Plexamp - unable to login on iPhone
I have checked all other topics, but nowhere found the issue I am having. I got Plex Premium to stream music to my iPhone. I have logged in the Plex app where everything is working fine, but when I downloaded Plexamp I cannot log in using the “Sign in with browser” button. This is the method I am always using - in the browser on PC I have successfully logged in Plex and also Plexamp on Android device worked fine but Plexamp on iPhone is not letting me log in. When I click on the sign-in browser button, the app closes. Nothing else happens. I have tried to reinstall the app several times, even along with the Plex app.
Does anyone have a similar issue? Do you know how to solve it? I would like to listen to my audiobooks via the app as it is a supposedly better way than via Plex app.
Thank you
Fixed in the next version.
I just experienced this myself. But thankfully I have a jailbroken iPhone, and which I realize the last version of Plexamp worked with no problems. However the latest update has this completely broke, if you are jailbroken you will need to downgrade plexamp to the last revision to make it work. Also I would advise that if someone has the last version do not automatically update via the App Store as it will break the login completely
