Plexamp visualizer covers UI elements
Server Version#: 1.24.0.4930
Player Version#: 3.5.0
Just noticed this bug after updating the app today. Scrolling down while playing media caused the visualizer to duplicate. One copy scrolled with the UI, while the other stayed in place while the UI scrolled behind it.
Any chance you rotated the device as well? If so, it should be fixed in the next release.
I don’t think so because I normally have rotation turned off, but it’s quite possible. If I did rotate it though, I’m confident that my phone didn’t switch to landscape orientation, either because I had it locked in portrait mode or because I didn’t rotate the device past the threshold (but can’t be entirely sure which case it was). In any case I haven’t been able to replicate the issue since this one occurrence.
If it happens again in the next release I’ll be sure to post back here!
