Let’s do the following:
- Stop PMS
- Start PMS
- Post
Plex Media Server.logapprox one minute after
I suspect that you are using something that creates another ip address in your PC (such as a VPN or a VM) and PMS is using that other ip.
Plex Media Server.log approx one minute afterI suspect that you are using something that creates another ip address in your PC (such as a VPN or a VM) and PMS is using that other ip.
I’m sorry but I’m not sure where the plex media server log is kept; I’m looking in the plex folder (not plexconnect), but the files I can find that seem relevant are the pled media server.dll files…
I have my ip set as static if that changes anything. In the past I have used a VPN, but then plex will work but netflix/amazon apps etc. all fail to connect. Under the current circumstances, netflix and other apps continue to work but plexconnect does not (VPN is off). I do not run a VM as far as I know…
Thank you. After restarting PMS:
Plex is saying my server is unreachable/currently unavailable (both app and webapp).
@solipsik This is probably because your PMS is not in a claimed status. I’m not sure I can help you (I’m not a specialist on PMS in Windows), but in order to solve that problem, in general:
Feel free to open a separate topic here to request help for PMS on WIndows. I can´t transfer this thread because another user stepped in and his problem seems to be PlexConnect only.
OK server claimed (thanks). Here is the log after stopping and starting PMS (username and email changed out):
Part 1:
Oct username3, 2020 07:username8:42.username06 [username9username84] INFO - Plex Media Server vusername.20.2.3402-0fecusername4d92 - Microsoft PC x64 - build: windows-x86 windows - GMT -07:00
Oct username3, 2020 07:username8:42.username06 [username9username84] INFO - Windows version: username0.0 (Build username8363), language en-US
Oct username3, 2020 07:username8:42.username06 [username9username84] INFO - 24 3800 MHz processor(s): Architecture=0, Level=23, Revision=28928 Processor Identifier=AMD64 Family 23 Model usernameusername3 Stepping 0, AuthenticAMD
Oct username3, 2020 07:username8:42.username06 [username9username84] DEBUG - "C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Server.exe"
Oct username3, 2020 07:username8:42.usernameusername8 [6username68] DEBUG - Plex for Windows Store application is not installed
Oct username3, 2020 07:username8:42.username20 [6username68] DEBUG - BPQ: [Idle] -> [Starting]
Oct username3, 2020 07:username8:42.username2username [6username68] DEBUG - FeatureManager: Using cached data for features list
Oct username3, 2020 07:username8:42.username2username [6username68] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.26.0, threadsafe=username
Oct username3, 2020 07:username8:42.username52 [6username68] DEBUG - Running migrations. (EPG 0)
Oct username3, 2020 07:username8:42.username67 [6username68] DEBUG - ChangestampAllocator: initialized to usernameusername52896
Oct username3, 2020 07:username8:42.username67 [6username68] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.26.0, threadsafe=username
Oct username3, 2020 07:username8:42.username7username [6username68] DEBUG - Running migrations. (EPG 0)
Oct username3, 2020 07:username8:42.username89 [6username68] DEBUG - [CERT] Installed certificate with fingerprint 35:ba:6a:99:84:70:8e:98:e8:70:f5:username7:c0:a5:34:0d:fb:usernameusername:c8:74.
Oct username3, 2020 07:username8:42.username89 [6username68] DEBUG - [CERT] Installed new private key.
Oct username3, 2020 07:username8:42.username89 [6username68] DEBUG - [CERT] Subject name is /C=US/ST=California/L=Los Gatos/O=Plex, Inc./CN=*.ed4db33de9fc4a38a6fb5usernameeusernameusernameecedb54.plex.direct
Oct username3, 2020 07:username8:42.username90 [6username68] DEBUG - [CERT/OCSP] Stapling requests will be made to 'http://ocsp.digicert.com/'.
Oct username3, 2020 07:username8:42.username90 [6username68] INFO - [CERT/OCSP] Successfully retrieved response from cache.
Oct username3, 2020 07:username8:42.username90 [6username68] DEBUG - [CERT] Installed intermediate certificate.
Oct username3, 2020 07:username8:42.username90 [6username68] DEBUG - HttpServer: Listening on port 32400.
Oct username3, 2020 07:username8:42.username90 [6username68] DEBUG - HttpServer: Listening on port 3240username.
Oct username3, 2020 07:username8:42.236 [username9356] DEBUG - Grabber: Cleaning up orphaned grabs.
Oct username3, 2020 07:username8:42.237 [6username68] DEBUG - Media Provider: Registering provider com.plexapp.plugins.library
Oct username3, 2020 07:username8:42.237 [6username68] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Oct username3, 2020 07:username8:42.237 [6username68] DEBUG - MyPlex: mapping state set to 'Unknown'.
Oct username3, 2020 07:username8:42.237 [username9356] DEBUG - Grabber: Cleaned up 0 decrepit directories in 0.username sec.
Oct username3, 2020 07:username8:42.237 [6username68] DEBUG - Relay: read 0 cached entries from hosts file
Oct username3, 2020 07:username8:42.237 [username8username24] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:42.237 [6username68] DEBUG - MyPlex: using cached data for request for https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:42.237 [6username68] DEBUG - MyPlex: updating with 8 access tokens
Oct username3, 2020 07:username8:42.238 [6username68] DEBUG - MyPlex: using cached data for request for https://plex.tv/api/v2/server/users?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:42.238 [0904] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Oct username3, 2020 07:username8:42.238 [0904] DEBUG - HTTP requesting GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:42.238 [6username68] DEBUG - Opening username database sessions to library (), SQLite 3.26.0, threadsafe=username
Oct username3, 2020 07:username8:42.239 [4628] DEBUG - File "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92" changed: -username => 2020-username0-usernameusername username5:33:47 (username602455627).
Oct username3, 2020 07:username8:42.239 [4628] DEBUG - File "C:\Users\Username\AppData\Local\Plex Media Server\Plug-ins" changed: -username => 2020-03-03 username5:30:05 (username583278205).
