Plexamp Raspberry Pi beta - sample matching not working? Or just a UI bug?
I posted this in the Future of Plexamp thread a little before it got (understandably) closed, so I’m posting it again in the hopes that I might be able to get a more definitive answer.
So I’m playing a file that is 192/24 for testing with Strict Sample Matching on and maximum quality settings. It isn’t stuttering or anything, so that’s good. However, I’m wondering if it’s playing at the full quality or not and I’m not sure how to tell.
On my laptop’s plexamp, which I am using to control it, I see this:
Capture
However, when I go to the settings on the Pi using the web browser, I see this:
Screenshot 2022-05-04 at 13-28-37 Plexamp
Is it converting the file for output or am I getting the full quality file?
I’ve tried changing the output and it always says the 44.1 kHz/2 channels thing regardless of which audio output I select.
I’m using one of the USB 3 slots, and the converter I have is supposed to support high bitrate stuff: https://www.amazon.com/dp/B07VSFBT82
Future of Plexamp on Raspberry Pi? - #236 by tpavey here suggests that it might just be a UI issue, as they can hear something change in their external DAC when the sample rate changes. They don’t say if they’re using USB though.
have observed the same when routing audio via USB and spdif thru a HAT … and I’ve seen this with plexamp on other non-pi platforms (mac) … in my case I’m sure sample rate switching is working as expected
Pretty sure it’s just a display issue, the UI doesn’t have visibility into output reconfiguration.
I’ve been building and using this to see the actual device parameters.
hw_params.c.zip (1.8 KB)
FWIW, my DAC that I have connected to the pi via USB displays the frequency and it is switching from track to track to the correct frequency for each file I’m playing.
aight, great to hear it. Thanks!
