PlexConnect changelog
Fixes and improvements...
03. Nov
decouple PMS discovery from requesting PlexConnect.xml
optimization: don't add '/PMS( )' to URL if PMS is unspezified
grab and store name/uuid for manual defined server, too
Movie List fix
05. Nov
scrobble redone - for servers far, far away.
AudioAndSubs - with MyPlex/remote server support, though it seems som…
06. Nov
poke MyPlex PMS before registering. add 'scheme' to PlexAPI. use 'bas…
08. Nov
merge salbahra's updates to Trailers (pull req #173) - now working di…
big changes - small testing: remove ADDR_PMS, remove setting PMS_uuid
allow aTV to request from multiple PMSs: /PMS(//) - recombine M…
fix: supress "headline" if Library/MyPlex has only one server to show
09. Nov
remove setting "viewmetadata" - split "Movie_List": new movieview opt…
Rename option: now "Detailed List"
10. Nov
add error checking for certificate (*.cer) not found
serving *.js: answer request to main.js with sending application.js, …
12. Nov
performance improvements - disable "prettyXML( )" for loglevel=Off or…
new POT for new translation...
Two weeks with minor enhancements - plus some development under cover.
16. Nov
merge pull req #186 - add setting for aTV app to use.
21. Nov
Issue #185 - add "string.format" and modify "input password" text
22. Nov
Channel view options: List, Grid, Bookcase
This thread needs some updates... OSX daemon installer anybody?
29. Nov
install OSX daemon to run at boot - merge PullReq #182
02. Dec
replace atv.plexconnect by IP:port - removes the need to DNS-redirect…
OSX starter: merge changes from branch OSXautostart (own Pull Req #195)
03. Dec
Rewite EVAL to support passing attributes as arguments
05. Dec
Merge pull request #197 from tallerthenyou/master
add credits to meltman (wiki)
05. Dec
merge PulReq #199, first part // add Version, use EVAL() to bring it …
quick fix: push Version out to extra file to prevent circular depende…
fixed test code in XMLConverter
07. Dec
OSX plist - remove "start" argument. It's not used...
08. Dec
OSX Installer - optimize pwd usage, fix cert echo issue
09. Dec
update language pack from getLocalization - added three new locales.
aTV2 (jailbreak): running right on this little box...
10. Dec
OSX install: check for cert ".pem"
PlexConnect on aTV (jailbroken)
OSX install: align files with aTV learnings
12. Dec
OSX/aTV install: edit comments, readme
JS - change string identifier to " -> fix "the french settings issue"
15. Dec
aTV_jailbraek: add own button...
international weeks, part 2: fixes and enhancements - this time for Italy and Sweden. :-D
16. Dec
aTV_jailbreak: add missing "settings.cfg" by filtering only *.cfg in …
fix Italian issue - enclose XML strings in .JS in double quotes, esca…
17. Dec
aTV: fix button name
*_daemon.py: update 1st line - link to python
support for utf-encoded image paths (Pull Req #196)
aTV install: update readme regarding python installation
18. Dec
"Version" file rename (it's shorter now. :-), logging of Version, Pyt…
19. Dec
*daemon.bash - add current path resolver, add restart option
Holiday season - let's start celebrating with V0.3!
21. Dec
Stable? V0.3!
More rather impressive numbers - as of today:
on github:
- 456 commits
- 143 watches
- 722 stars (!)
- 305 forks - yep, there are still development opportunities :-)
on Plex forums:
- views of "read before posting: approaching 90.000 - and this is only a 3 post thread.
- posts in this sub forum: > 15.000, more than any other third party client, we even past the native aTV client a couple of days ago. (Uh. Just found that I myself added probably about 1.500 posts - got to scale back on that... :-D)
Enough said... time to get implementing other goodies (subtitle, PrePlayScreen, Watched Progress, Refresh,... list is still long).
Happy holidays to everyone!
Happy new year everyone!
25. Dec
Changed all instances of my.plexapp.com to plex.tv. Fixes MyPlex log …
Merge pull request #207 from dionlarson/master
26. Dec
v0.3.1
27. Dec
increase http timeout for accessing PMS (issue #194)
use HostToIntercept for the baseURL (PulReq #205)
28. Dec
cleanup - remove DNS twisting from code base
02. Jan
PrePlay re-architecture - only for iOS 5.2+, Audio/Subs butto…
03. Jan
refresh section, take 2 => Select&Hold in Library view/on Section name.
5th Jan.
Some UI tweaks and the ability to access channels remotely on your OWNED servers. Full notes:
UI updates...
- Library shows “owned” instead of “local”
- MyPlex renamed to “Shared Libraries”, it’s “shared” instead of
“remote”
- Channels show plugins of remote, owned servers now
- show title for Movie/TVShow sections
not a lot of changes... but very important steps for some!
11. Jan
clean certfile path before handing off to socket()
-> this is for our Windows users with trouble setting up PlexConnect in the first place. I tend to push A LOT of reported issues here...
15. Jan
subtitle rendering - 1st shot. :-)
-> this is for our Subtitle readers, especially those with lower powered PMS hosts. I would rather grab a book - Winnie Pooh or so... :-D
current state:
- SRT only
- no formatting (italics, bold, underline…)
- prevents ALL PMS subtitle activity
Have fun testing!
