PlexConnect Cert Error
Haven’t used my ATV3 in some time. Tried today and nothing working as expected.
PlexConnect Version: 0.7-dev-151218
Python: 2.7.15
PMS Version 1.14.1.5488 (MacMini)
Mojave 10.14.2
PMS Version 1.14.1.5488 (WD PR4100 NAS)
WD NAS FW 2.31.149
The error I’m seeing in plexConnect is;
Jan 13,2019 11:35:22 DNSServer: -> DNS response: 192.168.0.111
Jan 13,2019 11:35:22 WebServer: serving .xml: /PlexConnect.xml
Jan 13,2019 11:35:46 WebServer: serving .xml: /PlexConnect.xml
Jan 13,2019 11:35:46 WebServer: File Not Found:
Traceback (most recent call last):
File “/Applications/PlexConnect-master/WebServer.py”, line 244, in do_GET
XML = XMLConverter.XML_PMS2aTV(PMSaddress, self.path + query, options)
File “/Applications/PlexConnect-master/XMLConverter.py”, line 241, in XML_PMS2aTV
(username, auth_token) = PlexAPI.MyPlexSignIn(parts[0], parts[1], options)
File “/Applications/PlexConnect-master/PlexAPI.py”, line 668, in MyPlexSignIn
response = urlopener.open(request).read()
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 429, in open
response = self._open(req, data)
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 447, in _open
‘_open’, req)
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 407, in _call_chain
result = func(*args)
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 1241, in https_open
context=self._context)
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 1198, in do_open
raise URLError(err)
URLError: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:726)>
Possible reasons:
  1. Timezone incorrect in the ATV
  2. Expired certificate (in this case you need to generate a new one)
  3. Or maybe this
Does the PR4100 support docker ? If yes, probably you can install this and run PlexConnect from it instead of Mac.
Thx for the reply. Indeed i tried checking the time zone but that did not resolve the issue. It looks like option 3 as u have linked.
Im unsure about docker. Indeed that would be great ill look into that option and post my results
