PlexConnect changelog
Things have slowed down: https://forums.plex.tv/topic/112418-changelog-says-last-was-418/
Here is an update...
06. May
bugfix: JSConverter translating {{URL()}}
honour request for "bootstrap.js"
13. May
rework http "query" handling to get closer to standard
fix: better differentiate between "similar" IP Adrs (eg. *.10 vs *.107)
16. May
Added detailed list view to TV shows
28. May
Library Grid/Bookcase: remove Search Icon...
05. Jun
new POT file waiting for upload to "get localization"
Let's call it 0.4. Still some issues left - just I have no idea how to fix 'em... :-(
28. Jun
pull req #262 - Allow concurrent web requests
04. Jul
update language files from getlocalization.com
24. Jul
Pretty stable... let's call it 0.4.
Oh no... again missed a month!
05. Aug
merge PullReq#269 "DNS listen using SO_REUSEADDR", bump version
10. Aug
deal with " in translations... dedicated especially to our Portuguese…
13. Aug
Fix for missing season artwork
19. Aug
Movie Extras
23. Aug
ping transcoder to keep it alive
24. Aug
Update logging code
25. Aug
Playlists? Video playlists implemented.
bugfix: movie view pulled homevideoview setting
playlist: add composite image to overview
playlist: do not order per video type
Another month. Playlists are playlists now - though we still lack "shuffle".
26. Aug
Base section type on scanner used.
27. Aug
Revert "Base section type on scanner used."
31. Aug
rewrite of PlayVideo.xml, new cmd {{COPY_PLAYLIST}}
02. Sep
Base section type on scanner...... again.
07. Sep
"continuous" - correcting spelling
09. Sep
fix channels
14. Sep
fix: update ratingKey (and other metadata) in playlist
16. Sep
improve timeline report on stacked media
fix: video overlays are missing...
19. Sep
Fix always on clock bug. Start clocks as hidden.
20. Sep
Quick options to remove Playlists & Shared Librarys
Add option to remove On Deck sections
21. Sep
proxy ATVSettings to std+SSL WebServer/XMLConvert
22. Sep
playlist without signing in // added log details
24. Sep
prevent early termination of ATVSettings proxy
Just about 2 weeks - a lot has happened: Music! Shuffle! FanArt! Roidy's back! :-D
28. Sep
music streaming? major rework coming up... (iOS 8)
30. Sep
music support: shuffle! (iOS8)
Channels: "No Items Available"
01. Oct
sprint - rework XML pretty-print decision
04. Oct
align Video_ChannelsV1 with current PlayVideo.xml
Music navbar + fix shuffle coverart
Start in correct section for xml update to work
Swap Album/Artists
Add track times to track list
Pad < 10 seconds with a leading zero
Consolidate Video & Audio duration to one function
05. Oct
First stab at official Fanart....
TV Show Episode list fanart
A few bug fixes
D'oh!... committed a file that wasn't ready.
Season List Fanart View
fix - duration for old style music XML (channels)
06. Oct
Optimize background creation + fix season coverflow
Missed a durationToString change.... D'oh!
07. Oct
Season Coverflow Fanart view
08. Oct
rework d045fc6 - set navbar item to "library"
Revert "rework d045fc6 - set navbar item to "library""
rework d045fc6 - set navbar item to "library" (now correctly :-)
Shuffle Playlists (video)
Sorry for the wait!
No big changes, just some maintenance... and a couple of things I wanted to look into for a long time.
09. Oct
extend Search to show Albums, Artists
10. Oct
"Playlists" now support Audio as well...
add-on to #13a95ca - Directory.xml wasn't meant to be removed.
11. Oct
Tweaked the gradient templates...
Fix Audio Playlist track thumbs
cleaning code: PILBackgrounds
Audio Playlist Shuffle coverflow....
