Plexamp Quick Skip disappeared
iPod touch 6th gen
IOS 12.5.4
Plexamp 3.7.0
Just updated yesterday and the buttons for Quick Skip have disappeared. All settings are correct, they just vanished. Probably lack of room in GUI? Hope you squish the bug soon I utilize them a lot.
Thanks for your hard work guys!
Scott
I’m guessing it has to due to width of screen. Assuming you do have it enabled in settings. Thanks for report
Yes, Disabled, reenabled. Either way no effect.
We’ve made a tweak for the next release which relaxes (a bit) the screen width requirements for those to show up. Sorry for the trouble.
