Plexamp & TLS issues behind reverse proxy (Traefik)
Hello there
I’m running a Plex server on Docker, behind a Traefik reverse proxy.
Traefik is doing the HTTPS / SSL termination, and forwards traffic to Plex (…:443 → plex:32400).
Because IT security is a part of my daily job, Traefik is configured to be enforce TLS 1.3 & secure ciphers.
Now Plex works flawlessly for years now, even with TLS 1.3 & those ciphers. All the browsers (Safari, Chrome, Chromium, Firefox), on different OS (Debian, Ubuntu, Kali, macOS, Windows, iOS, Android) can connect and play videos. I used openssl s_client to check the SSL connection. The connection looks good, the ciphers looking good, the SSL certificate looks good, and is valid. So, all fine.
However, today I thought I’ll give Plexamp a try. Have a guess :slight_smile: Plexamp fails in connecting the server. The server is behind a NAT, yes. However, the Plex server is also remotely available via custom hostname (behind named Traefik proxy). I tried to connect Plexamp to Plex via direct network connection, via NAT (loopback / hairpin), and from WAN.
Plexamp won’t connect to my Plex server. As mentioned before, all other clients & OS will work, it’s just Plexamp. I think I pinned it down to the TLS connection, which actually points more to a client (Plexamp) issue, rather than a server issue. The only thing I can think of now are:
  • Plexamp doesn’t properly support TLS 1.3 (which would be a bit of a shame & security issue in 2025)
  • Plexamp doesn’t support SNI and the proxy rejects because of strict SNI handling
  • Plexamp no longer uses HTTPS, or requests a different ALPN protocol
Is there anyone at Plex who can answer these questions? :slight_smile:
I can’t find anything useful in the logs, except for this:
May 09, 2025 00:53:51.196 [0x6daf3000] DEBUG - Networking: Completed request 41: (GET https://plex.example.net:443/) with code -35 (have 0 bytes) in 42 ms.
May 09, 2025 00:53:51.196 [Javascript] WARNING - DEVICE: Server connection https://plex.example.net:443 didn't work for example.net: HTTP status -35
Please note, example.net was redacted.
What does HTTP status -35 mean. Since -35 isn’t a valid HTTP status, I think this is coming from the layer underneath (networking). Does Plexamp leverage libcurl, and is this a libcurl error? In case it is libcurl or something similar, -35 can point to an SSL handshake error. Can I enable debugging for the networking module?
Btw. openssl s_client -connect, as well as curl works flawlessly:
curl -I https://plex.example.net/web/index.html
HTTP/2 200
accept-ranges: bytes
cache-control: no-cache
content-type: text/html
date: Thu, 08 May 2025 23:35:33 GMT
x-plex-protocol: 1.0
content-length: 30234
Anyone there who can help me out debug this properly?
I tried Plexamp on macOS and iOS. Both from LAN, NAT hairpin & via WAN. No success on both platforms.
The issue is that Plexamp currently uses libcurl with Apple’s Secure Transport enabled, and that does not support TLS v1.3.
We will update it at some point to use OpenSSL instead.
Damn Apple, huh? : )
Thanks for the fast, short and pretty accurate reply!
You sir, are a genius :slight_smile:
I renamed the forum thread, so that other people using Traefik, or any other reverse proxy with strong TLS ciphers / versions can find it.
For those using Traefik, I’ll leave this here: Downgrading to TLS 1.2 solved the issue for me. I had to update the dynamic Traefik config with the following mTLS option:
tls:
  options:
    default: &defaultOptions
      minVersion: VersionTLS13
      sniStrict : true
      curvePreferences:
        - X25519
        - CurveP256
        - CurveP384
    minTLS12:
      <<: *defaultOptions
      minVersion: VersionTLS12
Please note the &defaultOptions is a YAML anchor, because I didn’t want to specify the whole config for TLS 1.2 again. You can override the default to minVersion: VersionTLS12, but that will affect all services. Thus, I’ve created a new TLS option called minTLS12, which then is referred by the service / container via label:
traefik.http.routers.plex.tls.options: "minTLS12@file"
Hope that helps somebody :slight_smile: Thanks @elan for the support.
