Can plexconnect play audio plugins such as the new SomfaFM plugin, Grooveshark..etc?
thanks.
thanks.
If its available via the Unsupported app store or plex channels then yes. Look at UAS installer in my signature it works for windows and OSX.
That's where I got them from. Both SomaFM and Grooveshark will show one menu level of lists, however in SomaFm for instance, I can't view channels. I get an error msg. For Grooveshark, I can't search..also an error msg.
OSX Mavericks
Plex Version 0.9.9.11.501-fd87a84
PlexConnect latest build
PlexConnect set to Transcode
Thanks!
If you are getting those error messages then probably not, at least not currently. The plugin may need some work or something else.
Ok at least i know it's not my set-up. thanks.