Oct username3, 2020 07:username8:42.239 [4628] DEBUG - Scanning for plug-ins in "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92"
Oct username3, 2020 07:username8:42.243 [4628] DEBUG - Scanning for plug-ins in "C:\Users\Username\AppData\Local\Plex Media Server\Plug-ins"
Oct username3, 2020 07:username8:42.243 [4628] DEBUG - PluginRepository::setStartState: username, startingSystem
Oct username3, 2020 07:username8:42.243 [4628] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\System.bundle.
Oct username3, 2020 07:username8:42.243 [4628] DEBUG - [com.plexapp.system] Setting plug-in to always running (daemon mode).
Oct username3, 2020 07:username8:42.244 [4628] DEBUG - Starting file watcher for com.plexapp.system
Oct username3, 2020 07:username8:42.244 [4628] DEBUG - Plugin::createProcess: Creating plugin process: "C:\Program Files (x86)\Plex\Plex Media Server\PlexScriptHost.exe" "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\Framework.bundle\Contents\Resources\Versions\2\Python\bootstrap.py" "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\System.bundle"
Oct username3, 2020 07:username8:42.247 [4628] DEBUG - Spawned plug-in com.plexapp.system with PID username7904
Oct username3, 2020 07:username8:42.247 [4628] DEBUG - [com.plexapp.system] Sending command: GET /:/prefixes
Oct username3, 2020 07:username8:42.993 [username8username24] DEBUG - HTTP 200 response from GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:42.993 [username9356] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:43.022 [0904] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:43.023 [0904] DEBUG - MyPlex: updating with 8 access tokens
Oct username3, 2020 07:username8:43.023 [0904] DEBUG - HTTP requesting GET https://plex.tv/api/v2/server/users?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:43.502 [4628] DEBUG - Reading 486 bytes in the body, code is 200
Oct username3, 2020 07:username8:43.502 [4628] DEBUG - [com.plexapp.system] Plug-in running on port 55395.
Oct username3, 2020 07:username8:43.502 [4628] DEBUG - * Plug-in handles prefix: /system
Oct username3, 2020 07:username8:43.502 [4628] DEBUG - * Plug-in handles prefix: /player
Oct username3, 2020 07:username8:43.502 [4628] DEBUG - Read configuration for [com.plexapp.system], had 2 prefixes
Oct username3, 2020 07:username8:43.503 [4628] DEBUG - Done with username synchronous plug-in starts, starting the rest in parallel.
Oct username3, 2020 07:username8:43.503 [4628] DEBUG - PluginRepository::setStartState: 2, startingPlugins
Oct username3, 2020 07:username8:43.503 [4628] DEBUG - Updating the list of agents known by the system.
Oct username3, 2020 07:username8:43.503 [4628] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/agents
Oct username3, 2020 07:username8:43.503 [4628] DEBUG - HTTP requesting GET http://username27.0.0.username:55395/system/agents
Oct username3, 2020 07:username8:43.504 [6username68] DEBUG - Image transcode cache directory: "C:\Users\Username\AppData\Local\Plex Media Server\Cache\PhotoTranscoder"
Oct username3, 2020 07:username8:43.504 [6username68] DEBUG - Transcoder: Cleaning old transcode directories.
Oct username3, 2020 07:username8:43.505 [6username68] DEBUG - MyPlex: using cached data for request for https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:43.505 [6username68] DEBUG - MyPlex: updating with 8 access tokens
Oct username3, 2020 07:username8:43.505 [6username68] DEBUG - MyPlex: using cached data for request for https://plex.tv/api/v2/server/users?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:43.506 [6username68] DEBUG - MyPlex: using cached data for request for https://plex.tv/api/v2/user?includeSubscriptions=username&includeProviders=username
Oct username3, 2020 07:username8:43.506 [6username68] DEBUG - MyPlex: username is username1@gmail.com, login is username1@gmail.com, home is 0, no pin
Oct username3, 2020 07:username8:43.506 [6username68] DEBUG - MyPlex: stop public ip check and mapping - current mapped state: 'Unknown'.
Oct username3, 2020 07:username8:43.506 [6username68] DEBUG - NetworkInterface: Notified of network changed (force=0)
Oct username3, 2020 07:username8:43.506 [username7936] DEBUG - HTTP requesting GET https://plex.tv/api/v2/user?includeSubscriptions=username&includeProviders=username
Oct username3, 2020 07:username8:43.509 [6username68] DEBUG - NetworkInterface: ignoring adapter 'NordLynx' (fe80::8df6:2969:45f4:3946%9,username69.254.57.70) because it has no gateway
Oct username3, 2020 07:username8:43.509 [6username68] DEBUG - NetworkInterface: ignoring adapter 'Ethernet 2' (fe80::ddbusername:4805:2402:423a%2,username69.254.66.58) because it has no gateway
Oct username3, 2020 07:username8:43.5usernameusername [6username68] DEBUG - NetworkInterface: ignoring adapter 'Loopback Pseudo-Interface username' (::username,username27.0.0.username) because it has no gateway
Oct username3, 2020 07:username8:43.5username2 [6username68] DEBUG - Detected primary interface: username0.0.username.username7
Oct username3, 2020 07:username8:43.5username2 [6username68] DEBUG - Network interfaces:
Oct username3, 2020 07:username8:43.5username2 [6username68] DEBUG - * username4 Ethernet {CD4F4D48-usernameB73-49E9-9379-C602B829B700} (username0.0.username.username7) (loopback: 0)
Oct username3, 2020 07:username8:43.5username2 [6username68] DEBUG - Creating NetworkServices singleton.
Oct username3, 2020 07:username8:43.5username2 [6username68] DEBUG - NetworkServices: Initializing...
Oct username3, 2020 07:username8:43.5username2 [6username68] DEBUG - NetworkService: Creating new service.
