Plex Media Servers found: 0
Been running PlexConnect 0.7.4 on 2 ATV3 since fall 2021, no issues. Post Power Bump on Plexconnect server, now no libraries found by ATVs. Also logout just spins.
Error from Plexconnect.log (High) (snip):
Jul 03,2022 11:10:45 WebServer: serving .xml: /
Jul 03,2022 11:10:45 XMLConverter: ---------------------------------------------
Jul 03,2022 11:10:45 XMLConverter: PMS, path: /
Jul 03,2022 11:10:45 XMLConverter: Initial Command: Discover
Jul 03,2022 11:10:45 ATVSettings: getsetting v9yNxNrEs74c5kmk6tyu
Jul 03,2022 11:10:45 ATVSettings: getsetting False
Jul 03,2022 11:10:45 PlexAPI: ***
Jul 03,2022 11:10:45 PlexAPI: poke plex.tv - request Plex Media Server list
Jul 03,2022 11:10:45 PlexAPI: URL: https://plex.tv/api/resources?includeHttps=1
Jul 03,2022 11:10:45 PlexAPI: xargs: {‘X-Plex-Token’: ‘v9yNxNrEs74c5kmk6tyu’, ‘X-Plex-Client-Profile-Extra’: ‘add-transcode-target(type=MusicProfile&context=streaming&protocol=hls&container=mpegts&audioCodec=aac)+add-transcode-target(type=videoProfile&context=streaming&protocol=hls&container=mpegts&videoCodec=h264&audioCodec=aac,mp3&replace=true)’, ‘X-Plex-Platform’: ‘iOS’, ‘X-Plex-Model’: ‘2,3’, ‘X-Plex-Client-Platform’: ‘iOS’, ‘X-Plex-Device’: ‘AppleTV’, ‘X-Plex-Product’: ‘PlexConnect’, ‘X-Plex-Version’: ‘0.7.4-210621’}
Jul 03,2022 11:10:45 PlexAPI: No Response from Plex Media Server
Jul 03,2022 11:10:45 PlexAPI: We failed to reach a server. Reason: Unauthorized
Jul 03,2022 11:10:45 PlexAPI: Traceback:
Traceback (most recent call last):
File “/Applications/PlexConnect/PlexAPI.py”, line 452, in getXMLFromPMS
response = urllib2.urlopen(request, timeout=20)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 435, in open
response = meth(req, response)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 548, in http_response
‘http’, request, response, code, msg, hdrs)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 473, in error
return self._call_chain(*args)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 407, in _call_chain
result = func(*args)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 556, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 401: Unauthorized
Jul 03,2022 11:10:45 PlexAPI: Plex Media Servers found: 0
Jul 03,2022 11:10:45 PlexAPI: {‘name’: ‘plex.tv’, ‘accesstoken’: ‘v9yNxNrEs74c5kmk6tyu’, ‘address’: ‘plex.tv:443’, ‘enableGzip’: False, ‘ip’: ‘plex.tv’, ‘scheme’: ‘https’, ‘local’: ‘-’, ‘port’: ‘443’, ‘owned’: ‘-’, ‘baseURL’: ‘https://plex.tv:443’}
Jul 03,2022 11:10:45 XMLConverter: disable fanart (PIL not installed or aTVFirmwareVersion<6.0)
Jul 03,2022 11:10:45 Settings: getsetting allow_gzip_atv=False
Jul 03,2022 11:10:45 WebServer: http request header:
Host: trailers.apple.com
