Removed by Segran
Removed by Segran
I still have lost the fan art and the ATV3’s can’t show any movies, since they get stuck, and desperately need help.
I have re-installed El Capitan, Plex Media Server (even tried downgrading), PlexConnect and OpenPlex. Finally got CLT and pillow to install without hick-ups, now says PIL installed=True. PMS works fine from iPad, web and ATV4.
The problem seem to be that PMS refuse to connect to PlexConnect/PlexAPI. I can’t figure out why, PLEASE HELP!
Here is a section of the log:
15:34:00 PlexAPI: MyPlex Sign In successfull
15:34:00 PlexAPI: ***
15:34:00 PlexAPI: poke plex.tv - request Plex Media Server list
15:34:02 PlexAPI: No Response from Plex Media Server
15:34:02 PlexAPI: We failed to reach a server. Reason: [Errno 61] Connection refused
15:34:02 PlexAPI: Traceback:
Traceback (most recent call last):
File “/Applications/PlexConnect/PlexAPI.py”, line 406, in getXMLFromPMS
response = urllib2.urlopen(request, timeout=20)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 431, in open
response = self._open(req, data)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 449, in _open
‘_open’, req)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 409, in _call_chain
result = func(*args)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 1240, in https_open
context=self._context)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 1197, in do_open
raise URLError(err)
URLError: <urlopen error [Errno 61] Connection refused>
Found it… Turned off WiFi so the Mac only have one IP-adress…
Don’t understand why this suddenly become a problem, I have had both Ethernet and WiFi activated since day one…
I sure hope Plex will be fixed so that this will work again soon…
