PlexBMC 4.0.0 beta v4, Helper 3.4.7 - Script Failed Error
I’m running the following; (on all machines, a mix of Windows and Android)
Plex 2.4.23 PlexPass
PlexBMC v4.0.0 beta v4
PlexBMC Helper 3.4.7
Kodi 14.2 Helix
I have My own library and 2 shared with me.
On all clients I have my server current master server set to my system.
When I go to play video to a remote PlexBMC device (running PlexBMC Helper), on the device I get a script failed error.
`11:13:36 T:40228 NOTICE: PleXBMC -> playPlaylist : == ENTER ==
11:13:36 T:40228 NOTICE: PleXBMC -> playPlaylist : Creating new playlist
11:13:36 T:40228 NOTICE: PleXBMC -> getXML : == ENTER ==
11:13:36 T:40228 NOTICE: PleXBMC.plex -> get_server_from_ip : IP to lookup: 10.0.0.15:32400
11:13:36 T:40228 NOTICE: PleXBMC.plex -> get_server_from_ip : [Cascade] - checking ip:10.0.0.15 against server ip 10.0.0.15
11:13:36 T:40228 NOTICE: PleXBMC.plexserver -> find_address_match : Checking [10.0.0.15:32400] against [10.0.0.15:32400]
11:13:36 T:40228 NOTICE: PleXBMC.plexserver -> processed_xml : We have been passed a full URL. Parsing out path
11:13:36 T:40228 NOTICE: PleXBMC.plexserver -> talk : URL is: /library/metadata/112238/children
11:13:36 T:40228 NOTICE: PleXBMC.plexserver -> talk : URL was: http://10.0.0.15:32400/
11:13:36 T:40228 NOTICE: PleXBMC.plexserver -> talk : Response: 200 OK - Encoding: utf-8
11:13:36 T:40228 NOTICE: PleXBMC.plexserver -> talk : ===XML===
<?xml version="1.0" encoding="UTF-8"?>
                                        ===XML===
11:13:36 T:40228 NOTICE: PleXBMC.plexserver -> talk : DOWNLOAD: It took 0.02 seconds to retrieve data from 10.0.0.15
11:13:36 T:40228 NOTICE: PleXBMC.plexserver -> processed_xml : PARSE: it took 0.00 seconds to parse data from 10.0.0.15
11:13:36 T:40228 NOTICE: PleXBMC -> playPlaylist : Adding playlist item
11:13:36 T:40228 NOTICE: PleXBMC -> trackTag : == ENTER ==
11:13:36 T:40228 NOTICE: PleXBMC -> trackTag : Part is {‘container’: ‘mp3’, ‘file’: ‘M:\Master List\alt-J\This is All Yours\01 - Intro.mp3’, ‘key’: ‘/library/parts/148833/file.mp3’, ‘duration’: ‘278622’, ‘id’: ‘148833’, ‘size’: ‘11404714’}
11:13:36 T:40228 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<–
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type ‘exceptions.NameError’>
Error Contents: global name ‘url’ is not defined
Traceback (most recent call last):
File “C:\Users\mce\AppData\Roaming\Kodi\addons\plugin.video.plexbmc-4.0.0beta4\default.py”, line 13, in
plexbmc.start_plexbmc()
File “C:\Users\mce\AppData\Roaming\Kodi\addons\plugin.video.plexbmc-4.0.0beta4\resources\lib\plexbmc.py”, line 4213, in start_plexbmc
playLibraryMedia(param_url,force=force, override=play_transcode)
File “C:\Users\mce\AppData\Roaming\Kodi\addons\plugin.video.plexbmc-4.0.0beta4\resources\lib\plexbmc.py”, line 1118, in playLibraryMedia
playPlaylist(server, streams)
File “C:\Users\mce\AppData\Roaming\Kodi\addons\plugin.video.plexbmc-4.0.0beta4\resources\lib\plexbmc.py”, line 1080, in playPlaylist
url, item = trackTag(server, tree, track, listing = False)
File “C:\Users\mce\AppData\Roaming\Kodi\addons\plugin.video.plexbmc-4.0.0beta4\resources\lib\plexbmc.py”, line 2195, in trackTag
return ( url, details )
NameError: global name ‘url’ is not defined
–>End of Python script error report<–
11:13:46 T:39080 NOTICE: Thread BackgroundLoader start, auto delete: false`
I’ve trimmed out some portions of the log to save space, I can re-add (such as the full xml of the play list, or my full URL with tokens etc)
Here is another log dump I just ran, PlexBMC set to info, and debug in helper enabled.
