Plexamp Raspberry Pi 4.3 bug?
Context:
  • I tried to upgrade from 4.2 to 4.3 via odinb’s (awesome) script, this didn’t work for some reason.
  • I decided to do a fresh install. I got things working again but I’m puzzled and concerned with a couple of error messages, see below
Question: Is this an issue or will this be an issue? Can/should I address this?
pi@raspberrypi:~ $ systemctl --user enable plexamp.service && systemctl --user start plexamp.service
Created symlink /home/pi/.config/systemd/user/basic.target.wants/plexamp.service → /home/pi/.config/systemd/user/plexamp.service.
Failed to start plexamp.service: Unit network-online.target not found.
pi@raspberrypi:~ $ node /home/pi/plexamp/js/index.js
Starting Plexamp 4.3.0
DEVICE: No provider for source 13f113a4cb0031f535745b2c7ee8783fafcXXXXX
pi@raspberrypi:~ $ systemctl --user restart plexamp.service && systemctl --user status plexamp.service
Failed to restart plexamp.service: Unit network-online.target not found.
systemctl --user status plexamp.service does tell me that the service is active but also shows the same ‘DEVICE: no provider’ error…
● plexamp.service - Plexamp
Loaded: loaded (/home/pi/.config/systemd/user/plexamp.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2022-09-18 10:17:07 CEST; 1h 18min ago
Main PID: 640 (node)
Tasks: 39 (limit: 1830)
CPU: 7min 38.581s
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/plexamp.service
└─640 /usr/bin/node /home/pi/plexamp/js/index.js
Sep 18 10:17:07 raspberrypi systemd[601]: Started Plexamp.
Sep 18 10:17:10 raspberrypi node[640]: Starting Plexamp 4.3.0
Sep 18 10:17:10 raspberrypi node[640]: DEVICE: No provider for source 13f113a4cb0031f535745b2c7XXXXX>
you can generally ignore “DEVICE: No provider for source …” and other messages that appear after manually starting Plexamp
and regarding the network-online.target error, latest installer from @odinb1 addresses this with updates to the systemd service
Correct! Just re-run the installer, choose your user, cleanup for upgrade and run the upgrade. Should be fixed after that!
OK, many thanks!!