Oct username3, 2020 07:username8:43.5username2 [6username68] DEBUG - NetworkService: Got notification of changed network (first change: username)
Oct username3, 2020 07:username8:43.5username2 [6username68] DEBUG - NetworkService: Quick dispatch of network change.
Oct username3, 2020 07:username8:43.5username2 [username6username36] DEBUG - Network change for advertiser.
Oct username3, 2020 07:username8:43.5username2 [username6username36] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:324username4
Oct username3, 2020 07:username8:43.5username2 [username6username36] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:324username0
Oct username3, 2020 07:username8:43.5username2 [username6username36] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:324username2
Oct username3, 2020 07:username8:43.5username2 [username6username36] DEBUG - NetworkService: Network change for browser (polled=0), closing 0 browse sockets.
Oct username3, 2020 07:username8:43.5username2 [username6username36] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:324username3
Oct username3, 2020 07:username8:43.5username2 [username6username36] DEBUG - NetworkService: Browsing on interface username0.0.username.username7 on broadcast address username0.0.username.255 (index: 0)
Oct username3, 2020 07:username8:43.5username3 [username6username36] DEBUG - NetworkService: Network change for browser (polled=username), closing 0 browse sockets.
Oct username3, 2020 07:username8:43.5username3 [username6username36] DEBUG - NetworkService: Browsing on interface username0.0.username.username7 on broadcast address username0.0.username.255 (index: 0)
Oct username3, 2020 07:username8:43.5username3 [username6username36] DEBUG - NetworkService: Network change for browser (polled=0), closing 0 browse sockets.
Oct username3, 2020 07:username8:43.5username3 [username6username36] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:username90username
Oct username3, 2020 07:username8:43.5username3 [username6username36] DEBUG - NetworkService: Browsing on interface username0.0.username.username7 on broadcast address 239.255.255.250 (index: 0)
Oct username3, 2020 07:username8:43.5username3 [6username68] DEBUG - Starting HTTP server.
Oct username3, 2020 07:username8:43.5username3 [6username68] DEBUG - Running server...
Oct username3, 2020 07:username8:43.5username3 [6username68] DEBUG - Waiting for server condition to be signaled.
Oct username3, 2020 07:username8:43.5username3 [username4780] DEBUG - Plex Tuner Service.exe starting.
Oct username3, 2020 07:username8:43.5username3 [username4780] DEBUG - Job running: C:\Program Files (x86)\Plex\Plex Media Server\Plex Tuner Service.exe "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private" "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Shared" username.20.2.3402-0fecusername4d92 32600 /waitmutex
Oct username3, 2020 07:username8:43.5username3 [username6444] DEBUG - HttpServer: Set up a thread pool with 2 threads.
Oct username3, 2020 07:username8:43.5username3 [username6444] DEBUG - HTTP requesting GET https://plex.tv/api/v2/user/privacy?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:43.5username4 [username8644] ERROR - Error parsing allowedNetworks '': An invalid argument was supplied
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Request: [username27.0.0.username:55385 (Loopback)] GET / (5 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:43.5username4 [5880] DEBUG - Request: [username27.0.0.username:55386 (Loopback)] GET /:/plugins/com.plexapp.system/messaging/function/X0JusernamebmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_ (5 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale af
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale ar
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale cs_CZ
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale da
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale de
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale en
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale es
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale et_EE
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale fi
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale fr
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale he
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale hr_HR
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale hu
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale hu_HU
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale it
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale ja_JP
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale ko
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale lt
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale nl
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale nl_BE
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale no
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale pl
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale pt
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale pt_BR
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale ro
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale ru
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale sr
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale sv
Oct username3, 2020 07:username8:43.5username4 [username7username32] DEBUG - Translator: Found locale zh_CN
Oct username3, 2020 07:username8:43.5username4 [username4848] DEBUG - Request: [username27.0.0.username:55394 (Loopback)] GET /servers (5 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:43.5username4 [username9444] DEBUG - Request: [username27.0.0.username:55393 (Loopback)] GET / (5 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:43.5username6 [username4780] DEBUG - Jobs: Starting child process with pid username9096
Oct username3, 2020 07:username8:43.522 [5880] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /:/plugins/com.plexapp.system/messaging/function/X0JusernamebmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
Oct username3, 2020 07:username8:43.523 [5880] DEBUG - HTTP requesting GET http://username27.0.0.username:55395/:/plugins/com.plexapp.system/messaging/function/X0JusernamebmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
Oct username3, 2020 07:username8:43.523 [3720] DEBUG - Completed: [username27.0.0.username:55394] 200 GET /servers (5 live) GZIP 8ms 487 bytes
Oct username3, 2020 07:username8:43.523 [3720] DEBUG - Completed: [username27.0.0.username:55385] 200 GET / (4 live) GZIP 9ms 273username bytes
Oct username3, 2020 07:username8:43.523 [username8644] DEBUG - Completed: [username27.0.0.username:55393] 200 GET / (4 live) GZIP 9ms 273username bytes
Oct username3, 2020 07:username8:43.534 [username9444] DEBUG - Request: [username27.0.0.username:554username0 (Loopback)] GET / (3 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:43.535 [3720] DEBUG - Completed: [username27.0.0.username:554username0] 200 GET / (3 live) GZIP 0ms 273username bytes
Oct username3, 2020 07:username8:43.537 [username9444] DEBUG - Request: [username27.0.0.username:554usernameusername (Loopback)] GET /library/sections (3 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:43.538 [3720] DEBUG - Completed: [username27.0.0.username:554usernameusername] 200 GET /library/sections (3 live) GZIP 0ms 960 bytes
Oct username3, 2020 07:username8:43.543 [username9444] DEBUG - Request: [username27.0.0.username:554username2 (Loopback)] GET /channels/all (3 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:43.543 [username8644] DEBUG - Completed: [username27.0.0.username:554username2] 200 GET /channels/all (3 live) GZIP 0ms 387 bytes
Oct username3, 2020 07:username8:43.586 [username9444] DEBUG - Request: [username27.0.0.username:554username4 (Loopback)] GET /library/sections (3 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:43.587 [3720] DEBUG - Completed: [username27.0.0.username:554username4] 200 GET /library/sections (3 live) GZIP 0ms 960 bytes
Oct username3, 2020 07:username8:43.59username [username9444] DEBUG - Request: [username27.0.0.username:554username5 (Loopback)] GET /channels/all (3 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:43.59username [3720] DEBUG - Completed: [username27.0.0.username:554username5] 200 GET /channels/all (3 live) GZIP 0ms 387 bytes
Oct username3, 2020 07:username8:43.626 [5880] DEBUG - HTTP 200 response from GET http://username27.0.0.username:55395/:/plugins/com.plexapp.system/messaging/function/X0JusernamebmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
Oct username3, 2020 07:username8:43.626 [5880] DEBUG - [com.plexapp.system] HTTP reply status 200, with 59978 bytes of content.
