Plexamp suggestion: Sort albums by duration
Would be great to be able sort albums by total length–sometimes you want to play something to fit a certain time, or find something that’ll play for hours, or suchlike. Plexamp determines each album’s length, so the data must be in there somewhere to be used.
Just to clarify… do you want to filter albums by their total duration or actually set the order in which the entire library is sorted?
From experience, some users are applying both terms interchangeably, so I want to be sure we’re on the same page :innocent:
Thanks for the quick response! I meant actually set the order to sorting by duration, in the same way you can sort movies by length.
Seconded! I was going for a walk last night and knew it would take me around 35 minutes so I was looking for an album with running time less than 40…
