the single track.
Would also like the option to play a Station after an album, don’t always want to listen to the same artist.
swipe the card and you have your wish
I’m sorry, I don’t know what that means.
Figured it out, had no clue there was a swippy thing at the bottom of the play queue.
it’s idiomatic, now you’ll never forget!