Oct username3, 2020 07:username8:43.626 [4628] DEBUG - HTTP 200 response from GET http://username27.0.0.username:55395/system/agents
Oct username3, 2020 07:username8:43.627 [4628] DEBUG - [com.plexapp.system] HTTP reply status 200, with usernameusernameusername35 bytes of content.
Oct username3, 2020 07:username8:43.627 [3720] DEBUG - Completed: [username27.0.0.username:55386] 200 GET /:/plugins/com.plexapp.system/messaging/function/X0JusernamebmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_ (2 live) GZIP usernameusername3ms username94username2 bytes
Oct username3, 2020 07:username8:43.628 [4628] DEBUG - The system knows about username5 agents.
Oct username3, 2020 07:username8:43.629 [username47username6] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\Fanart-TV.bundle.
Oct username3, 2020 07:username8:43.629 [4628] DEBUG - Waiting for 20 plug-ins to finish starting.
Oct username3, 2020 07:username8:43.629 [7292] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\Framework.bundle.
Oct username3, 2020 07:username8:43.629 [9092] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\HTbackdrops.bundle.
Oct username3, 2020 07:username8:43.629 [7292] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\LastFM.bundle.
Oct username3, 2020 07:username8:43.629 [9092] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.htbackdrops] yet.
Oct username3, 2020 07:username8:43.630 [username47username6] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.fanarttv] yet.
Oct username3, 2020 07:username8:43.630 [9092] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\LocalMedia.bundle.
Oct username3, 2020 07:username8:43.630 [username47username6] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\LyricFind.bundle.
Oct username3, 2020 07:username8:43.630 [7292] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.lastfm] yet.
Oct username3, 2020 07:username8:43.630 [7292] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\Media-Flags.bundle.
Oct username3, 2020 07:username8:43.630 [username47username6] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.lyricfind] yet.
Oct username3, 2020 07:username8:43.630 [7292] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\MoviePosterDB.bundle.
Oct username3, 2020 07:username8:43.630 [username47username6] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\Musicbrainz.bundle.
Oct username3, 2020 07:username8:43.63username [9092] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.localmedia] yet.
Oct username3, 2020 07:username8:43.63username [9092] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\OpenSubtitles.bundle.
Oct username3, 2020 07:username8:43.63username [7292] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.movieposterdb] yet.
Oct username3, 2020 07:username8:43.63username [7292] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\PersonalMedia.bundle.
Oct username3, 2020 07:username8:43.63username [username47username6] DEBUG - Perfect cache hit, we don't need to start [org.musicbrainz.agents.music] yet.
Oct username3, 2020 07:username8:43.63username [username47username6] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\PlexMovie.bundle.
Oct username3, 2020 07:username8:43.63username [9092] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.opensubtitles] yet.
Oct username3, 2020 07:username8:43.63username [9092] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\PlexMovieNew.bundle.
Oct username3, 2020 07:username8:43.632 [7292] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.none] yet.
Oct username3, 2020 07:username8:43.632 [7292] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\PlexMusic.bundle.
Oct username3, 2020 07:username8:43.632 [9092] DEBUG - Perfect cache hit, we don't need to start [tv.plex.agents.movie] yet.
Oct username3, 2020 07:username8:43.632 [9092] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\PlexThemeMusic.bundle.
Oct username3, 2020 07:username8:43.632 [username47username6] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.imdb] yet.
Oct username3, 2020 07:username8:43.632 [username47username6] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\Scanners.bundle.
Oct username3, 2020 07:username8:43.632 [username47username6] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\TheMovieDB.bundle.
Oct username3, 2020 07:username8:43.632 [7292] DEBUG - Perfect cache hit, we don't need to start [tv.plex.agents.music] yet.
Oct username3, 2020 07:username8:43.632 [7292] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\TheTVDB.bundle.
Oct username3, 2020 07:username8:43.632 [9092] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.plexthememusic] yet.
Oct username3, 2020 07:username8:43.632 [9092] DEBUG - Starting plug-in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\WebClient.bundle.
Oct username3, 2020 07:username8:43.633 [9092] DEBUG - Starting plug-in C:\Users\Username\AppData\Local\Plex Media Server\Plug-ins\Services.bundle.
Oct username3, 2020 07:username8:43.633 [7292] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.thetvdb] yet.
Oct username3, 2020 07:username8:43.633 [username47username6] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.themoviedb] yet.
Oct username3, 2020 07:username8:43.633 [4628] DEBUG - Starting scheduled updates, every 3600 seconds
Oct username3, 2020 07:username8:43.633 [4628] INFO - LibraryUpdateManager path watching is disabled
Oct username3, 2020 07:username8:43.633 [4628] DEBUG - Done waiting for all plug-ins to start.
