Would anyone tell me if there is any configuration to operate the 0.9.11.6 version of plex?
weird, it works for me with .5 and .6 and .7 from yesterday, what ver of plexconnet are you running?
0,5, 0,6 or 0,7 tested
look this error:
Why not try the latest PP release? Ah looks like you already did. Can you provide your issue in much greater detail so everyone can assist your better using this template? I can also confirm with other users that the latest PP works with PlexConnect.
Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV 3
The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.25.5
The local IP address of the device that PlexConnect is installed on: 192.168.25.5
The device and operating system (including version number) that PlexConnect is installed on: ATV - 7.0.2
The device and operating system (including version number) that the Plex media server (PMS) is installed on: Notebook x64 - Windows 8.1 64bits
The Plex media server (PMS) version number you are running (do not put 'latest'): Plex-Media-Server-0.9.1106.800-831ffad-en-US
The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.25.5
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any non-standard setup e.g. Plexify or a fork. version 0.5
The contents of your 'Settings.cfg' file (this is created at first clean shutdown of PlexConnect, using CTR+c)
A detailed description of the issue (the clearer you can make this the better): The plexconnect works in ATV, but is there no library.
Ensure you post your 'PlexConnect.log' file to pastebin and post the link ('PlexConnect.log' is located in your PlexConnect folder). If possible, follow these steps to create a "more detailed fresh" one:
- shutdown PlexConnect
- in 'Settings.cfg', set loglevel to "High" (note the capital 'H')
- delete the existing log file
- restart PlexConnect
- repeat the issue
- immediately close PlexConnect and post the log.
- in 'Settings.cfg', set the loglevel back to "Normal"
So the PlexConnect library tab just has a spinning wheel? Can you download a fresh copy of PlexConnect and leave your Settings.cfg file as default? What is your old Settings.cfg file also? You posted your ATVSettings.cfg file earlier.
Strange it works for other users but not for you. Got me, sorry I can't assist any further. Hopefully someone else can debug it further for you. Also paste your new settings.cfg if you get a chance or if its the default one just say that is it the default one.
"wahlman.j"
all plexconnect files are new...
Just curious but did you try to uninstall plex and go back to the .4 public release?
[PlexConnect]
Plex Home enabled?
ip_pms = 192.168.25.5 <-----------This is not default
wahlman.j
Only doing a test, but I was the default address!
Baa
Which doesn't matter at all - since PlexGDM is active.
>> Plex Home
No, no setting. But not supported by PlexConnect...
Here only PMS and Plexconnect
In this environment it works my friend!
Hi everyone, I need your help, yesterday my plex was upgrade to version 0.9.11.7 and after the restar of computer PlexConnect not work again, DNS relay work ok but Trailers (in apple tv 3) say imposible to connect to trailers.... I don't know what happen; I try to restore (restore point of windows 8.1) before the instalation... restore to Plex 0.9.11.4 but but not work anyway... Maybe Windows was update to, I dont know...
Please help me.
I attach PlexConnect.log
Thanks hug... If I uninstall plex... I'm going to add all movies again ?