Same for Video Playlists
Added {{TEXT()}} to new..... text :-)
12. Oct
Episode PrePlay Fanart + some optimizations
13. Oct
"quote" cached filename, add token to PMS requests
playlists - show actual title in list's headline
14. Oct
Fix Season CoverFlow Fanart lines on ios<8
Arghhh.... fixed blank lines at bottom of gradients
15. Oct
Fanart: use PMS/art-id to identify background
16. Oct
Stop trailer button appearing in episode preplay.
more background tweaking...
catch a third err: IOError when reply is no image
18. Oct
Updated Change Artwork to allow fanart selection
20. Oct
Season List Fanart fix if poster is missing
21. Oct
Automagically save aTV settings.
22. Oct
Separate out change fanart menus.
Rename 'Artwork' to 'Poster' / 'Fanart'
Respond to the aTV when requesting to save settings.
Keep Baa happy ;)
30. Oct
Fanart sesaon list fix missing image.....
01. Nov
add ratingKey to cache filename
04. Nov
TVShow preplay screen: add direct play for additional episodes (butto…
12. Nov
music/playlist: controls tweak - "select" is main
Make 'PIL/Pillow not installed' item unselectable
22. Nov
Fix xml names - Linux filenames are case sensitive
26. Nov
add "now playing". missing JS to hide item. :-(
fix spelling (please re-hide shared libraries, if needed/wished)
new POT - did we really change that much?
28. Nov
PILBackgrounds - disable for iOS prior to 6.0
30. Nov
Fix ByFolder post-play navigation
tweaks on aTV2 installation instructions
01. Dec
add short note on PILBackgrounds
05. Dec
replace loadURL overrides by onGenerateRequest
06. Dec
onGenerateReq: allow non-std. URL parameters
10. Dec
js: new algorithm to update main navbar changes
Here you go: PlexConnect v0.5 released.
13. Dec
quick fix: syntax error in a onPlay event
Update gitignore for VS Express
gitignore suo files and fix line feeds
Remove 'PILL not installed' message from PILBackgrounds.py
14. Dec
upload new POT files (localization), release V0.5
github missed two files?
cleaning up the backlog - a month worth of updates (15. Dec to 14. Jan).
16. Dec
extend {{URL}}, rework {{PLAY}} parameters
bump version to 0.5-dev
19. Dec
Added Tabbed List Channel view
20. Dec
Option to blur lower portion of fanart images
Added Tabbed List PLaylist view
Forgot to cut empty tabs...
21. Dec
another little bug fix...
why did PhotoSection have a different columnCount?
Massive update to the XML selection code
Didn't mean to commit Debug.py :(
Fix Music/Directory and Music/Secondary
Remove \Main\Directory*.xml files
Point the iTunes scanner to the right directory
Channels/Audio - own, fresh XMLs
Fixed Playlist Audio/Video
Fix Channels/Photo
22. Dec
two fixes: Shared servers, View redirection
Fix "View Show" from scrobble menu
Fix MyPlex Sign In/Out
playlists template tweaks
23. Dec
Fix Channel Search.... Hopefully :)
Movie PrePlay bottom shelf option.
24. Dec
Fix Music Now Playing Info
Increase resolution of ByFolder images
Tab fix... Merry Christmas Baa :D
Arghh..... again with Debuy.py :(
Fix Photo sub-directories
25. Dec
Fix for Photo Channels
26. Dec
Fix Play button on Movie PrePlay
27. Dec
Fix TV Show DetailedList.
rework "redirection" / consolidate photo browser
add "now playing" to playlists/audio, too
playlists/audio: PLAY on headline shuffles songs
Expand rediect to allow a new path
Forgot to update path with new value :(
Don't need to declare redirect twice :(
28. Dec
Fix FlattenSeason Unwatched
29. Dec
Merge branch 'master' of https://github.com/iBaa/PlexConnect
channels search: remove special code, let XMLConverter do the job
XMLConverter test code update...
PMSmark: change to IP:port
Simplify Flatten Season
Fix TV Secondary showview
30. Dec
Fix flattenseason - option now working
31. Dec
fix Search->Show link
fix Music/Directory to avoid double-entries
discovery: show spinner during look up
fix music/artist: CUT needed adaption (too wide)
04. Jan
NavBar feature: "Hide" for every item
fanart setting: verify with aTV/host capability
05. Jan
typo - delete the "s".