Oct username3, 2020 07:username8:43.634 [4628] DEBUG - PluginRepository::setStartState: 3, complete
Oct username3, 2020 07:username8:43.634 [username5768] DEBUG - Downloading document http://username27.0.0.username:32400/:/plugins/com.plexapp.agents.imdb/prefs
Oct username3, 2020 07:username8:43.634 [username5768] DEBUG - Starting file watcher for com.plexapp.agents.imdb
Oct username3, 2020 07:username8:43.634 [username5768] DEBUG - Plugin::createProcess: Creating plugin process: "C:\Program Files (x86)\Plex\Plex Media Server\PlexScriptHost.exe" "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\Framework.bundle\Contents\Resources\Versions\2\Python\bootstrap.py" "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-0fecusername4d92\PlexMovie.bundle"
Oct username3, 2020 07:username8:43.635 [username5768] DEBUG - Spawned plug-in com.plexapp.agents.imdb with PID username0username28
Oct username3, 2020 07:username8:43.635 [username5768] DEBUG - [com.plexapp.agents.imdb] Sending command: GET /:/prefixes
Oct username3, 2020 07:username8:43.736 [username9356] DEBUG - HTTP 200 response from GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:43.736 [username7332] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:43.765 [0904] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/server/users?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:44.usernameusername6 [5320] DEBUG - Job running: C:\Program Files (x86)\Plex\Plex Media Server\CrashUploader.exe "--directory=C:\Users\Username\AppData\Local\Plex Media Server\Crash Reports\username.20.2.3402-0fecusername4d92" --version=username.20.2.3402-0fecusername4d92 --platform=Windows "--platformVersion=username0.0 (Build username8363)" --serverUuid=39aa7usernameda8b24fbe826a8usernamebb3cf7usernamec0fa69ae0b86 --userId=username1@gmail.com --sentryUrl=https://sentry.io/api/username233455/minidump --sentryKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx --vendor=Microsoft --model=x64 --device=PC --allowRetries=0
Oct username3, 2020 07:username8:44.usernameusername9 [5320] DEBUG - Jobs: Starting child process with pid usernameusername04
Oct username3, 2020 07:username8:44.username44 [username7876] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\CrashUploader.exe' exit code for process usernameusername04 is 0 (success)
Oct username3, 2020 07:username8:44.username74 [5880] DEBUG - Request: [username27.0.0.username:5542username (Loopback)] GET /system/messaging/clear_events/com.plexapp.agents.imdb (2 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:44.username74 [5880] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/messaging/clear_events/com.plexapp.agents.imdb
Oct username3, 2020 07:username8:44.username74 [5880] DEBUG - HTTP requesting GET http://username27.0.0.username:55395/system/messaging/clear_events/com.plexapp.agents.imdb
Oct username3, 2020 07:username8:44.username96 [5880] DEBUG - HTTP 200 response from GET http://username27.0.0.username:55395/system/messaging/clear_events/com.plexapp.agents.imdb
Oct username3, 2020 07:username8:44.username96 [5880] DEBUG - [com.plexapp.system]
Part 2:
HTTP reply status 200, with 0 bytes of content.
Oct username3, 2020 07:username8:44.username96 [3720] DEBUG - Completed: [username27.0.0.username:5542username] 200 GET /system/messaging/clear_events/com.plexapp.agents.imdb (2 live) GZIP 22ms 280 bytes
Oct username3, 2020 07:username8:44.227 [username6444] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/user/privacy?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:44.229 [username6444] DEBUG - HTTP requesting GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:44.242 [5880] DEBUG - Request: [username27.0.0.username:55429 (Loopback)] GET /:/plugins/com.plexapp.system/resourceHashes (2 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:44.242 [5880] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /:/plugins/com.plexapp.system/resourceHashes
Oct username3, 2020 07:username8:44.242 [5880] DEBUG - HTTP requesting GET http://username27.0.0.username:55395/:/plugins/com.plexapp.system/resourceHashes
Oct username3, 2020 07:username8:44.300 [username7936] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/user?includeSubscriptions=username&includeProviders=username
Oct username3, 2020 07:username8:44.30username [username7936] DEBUG - MyPlex: username is username1@gmail.com, login is username1@gmail.com, home is 0, no pin
Oct username3, 2020 07:username8:44.30username [username7936] DEBUG - HTTP requesting GET https://plex.tv/api/v2/geoip
Oct username3, 2020 07:username8:44.356 [5880] DEBUG - HTTP 200 response from GET http://username27.0.0.username:55395/:/plugins/com.plexapp.system/resourceHashes
Oct username3, 2020 07:username8:44.356 [5880] DEBUG - [com.plexapp.system] HTTP reply status 200, with username3276 bytes of content.
Oct username3, 2020 07:username8:44.356 [3720] DEBUG - Completed: [username27.0.0.username:55429] 200 GET /:/plugins/com.plexapp.system/resourceHashes (2 live) GZIP usernameusername3ms 3448 bytes
Oct username3, 2020 07:username8:44.365 [5880] DEBUG - Request: [username27.0.0.username:55438 (Loopback)] GET /:/plugins/com.plexapp.system/messaging/function/X0JusernamebmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_ (2 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:44.365 [5880] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /:/plugins/com.plexapp.system/messaging/function/X0JusernamebmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
Oct username3, 2020 07:username8:44.365 [5880] DEBUG - HTTP requesting GET http://username27.0.0.username:55395/:/plugins/com.plexapp.system/messaging/function/X0JusernamebmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
Oct username3, 2020 07:username8:44.366 [username9444] DEBUG - Request: [username27.0.0.username:5544username (Loopback)] GET / (3 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:44.366 [3720] DEBUG - Completed: [username27.0.0.username:5544username] 200 GET / (3 live) GZIP 0ms 2720 bytes
Oct username3, 2020 07:username8:44.378 [5880] DEBUG - HTTP 200 response from GET http://username27.0.0.username:55395/:/plugins/com.plexapp.system/messaging/function/X0JusernamebmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
Oct username3, 2020 07:username8:44.378 [5880] DEBUG - [com.plexapp.system] HTTP reply status 200, with 59978 bytes of content.
