Desktop is building for the beta channel now, and mobile is on its way to TestFlight and Play testing. The main one: the … menu opens again for those of you it had stopped opening for.
Added
The volume slider is easier to grab, and the volume popover’s is wider and sets the volume with a tap.
iOS: an unfolded iPhone Duo gets the side-by-side player and queue in landscape.
Mobile: Settings › Debugging can share offline diagnostics.
Fixed
Desktop: the … menu opens again.
Players on your network, like Caldera nodes, no longer drop out of the player list after the phone sits idle.
Mobile: a downloaded song shows its lyrics when you’re online.
Mobile: downloads skip old links to TIDAL tracks instead of stalling.
CarPlay: the app no longer freezes for a few seconds when playback changes.
macOS: seeking no longer tells Now Playing the track started over.
Linux: the back of a flipping poster no longer shows through its front, mirrored.
Desktop: remote control no longer gets stuck starting up.
It’s out on the desktop beta channel, TestFlight and Play testing. This one is mostly downloads: renames on the server reach them, offline artist pages look like they do online, and plays and ratings made offline find their way home.
Added
Sweet Fades has a Longest Fade setting, from 5 to 30 seconds.
Offline artist pages split albums into Singles & EPs, Live Albums, Soundtracks, Compilations, Demos and Remixes.
Desktop: the keyboard gets around Settings pages, and Back returns to where you came from.
Fixed
Downloads pick up artist, album, track and playlist renames made on the server.
A downloaded artist with many albums shows all of them offline, not only the first 30.
Offline artists and albums sort by their sort titles, and offline search finds a compilation’s tracks by their own artists.
Tracks added to a downloaded playlist download at the next refresh.
A download’s progress no longer counts past its total while it refreshes.
Plays and ratings made offline reach every server they belong to, not only the one you’re using.
A cover changed on the server shows on every track of that album in the queue.
CarPlay/Android Auto: offline artists list all their albums, and playing one plays its main albums.
iOS: no more stalling and closing when you leave the app and come back, or sticking on the splash screen.
Android: Share Offline Diagnostics and Share Logs no longer close the app with a lot downloaded.
Desktop: Home’s title keeps its library and server picker after the window changes size.
Desktop: swiping a row away keeps the red background attached to it.
Desktop: a full-screen cover that fills the window has square corners.
Desktop is on the beta channel now, and mobile is on its way to TestFlight and Play testing. A small one: downloads now ride out a brief network change.
Fixed
Mobile: a brief network change, like waking up or switching Wi-Fi, no longer cancels and restarts every download.
Desktop: upcoming tracks’ artwork is fetched ahead again.
Desktop is on the beta channel now, and mobile is on its way to TestFlight and Play testing. The main one: the iPhone Duo’s outer display gets a proper player layout.
Fixed
iOS: on the iPhone Duo, the player is centred on both displays, lyrics are no longer cut off, and landscape on the outer display fits every control.
Lyrics fade out at the top and bottom instead of showing a sliver of a cut-off line.
Lyrics show on the first try after reopening the app.
Mobile is on its way to TestFlight and Play testing, and desktop is on the beta channel. The main one: Signal Path, which used to work only when playing to a Caldera player, now works for music playing in Plexamp itself.
Added
Signal Path for music playing in Plexamp, not just on a Caldera player: tap the light by the codec details to see each step from file to speaker, and what keeps it from being lossless.
Fixed
After switching networks, screens load straight away and relayed servers connect sooner.
CarPlay/Android Auto: a new track’s artwork shows straight away, on the lock screen too.
iOS: an unfolded iPhone Duo no longer sometimes sticks on the logo at launch.
iOS: on the iPhone Duo’s outer display, the visualiser reaches both edges again.
Desktop: resizing a window no longer switches between Desktop and Compact; use the Window menu or the shortcuts.
