Hm. I am running PMS 0.9.11.7.803-87... and have no issues.
No need not, here done this a few times and did not need!
Too bad it iBaa!
I noticed you are running Plexconnect version 0.5-dev. Might try rolling back to version 0.5 https://github.com/iBaa/PlexConnect/archive/v0.5.zip as mentioned in this thread https://forums.plex.tv/topic/132734-massive-update-to-xml-selector-read-before-updating/
I didnt have the same exact problems as you, but mine were numerous and rolling back to 0.5 fixed them instantly for me.
I am also running PMS 0.9.11.1 but at this point I dont think that was the culprit for me.
HI,
yesterday, I installed the update of PMS on my win32 machine to Version 0.9.11.7. I had the same issue, ATV Trailers did not work anymore.
on the plexcoonect screen, i can see the dns redirect working. ATV says: 'Trailers not availible'. Another thing, I did was upgrading to Plex-Pass.
All Firewall Issues tested on Windows 7 plex machine, Tested with plexconnect 0-5. The Problem remains the same.
Do I have to roll-back the PMS Server Version?
br
PS. Back to PMS Version 0.9.11.4, The Issue remains. Could there be something interferring with the rights management for PlexPass? I do not have anybody in the "Plex Home", but have shared my Libraries to a friend.
PPS. I´ve just rebuilt the formerly working version from 11/2014 PMS Version 0.9.11.1 with my old plexconnect 0.31+ and the ATV tells me 'Trailers not available'
If your PMS would have issues communicating to PlexConnect you would at least find the aTV main Navbar and a message like "PlexConnect: no items available".
"trailers unavailable" will be shown if PlexConnect isn't able to answer, or the produced XML doesn't fit to aTVs needs. The latter - at least when it comes to the initial PlexConnect.xml - shouldn't be affected by PMS.
Does this new PMS change any firewall settings? Does it come with a new python versions?
Hi, there.
at least MY Problem is solved. After removing all Software components and reinstalling all significant components, ATV did not stop saying 'Trailers not accessible'.
Then I found out that simply the used certificate has been expired. I made a new certificate, uploaded it to the ATV and --- it worked!
I' ve now the most recent versions of PMS and plexceonnect and erverything works.
best regards
I too am running into issue after updating my Debian-based Linux server to 0.9.7.803.87d0708.
I have now found a workaround in disabling secure access with the PIN, which I did set up as soon as I was given the option. Now that the PIN has been disabled, PlexConnect is working again without issues.
Hope this helps.
Best regards,
Luca
Does it work on other plex clients like iOS app or other client? Maybe you need to completely remove Plex Media Server and start fresh. Just copying and pasting the app/program into its original location will not remove old settings.
https://support.plex.tv/hc/en-us/articles/201941078-Uninstall-Plex-Media-Server