Oct username3, 2020 07:username8:44.380 [3720] DEBUG - Completed: [username27.0.0.username:55438] 200 GET /:/plugins/com.plexapp.system/messaging/function/X0JusernamebmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_ (2 live) GZIP username4ms username94username2 bytes
Oct username3, 2020 07:username8:44.45username [username7332] DEBUG - HTTP 200 response from GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:44.45username [5320] DEBUG - HTTP requesting GET https://vod.provider.plex.tv
Oct username3, 2020 07:username8:44.45username [username0432] DEBUG - HTTP requesting GET https://music.provider.plex.tv
Oct username3, 2020 07:username8:44.608 [5320] DEBUG - HTTP 200 response from GET https://vod.provider.plex.tv
Oct username3, 2020 07:username8:44.6username6 [username7332] DEBUG - HTTP requesting GET https://music.provider.plex.tv
Oct username3, 2020 07:username8:44.624 [username0432] DEBUG - HTTP 200 response from GET https://music.provider.plex.tv
Oct username3, 2020 07:username8:44.7username9 [username7332] DEBUG - HTTP 200 response from GET https://music.provider.plex.tv
Oct username3, 2020 07:username8:44.803 [username7username32] DEBUG - Request: [username27.0.0.username:55466 (Loopback)] GET /:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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_ (2 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:44.803 [username7username32] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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_
Oct username3, 2020 07:username8:44.803 [username7username32] DEBUG - HTTP requesting GET http://username27.0.0.username:55395/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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_
Oct username3, 2020 07:username8:44.807 [username7username32] DEBUG - HTTP 200 response from GET http://username27.0.0.username:55395/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQo3CmRpY3QKbGlzdApkaWN0Cmxpc3QKbGlzdApsaXN0Cmxpc3QKMgpzMjMKY29tLnBsZXhhcHAuYWdlbnRzLmltZGJzMTAKaWRlbnRpZmllcnIxCnMxMAphZ2VudF9pbmZvMQpyMgoxMApyMwpzMTEKbWVkaWFfdHlwZXNyNApzMTIKYWNjZXB0cusername9mcm9tbnMxNApmYWxsYmFjausername9hZ2VudHIusernameCnMxNApjb250cmlidXRlcusername90b3I2CnM5CmxhbmdusernameYWdlc2IxczIwCnBlcnNpc3Rfc3RvcmVkX2ZpbGVzaTAKczcKdmVyc2lvbmIxczE2CnByaWusernamehcnlfcHJvdmlkZXJiMXMusernameCnByZWZzczEwClBsZXggTW92aWVzNApuYWusernamelMQpzNQpNb3ZpZTEKczI5CmNvbS5wbGV4YXBwLmFnZW50cy5sb2NhbGusernamelZGlhMQpzMjkKY29tLnBsZXhhcHAuYWdlbnRzLnRoZWusernamevdmllZGIzMwpzMgplbnMyCnN2czIKZnJzMgplc3MyCm5sczIKZGVzMgppdHMyCmRhczIKYXJzMgpjYXMyCnpoczIKY3NzMgpldHMyCmZpczIKZWxzMgpoZXMyCmhpczIKaHVzMgppZHMyCmphczIKa29zMgpsdnMyCm5vczIKZmFzMgpwbHMyCnB0czIKcm9zMgpydXMyCnNrczIKdGhzMgp0cnMyCnVrczIKdmlyMAo_
Oct username3, 2020 07:username8:44.807 [username7username32] DEBUG - [com.plexapp.system] HTTP reply status 200, with username6 bytes of content.
Oct username3, 2020 07:username8:44.807 [3720] DEBUG - Completed: [username27.0.0.username:55466] 200 GET /:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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_ (2 live) GZIP 4ms 4username5 bytes
Oct username3, 2020 07:username8:44.8username7 [username5768] DEBUG - Reading username48 bytes in the body, code is 200
Oct username3, 2020 07:username8:44.8username8 [username5768] DEBUG - [com.plexapp.agents.imdb] Plug-in running on port 55470.
Oct username3, 2020 07:username8:44.8username8 [username5768] DEBUG - Read configuration for [com.plexapp.agents.imdb], had 0 prefixes
Oct username3, 2020 07:username8:44.8username8 [username5768] DEBUG - [com.plexapp.agents.imdb] Sending command over HTTP (GET): /:/plugins/com.plexapp.agents.imdb/prefs
Oct username3, 2020 07:username8:44.8username8 [username5768] DEBUG - HTTP requesting GET http://username27.0.0.username:55470/:/plugins/com.plexapp.agents.imdb/prefs
Oct username3, 2020 07:username8:44.839 [username5768] DEBUG - HTTP 200 response from GET http://username27.0.0.username:55470/:/plugins/com.plexapp.agents.imdb/prefs
Oct username3, 2020 07:username8:44.839 [username5768] DEBUG - [com.plexapp.agents.imdb] HTTP reply status 200, with 2224 bytes of content.
Oct username3, 2020 07:username8:44.840 [username5768] DEBUG - Caching document http://username27.0.0.username:32400/:/plugins/com.plexapp.agents.imdb/prefs as e8524296b954feea8c6fa3cusernameadf9f0c2ee43f3ed
Oct username3, 2020 07:username8:44.840 [username5768] DEBUG - IVA: Downloading trailer lists.
Oct username3, 2020 07:username8:44.928 [username6444] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:44.929 [username6444] DEBUG - HTTP requesting GET https://plex.tv/api/v2/features?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:45.004 [username7936] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/geoip
Oct username3, 2020 07:username8:45.004 [username7936] DEBUG - HTTP requesting GET https://plex.tv/api/v2/user/privacy?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:45.004 [username5768] DEBUG - IVA: Downloaded 50 trailers for source username.