13:33:18 T:41820 NOTICE: PleXBMC.plex -> load_tokencache : plexhome_cache data loaded successfully 13:33:18 T:41820 NOTICE: PleXBMC.plex -> setup_user_token : No user set. Will default to admin user 13:33:18 T:41820 NOTICE: PleXBMC.plex -> setup_user_token : myplex userid: Palmore 13:33:18 T:41820 NOTICE: PleXBMC.plex -> setup_user_token : effective userid: Palmore 13:33:18 T:41820 NOTICE: PleXBMC -> Detected parameters: {'url': 'http://10.0.0.15:32400/library/metadata/112246', 'force': '0', 'mode': '5'} 13:33:18 T:41820 NOTICE: PleXBMC.plex -> load : Loading cached server list 13:33:18 T:41820 NOTICE: PleXBMC.plex -> load : unsuccessful 13:33:18 T:41820 NOTICE: PleXBMC.plex -> discover_all_servers : PleXBMC -> Adding myplex as a server location 13:33:18 T:41820 NOTICE: PleXBMC.plex -> talk_to_myplex : url = https://plex.tv/pms/servers 13:33:19 T:41820 ERROR: C:\Users\mce\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\packages\urllib3\util\ssl_.py:100: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#insecureplatformwarning. InsecurePlatformWarning 13:33:19 T:41820 NOTICE: PleXBMC.plex -> get_myplex_servers : Discovered myplex server Cascade <redacted> 13:33:19 T:41820 NOTICE: PleXBMC.plex -> get_myplex_servers : Discovered myplex server TheFatherMind-MB <redacted> 13:33:19 T:41820 NOTICE: PleXBMC.plex -> get_myplex_servers : Discovered myplex server qnap-eric-home <redacted> 13:33:19 T:41820 NOTICE: PleXBMC.plex -> discover_all_servers : MyPlex discovery completed 13:33:19 T:41820 NOTICE: PleXBMC.plex -> discover_all_servers : PleXBMC -> Settings hostname and port: 10.0.0.15 : 32400 13:33:19 T:41820 NOTICE: PleXBMC.plex -> merge_servers : merging server with uuid None 13:33:19 T:41820 NOTICE: PleXBMC.plexserver -> talk : URL is: / 13:33:19 T:41820 NOTICE: PleXBMC.plexserver -> talk : DOWNLOAD: It took 0.01 seconds to retrieve data from 10.0.0.15 13:33:19 T:41820 NOTICE: PleXBMC.plex -> discover_all_servers : PleXBMC -> serverList is: <redacted> 13:33:19 T:41820 NOTICE: PleXBMC -> Mode: 5 13:33:19 T:41820 NOTICE: PleXBMC -> URL: http://10.0.0.15:32400/library/metadata/112246 13:33:19 T:41820 NOTICE: PleXBMC -> Name: 13:33:19 T:41820 NOTICE: PleXBMC -> identifier: None 13:33:19 T:41820 NOTICE: PleXBMC.plexserver -> talk : URL is: /library/metadata/112246 13:33:19 T:41820 NOTICE: PleXBMC.plexserver -> talk : DOWNLOAD: It took 0.06 seconds to retrieve data from 10.0.0.15 13:33:19 T:41820 NOTICE: PleXBMC.plexserver -> processed_xml : PARSE: it took 0.00 seconds to parse data from 10.0.0.15 13:33:19 T:41820 ERROR: C:\Users\mce\AppData\Roaming\Kodi\addons\plugin.video.plexbmc-4.0.0beta4\resources\lib\plexbmc.py:928: FutureWarning: The behavior of this method will change in future versions. Use specific 'len(elem)' or 'elem is not None' test instead. if timings: 13:33:19 T:41820 NOTICE: PleXBMC.plexserver -> talk : URL is: /library/metadata/112238/children 13:33:19 T:41820 NOTICE: PleXBMC.plexserver -> talk : DOWNLOAD: It took 0.01 seconds to retrieve data from 10.0.0.15 13:33:19 T:41820 NOTICE: PleXBMC.plexserver -> processed_xml : PARSE: it took 0.00 seconds to parse data from 10.0.0.15 13:33:19 T:41820 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.NameError'> Error Contents: global name 'url' is not defined Traceback (most recent call last): File "C:\Users\mce\AppData\Roaming\Kodi\addons\plugin.video.plexbmc-4.0.0beta4\default.py", line 13, in <module> plexbmc.start_plexbmc() File "C:\Users\mce\AppData\Roaming\Kodi\addons\plugin.video.plexbmc-4.0.0beta4\resources\lib\plexbmc.py", line 4213, in start_plexbmc playLibraryMedia(param_url,force=force, override=play_transcode) File "C:\Users\mce\AppData\Roaming\Kodi\addons\plugin.video.plexbmc-4.0.0beta4\resources\lib\plexbmc.py", line 1118, in playLibraryMedia playPlaylist(server, streams) File "C:\Users\mce\AppData\Roaming\Kodi\addons\plugin.video.plexbmc-4.0.0beta4\resources\lib\plexbmc.py", line 1080, in playPlaylist url, item = trackTag(server, tree, track, listing = False) File "C:\Users\mce\AppData\Roaming\Kodi\addons\plugin.video.plexbmc-4.0.0beta4\resources\lib\plexbmc.py", line 2195, in trackTag return ( url, details ) NameError: global name 'url' is not defined -->End of Python script error report<--
Can anyone assist? at one point I had this working some time ago, but I can’t determine when it failed and what caused it.
I have several client devices (between Android, FireStick and Windows 8.1) they all inhibit the same Script Failed error with PlexBMC Helper when trying to cast to them.
Some other side notes, in PlexBMC Helpers Config, I do have a different name then the Device name set.
Any assistance would be greatly appreciated.
Thank you.
I have the same problem, only when trying to play Music - any suggestions?
I have the same issue but it starts once I try to select media that should be played on my FireTV 2. Use the control keys works fine however.
@DANANGDEMO Can you play video files without the script issue?
No trouble at all
@DANANGDEMO Have you find the solution since the end of last year?
Because I have the same probleme only for music with plugin.video.plexbmc-4.0.0beta4 and script.plexbmc.helper-3.4.2