Main updates are to do with subs. Users can now update knowing they can switch off the newer subtitle code if they are having issues with it - give it a try though and provide feedback in the official subs sticky!
There has also been a change to the UI on TV shows, if you use the bottom shelf on the pre play screen to flick through episodes then you do not get "trapped" any more, hitting back via the menu button will kick you back to the top level ;)
Jan 20, 2014
Jan 19, 2014
Jan 18, 2014
Jan 16, 2014
Jan 15, 2014
More changes related to subtitle handling and added some validation of settings.cfg (invalid entries will revert to default e.g. using "high" instead of "High" will result in the setting reverting back to default).
Jan 28, 2014
Jan 27, 2014
Jan 25, 2014
Jan 24, 2014
Jan 29, 2014
The road map has also been updated.
If you are a Python developer and want to contribute code then the roadmap below may help you identify specific areas for pull requests.
PlexConnect 0.4
Complete:
  • Channels working in MyPlex
  • Refresh sections on servers via the ATV (hold select down when in the section)
  • Validation of settings.cfg file (incorrect settings revert to default)
  • Flatten seasons if only one is present
Underway:
  • GUI improvements (possibly including fanart if the bugs can be worked out)
  • Subtitle renderer
  • Create a more relevant template for Home videos sections as opposed to reusing the Movies template e.g. browse by folder being top level option
Not yet started:
  • Fix stacked files support
  • Option to show numbers (e.g. 8/10) instead of stars for ratings
  • Ability to play files from a section or from season one after the other (sequentially or randomly)
  • Handle broken channel messages (https://github.com/iBaa/PlexConnect/issues/213)
  • Support Plex dialogue boxes
  • Explanations in the settings.cfg file for config options
  • Save settings.cfg at periodic intervals
PlexConnect 0.5 (tentative)
  • Ability to delete files from PMS
  • Support indexed media files for fwd/rwd previews
  • Add "view transcoderstate" at start of playing (/resuming?) media file - similar to clock or end time
  • Fling media to PlexConnect (if it can be done well)
  • Pseudo random selection on pivot screens for genres (this would be better served based at the PMS end)
  • Pressing the play button on a season of a TV show will automatically play the first partially watched / unwatched episode
Not yet assigned to any point release:
  • Global on deck section (aggregated local sections) at root of menu
  • MyPlex fast user switching
  • Utilise GZIP communication PMS->PlexConnect; enable/disable it depending on processor power vs network speed (LAN/WAN)
  • Implement log rotation based on date and/or size
  • Aperture plugin working
  • Music sections working (not sure if this is possible)
  • Audio offset option
  • Built in update mechanism
  • Ability to run PlexConnect as a service on Windows (there are currently a few methods to achieve similar to this in forum threads)
  • Native helper applications for OSX/Win/Linux
  • Python 3 support
More subtitle. Plus other goodies - Welcome back, Roidy!
30. Jan
Settings - loosen check for HostToIntercept (localhost does't contain…
31. Jan
Improves SSL certificate generation
01. Feb
Flatten 'All Seasons' fix
Merge pull request #229 from jeroenj/patch-1
remove Season.xml - not in use any more.
Send MyPlex token to flattenSeason
Fix accessToken type for unwatched section
02. Feb
remove "allow_no_value" which is unsupported prior to python 2.7
03. Feb
fix: subtitle renderer does not work with transcoded media
04. Feb
Added Detailed List option to Home Video views
06. Feb
Added Genres and Collections to home video view
stacked media - report correct "viewOffset" from later parts
small fix in log comment...
07. Feb
subtitle - add drop-shadow for improved readably on light background
read: add subtitle.py to file overview
08. Feb
Only show "Shared Libraries" item if signed into myPlex
Small tidy up.
Fixed myPlex failed login
Clean up, remove unused RefreshLibrary code.
Quite a number of GUI tweaks plus early support for running PlexConnect as a service on Windows (see the support folder for details)
Feb 17, 2014
Feb 16, 2014
Feb 15, 2014
Feb 13, 2014
Feb 12, 2014
Feb 11, 2014
Includes a pretty important fix for the recently added section on the TV show On Deck page.
Feb 19, 2014
Mostly bug fixes for various items:
Mar 05, 2014
Mar 01, 2014
Feb 28, 2014
Feb 24, 2014
Feb 22, 2014
Feb 21, 2014
The major two changes involve:
  • Support Plex dialogue boxes for channels
  • Those using reverse provides no longer need the "AllowEncodedSlashes On" in their web server configuration
Mar 25, 2014
Mar 19, 2014
Mar 10, 2014
Mar 09, 2014
Mar 08, 2014
New feature: transcoding audio from non-native formats!
07. Apr
add Library View: Grid, Bookcase
13. Apr
enhance Photo view
14. Apr
fix reported aTV IP in "forwarding" environments (X-Forward-For", eg. on Syology)
18. Apr
add support for audio transcoder
Apr 18, 2014
Also we are doing some testing on a cross platform GUI, see this thread for details.