Oct username3, 2020 07:username8:45.username0username [username5768] DEBUG - IVA: Downloaded 0 trailers for source 2.
Oct username3, 2020 07:username8:45.7username6 [username6444] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/features?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:45.7username7 [username6444] DEBUG - Running database fix-ups.
Oct username3, 2020 07:username8:45.725 [username7936] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/user/privacy?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:45.727 [username7936] DEBUG - HTTP requesting GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:45.73username [username6444] DEBUG - Database Fixups: Destroyed 0 transient items.
Oct username3, 2020 07:username8:45.73username [username6444] DEBUG - Collections: Found 0 collections tags in section 3.
Oct username3, 2020 07:username8:45.73username [username6444] DEBUG - Collections: We had 0 collections in the library already.
Oct username3, 2020 07:username8:45.73username [username6444] DEBUG - Collections: Synced tags in section 3 in 0ms.
Oct username3, 2020 07:username8:45.732 [username6444] DEBUG - Collections: Refreshed attributes for 0 collections in section 3 in 0ms.
Oct username3, 2020 07:username8:45.732 [username6444] DEBUG - Collection: Refreshed visibility in section 3 in 0ms.
Oct username3, 2020 07:username8:45.733 [username6444] DEBUG - Collections: Found 0 collections tags in section 4.
Oct username3, 2020 07:username8:45.733 [username6444] DEBUG - Collections: We had 0 collections in the library already.
Oct username3, 2020 07:username8:45.733 [username6444] DEBUG - Collections: Synced tags in section 4 in 0ms.
Oct username3, 2020 07:username8:45.733 [username6444] DEBUG - Collections: Refreshed attributes for 0 collections in section 4 in 0ms.
Oct username3, 2020 07:username8:45.733 [username6444] DEBUG - Collection: Refreshed visibility in section 4 in 0ms.
Oct username3, 2020 07:username8:45.733 [username6444] DEBUG - Collections: Found 0 collections tags in section 5.
Oct username3, 2020 07:username8:45.733 [username6444] DEBUG - Collections: Synced tags in section 5 in 0ms.
Oct username3, 2020 07:username8:45.733 [username6444] DEBUG - Collections: Refreshed attributes for 0 collections in section 5 in 0ms.
Oct username3, 2020 07:username8:45.734 [username6444] DEBUG - Collection: Refreshed visibility in section 5 in 0ms.
Oct username3, 2020 07:username8:45.734 [username6444] DEBUG - Running database fix-ups completed in 0.0 seconds.
Oct username3, 2020 07:username8:45.734 [username7332] DEBUG - DVR: Starting up.
Oct username3, 2020 07:username8:45.734 [username7332] DEBUG - Activity: registered new activity 84bbusername2fd-096b-434e-aae0-7a76b0bd27db - Processing subscriptions
Oct username3, 2020 07:username8:45.734 [8username56] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:46.396 [username7936] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:46.397 [username7936] DEBUG - HTTP requesting GET https://plex.tv/api/v2/features?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:46.5username0 [8username56] DEBUG - HTTP 200 response from GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:47.username22 [username7936] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/features?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:47.username24 [username7936] DEBUG - Sync: onMyPlexSignIn
Oct username3, 2020 07:username8:47.username24 [username7936] WARN - Sync: Couldn't get sync lists without subscription.
Oct username3, 2020 07:username8:47.username24 [username6940] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:47.username24 [username7936] DEBUG - EventSource: Resolving username84.username05.username48.82 port 443
Oct username3, 2020 07:username8:47.username24 [3720] DEBUG - EventSource: Resolved username84.username05.username48.82 to username84.username05.username48.82
Oct username3, 2020 07:username8:47.username24 [username4572] DEBUG - MyPlex: sendMapping resetting state - previous mapping state: 'Unknown'.
Oct username3, 2020 07:username8:47.username24 [username4572] DEBUG - MyPlex: mapping state set to 'Unknown'.
Oct username3, 2020 07:username8:47.username24 [username8username24] DEBUG - HTTP requesting GET https://plex.tv/api/v2/server/webhooks?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:47.username29 [username7936] DEBUG - MyPlex: Updating device connections (from timer: 0)
Oct username3, 2020 07:username8:47.username29 [username7936] DEBUG - HTTP requesting PUT https://plex.tv/devices/39aa7usernameda8b24fbe826a8usernamebb3cf7usernamec0fa69ae0b86?Connection[][uri]=http://username0.0.username.username7:32400&httpsEnabled=username&httpsRequired=0&dnsRebindingProtection=0&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:47.username30 [username4572] DEBUG - MyPlex: Sending Server Info to myPlex (user=username1@gmail.com, ip=, port=0)
Oct username3, 2020 07:username8:47.username30 [username4572] DEBUG - HTTP requesting POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:47.250 [3720] DEBUG - EventSource: Connected in 86 ms.
Oct username3, 2020 07:username8:47.25username [username8644] DEBUG - EventSource: Wrote data, reading reply.
Oct username3, 2020 07:username8:47.838 [username8644] DEBUG - EventSource: Read HTTP reply header.
Oct username3, 2020 07:username8:47.838 [username8644] DEBUG - MyPlex: We appear to have regained Internet connectivity.
Oct username3, 2020 07:username8:47.850 [username6940] DEBUG - HTTP 200 response from GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:47.863 [username7936] DEBUG - HTTP 200 response from PUT https://plex.tv/devices/39aa7usernameda8b24fbe826a8usernamebb3cf7usernamec0fa69ae0b86?Connection[][uri]=http://username0.0.username.username7:32400&httpsEnabled=username&httpsRequired=0&dnsRebindingProtection=0&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:47.864 [username7936] DEBUG - CERT: Certificate will not expire soon.
