PlexComskip on Ubuntu
Anyone else ever seen this error? I can’t seem to get it to process the files. However, if I sudo to the plex ID and run it against the file it works fine.
2017-06-23 08:00:10,941 [7d96ba] Using session ID: 7d96ba26-49e2-4195-9df3-a54166d0a9f9 2017-06-23 08:00:10,942 [7d96ba] Using temp dir: /tmp/7d96ba26-49e2-4195-9df3-a54166d0a9f9 2017-06-23 08:00:10,942 [7d96ba] Using input file: /Media/TV Shows/.grab/bae34e95481c670490b84f1176ef77068d2871b9/Wild Kratts (2011) - S02E14 - Seahorse Rodeo.mkv 2017-06-23 08:00:10,942 [7d96ba] [comskip] Command: ['/usr/local/bin/comskip', '--output', '/tmp/7d96ba26-49e2-4195-9df3-a54166d0a9f9', '--ini', '/opt/PlexComskip/comskip.ini', '/Media/TV Shows/.grab/bae34e95481c670490b84f1176ef77068d2871b9/Wild Kratts (2011) - S02E14 - Seahorse Rodeo.mkv'] 2017-06-23 08:00:10,959 [7d96ba] Using EDL: /tmp/7d96ba26-49e2-4195-9df3-a54166d0a9f9/Wild Kratts (2011) - S02E14 - Seahorse Rodeo.edl 2017-06-23 08:00:10,960 [7d96ba] Keeping segment from 0.0 to the end of the file... 2017-06-23 08:00:10,960 [7d96ba] [ffmpeg] Command: ['/usr/bin/ffmpeg', '-i', '/Media/TV Shows/.grab/bae34e95481c670490b84f1176ef77068d2871b9/Wild Kratts (2011) - S02E14 - Seahorse Rodeo.mkv', '-ss', '0.0', '-c', 'copy', 'segment-0.mkv'] 2017-06-23 08:00:10,995 [7d96ba] Going to concatenate 0 files from the segment list. 2017-06-23 08:00:10,996 [7d96ba] [ffmpeg] Command: ['/usr/bin/ffmpeg', '-y', '-f', 'concat', '-i', '/tmp/7d96ba26-49e2-4195-9df3-a54166d0a9f9/segments.txt', '-c', 'copy', '/tmp/7d96ba26-49e2-4195-9df3-a54166d0a9f9/Wild Kratts (2011) - S02E14 - Seahorse Rodeo.mkv'] 2017-06-23 08:00:11,028 [7d96ba] Sanity checking our work... 2017-06-23 08:00:11,029 [7d96ba] Something went wrong during sanity check: [Errno 2] No such file or directory: '/tmp/7d96ba26-49e2-4195-9df3-a54166d0a9f9/Wild Kratts (2011) - S02E14 - Seahorse Rodeo.mkv' 2017-06-23 08:00:11,029 [7d96ba] Leaving temp files in: /tmp/7d96ba26-49e2-4195-9df3-a54166d0a9f9 2017-06-23 08:00:11,029 [7d96ba] Done processing!
I have this problem also. Has anyone overcome it?
same problem
I have not solved it yet
what exactly do you mean by
does this mean you added the user plex to the sudo or?
