Apple TV model 3 version 7.0.1
DNS - 192.168.0.14
Local address - 192.168.0.14
Windows 10
Plex server version 1.1.4.2757
Plex local - 192.168.0.14
Downloaded copy today of plex connect
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
allow_gzip_atv = False
allow_gzip_pmslocal = False
allow_gzip_pmsremote = True
loglevel = Normal
logpath = .
Keep getting the error plexconnect failed to connect to https 443 on the plex command line.
log file
21:47:45 PlexConnect: started: 21:47:45
21:47:45 PlexConnect: Version: 0.5-dev-110616
21:47:45 PlexConnect: Python: 2.7.12 (v2.7.12:d33e0cf91556, Jun 27 2016, 15:19:22) [MSC v.1500 32 bit (Intel)]
21:47:45 PlexConnect: Host OS: win32
21:47:45 PlexConnect: PILBackgrounds: Is PIL installed? False
21:47:45 Settings: getsetting enable_plexconnect_autodetect=True
21:47:45 PlexConnect: IP_self: 192.168.0.14
21:47:45 Settings: getsetting hosttointercept=trailers.apple.com
21:47:45 Settings: getsetting enable_dnsserver=True
21:47:46 DNSServer: started: 21:47:46
21:47:46 Settings: getsetting port_dnsserver=53
21:47:46 Settings: getsetting ip_dnsmaster=8.8.8.8
21:47:46 Settings: getsetting prevent_atv_update=True
21:47:46 DNSServer: ***
21:47:46 DNSServer: DNSServer: Serving DNS on 192.168.0.14 port 53.
21:47:46 DNSServer: intercept: [‘trailers.apple.com’] => 192.168.0.14
21:47:46 DNSServer: restrain: [‘mesu.apple.com’, ‘appldnld.apple.com’, ‘appldnld.apple.com.edgesuite.net’] => 127.0.0.1
21:47:46 DNSServer: forward other to higher level DNS: 8.8.8.8
21:47:46 Settings: getsetting enable_webserver_ssl=True
21:47:46 WebServer: started: 21:47:46
21:47:46 Settings: getsetting port_webserver=80
21:47:46 WebServer: ***
21:47:46 WebServer: WebServer: Serving HTTP on 192.168.0.14 port 80.
21:47:46 Settings: getsetting port_ssl=443
21:47:46 Settings: getsetting certfile=./assets/certificates/trailers.pem
21:47:46 WebServer: Failed to connect to HTTPS on 192.168.0.14 port 443: [SSL] PEM lib (_ssl.c:2603)
21:47:51 PlexConnect: Shutting down.
21:47:52 WebServer: Shutting down (HTTP).
21:47:56 DNSServer: Shutting down.
21:47:56 PlexConnect: shutdown
Ok i sorted out the certificates error but now get this
21:56:01 PlexConnect: started: 21:56:01
21:56:01 PlexConnect: Version: 0.5-dev-110616
21:56:01 PlexConnect: Python: 2.7.12 (v2.7.12:d33e0cf91556, Jun 27 2016, 15:19:22) [MSC v.1500 32 bit (Intel)]
21:56:01 PlexConnect: Host OS: win32
21:56:01 PlexConnect: PILBackgrounds: Is PIL installed? False
21:56:01 PlexConnect: IP_self: 192.168.0.14
21:56:01 DNSServer: started: 21:56:01
21:56:01 DNSServer: ***
21:56:01 DNSServer: DNSServer: Serving DNS on 192.168.0.14 port 53.
21:56:01 WebServer: started: 21:56:01
21:56:01 WebServer: ***
21:56:01 WebServer: WebServer: Serving HTTP on 192.168.0.14 port 80.
21:56:01 WebServer: WebServer: Serving HTTPS on 192.168.0.14 port 443.
21:56:08 PlexAPI: ***
21:56:08 PlexAPI: PlexGDM - looking up Plex Media Server
21:56:09 PlexAPI: GDM: Servers discovered: 1
21:56:09 PlexAPI: Servers (local, plex.tv, MyPlex): 2
21:56:10 PlexAPI: No Response from Plex Media Server
21:56:10 PlexAPI: We failed to reach a server. Reason: Unauthorized
21:56:10 PlexAPI: Traceback:
Traceback (most recent call last):
File “C:\Program Files\PlexConnect-master\PlexAPI.py”, line 432, in getXMLFromPMS
response = urllib2.urlopen(request, timeout=20)
File “C:\Python27\lib\urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
File “C:\Python27\lib\urllib2.py”, line 435, in open
response = meth(req, response)
File “C:\Python27\lib\urllib2.py”, line 548, in http_response
‘http’, request, response, code, msg, hdrs)
File “C:\Python27\lib\urllib2.py”, line 473, in error
return self._call_chain(*args)
File “C:\Python27\lib\urllib2.py”, line 407, in _call_chain
result = func(*args)
File “C:\Python27\lib\urllib2.py”, line 556, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 401: Unauthorized
Just in case anyone has the same issues.
For certificates just try running them again
The authentication issue please follow here https://forums.plex.tv/discussion/comment/1244304/#Comment_1244304