11. Jan
merge pull reqs #189 and #293 - use gzip for com
Main changes: enhanced media badges, initial Plex Home support
17. Jan
Extra error checking in PILBackgrounds.py
18. Jan
en-/disable gzip compression
24. Jan
Enhanced Media Badges
fix: Library/Grid, Bookcase: "not available"
25. Jan
basic Plex Home support
Life is busy - isn't it?
25. Jan
No media badges for firmware<6 :(
fix: PlexHome.xml to display "lock"
Plex Home: improve "protected", add Sign Out
26. Jan
XVID badge and mpeg4 sub codecID
28. Jan
PlexHome: rewrite authorisation handling
31. Jan
2k 4k and H265 badges added
03. Feb
Treat all mpeg4-part2 files as xvid.
05. Feb
1.0 (mono) badge
08. Feb
Fix for S-BABS scanner
11. Feb
Settings/myPlexSignInOut: update Discover/PlexHome
16. Feb
better error log: dprint(traceback)
23. Feb
PlexGDM: switch from "broadcast" to "multicast"
Development is slowing down? My take: Things are pretty solid. :-D
Ok, honestly, I start to like that thing and watch movies/shows more often now...
02. Mar
Settings: when coming back from HomeUse selection, invalidate display…
03. Mar
Remove invalid file reference.
13. Mar
Fix for BABS scanner
30. Mar
Settings clean up...
update localization - mainly plex home, settings
With that, please head over to http://www.getlocalization.com/PlexConnect/ and update your favorite language!
21 Apr
Fix for Movie_ByFolder sub Directory preplay.
search: get rid of XMLConv “special case”, fix typo
Plex-wide search in main NavBar
25 Apr
global search: hide PMS name if you got only one…
fix search “episode”: pull in TVShow PrePlay
26 Apr
Option to hide new global search
01 May
Quick fix to get Premium Music section to work…
02 May
First attempt at some Premium Music features…
MOV badge
04 May
First attempt at "Plex Mix"
Show music videos on the album track list view.
The day of the WWDC keynote: New aTV hardware?
06. May
Fix for Photo section not working
13. May
fix cutting names for high number of PMSs
16. May
WMV badges
17. May
Fix HomeVideo ByFolder error ...
home video: add new scanner, fix ByFolder
Fix SectionPreview-photo filename case....
24. May
MPEG badges
02. Jun
update language files - add ca-AD
redo 61cbbed - fix photo filename case...
Long time no update to this list - only some smaller fixed @github:
-18. Jun
allow “-” at host URL
(https://github.com/iBaa/PlexConnect/commit/88d8e134e840b196fe694c3c1c946cca7b3f4770)
-13. Jul
fix links into new plex forums
(https://github.com/iBaa/PlexConnect/commit/2c414f07809aa36be38f1b141772163eb3f3f748)
-31. Aug
don’t hide HttpException (aka BadStatusLine) with PMSs requiring encr…
(https://github.com/iBaa/PlexConnect/commit/0b9d96fcc8c6e631a4f6bb2669e7e05da0fe5c76)
-21. Oct
re-architect discovery to help with https encryption (#352)
(https://github.com/iBaa/PlexConnect/commit/1d4e285214fd96281e81007e43c7600e0d12f935)
-27. Oct
discovery: init with first connection, even if local/remote tag doesn…
(https://github.com/iBaa/PlexConnect/commit/bc48d8314f081c0fd6f2809852af6a72818bcc4c)
-03. Nov
Buffering fix, Hopefully…
(https://github.com/iBaa/PlexConnect/commit/ba6529fd0089523d7c30009e6ef9abd100bc9e73)
-06. Nov
DNS: create new socket for each request. should solve #375
(https://github.com/iBaa/PlexConnect/commit/b19e4824f1c3821a73c54a5c57f6c12593895793)