Oct username3, 2020 07:username8:47.897 [username4572] DEBUG - HTTP 422 response from POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:47.897 [username4572] DEBUG - MyPlex: Published Mapping State response was 422
Oct username3, 2020 07:username8:47.897 [username4572] DEBUG - MyPlex: Got response for 39aa7usernameda8b24fbe826a8usernamebb3cf7usernamec0fa69ae0b86 ~ registered :0
Oct username3, 2020 07:username8:47.897 [username4572] DEBUG - MyPlex: updating mapped state - current state: 'Unknown'
Oct username3, 2020 07:username8:47.897 [username4572] DEBUG - MyPlex: mapping state set to 'Mapped - Publishing'.
Oct username3, 2020 07:username8:47.897 [username4572] DEBUG - MyPlex: async reachability check - current mapped state: 'Mapped - Publishing'.
Oct username3, 2020 07:username8:47.897 [username4572] DEBUG - MyPlex: Requesting reachability check.
Oct username3, 2020 07:username8:47.898 [username4572] DEBUG - HTTP requesting PUT https://plex.tv/api/servers/39aa7usernameda8b24fbe826a8usernamebb3cf7usernamec0fa69ae0b86/connectivity?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&asyncIdentifier=89af5eusername9-d3f2-445c-b59f-f83442639945
Oct username3, 2020 07:username8:47.907 [username8username24] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/server/webhooks?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:48.5username2 [username6username36] DEBUG - NetworkServiceBrowser: SERVER arrived: username0.0.username.username7 (Phantom)
Oct username3, 2020 07:username8:48.5username2 [username6username36] DEBUG - Notifying the system bundle an update to server /system/notify/serverUpdated?host=username0.0.username.username7
Oct username3, 2020 07:username8:48.5username2 [username6username36] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/notify/serverUpdated?host=username0.0.username.username7
Oct username3, 2020 07:username8:48.5username3 [username6username36] DEBUG - HTTP requesting GET http://username27.0.0.username:55395/system/notify/serverUpdated?host=username0.0.username.username7
Oct username3, 2020 07:username8:48.5username6 [5880] DEBUG - Request: [username27.0.0.username:55526 (Loopback)] GET /servers (2 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:48.5username6 [3720] DEBUG - Completed: [username27.0.0.username:55526] 200 GET /servers (2 live) GZIP 0ms 487 bytes
Oct username3, 2020 07:username8:48.5username9 [5880] DEBUG - Request: [username27.0.0.username:55527 (Loopback)] GET /library/sections (2 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:48.5username9 [3720] DEBUG - Completed: [username27.0.0.username:55527] 200 GET /library/sections (2 live) GZIP 0ms 960 bytes
Oct username3, 2020 07:username8:48.52username [5880] DEBUG - Request: [username27.0.0.username:55528 (Loopback)] GET /channels/all (2 live) GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:username8:48.52username [3720] DEBUG - Completed: [username27.0.0.username:55528] 200 GET /channels/all (2 live) GZIP 0ms 387 bytes
Oct username3, 2020 07:username8:48.523 [username6username36] DEBUG - HTTP 200 response from GET http://username27.0.0.username:55395/system/notify/serverUpdated?host=username0.0.username.username7
Oct username3, 2020 07:username8:48.523 [username6username36] DEBUG - [com.plexapp.system] HTTP reply status 200, with 0 bytes of content.
Oct username3, 2020 07:username8:48.622 [username4572] DEBUG - HTTP 200 response from PUT https://plex.tv/api/servers/39aa7usernameda8b24fbe826a8usernamebb3cf7usernamec0fa69ae0b86/connectivity?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&asyncIdentifier=89af5eusername9-d3f2-445c-b59f-f83442639945
Oct username3, 2020 07:username8:48.622 [username8644] DEBUG - MyPlex: async reachability check - current mapped state: 'Mapped - Publishing'.
Oct username3, 2020 07:username8:48.622 [username8644] DEBUG - MyPlex: we already have requested a connectivity refresh for async identifier 89af5eusername9-d3f2-445c-b59f-f83442639945 which has not yet expired.
Oct username3, 2020 07:username8:48.622 [username8644] DEBUG - EventSource: Successfully connected to username84.username05.username48.82.
Oct username3, 2020 07:username8:48.807 [username8644] DEBUG - EventSource: Got event [data] '<Message address="" port="0" asyncIdentifier="89af5eusername9-d3f2-445c-b59f-f83442639945" connectivity="0" command="notifyConnectivity"/>'
Oct username3, 2020 07:username8:48.808 [username8644] DEBUG - PubSub: Got notified of reachability for async identifier 89af5eusername9-d3f2-445c-b59f-f83442639945: 0 for :0 (responded in username85 ms)
Oct username3, 2020 07:username8:48.808 [username8644] DEBUG - MyPlex: reachability check - current mapping state: 'Mapped - Publishing'.
Oct username3, 2020 07:username8:48.808 [username8644] DEBUG - MyPlex: mapping state set to 'Mapped - Not Published (Not Reachable)'.
Oct username3, 2020 07:username8:52.username24 [username6940] DEBUG - HTTP requesting GET https://plex.tv/services/pubsub/servers
Oct username3, 2020 07:username8:52.236 [username6456] DEBUG - DVR:Device: Discovering and refreshing all devices.
Oct username3, 2020 07:username8:52.237 [username6456] DEBUG - Grabber: HDHomerun discovered 0 compatible devices.
Oct username3, 2020 07:username8:52.237 [username6456] DEBUG - HTTP requesting POST http://username27.0.0.username:32600/devices/discover
Oct username3, 2020 07:username8:52.829 [username6940] DEBUG - HTTP 200 response from GET https://plex.tv/services/pubsub/servers
Oct username3, 2020 07:username8:53.52username [username6940] DEBUG - PubSubManager: Time to connect to username84.username05.username48.usernameusername2 was 86 ms.
Oct username3, 2020 07:username8:53.52username [username6940] DEBUG - PubSubManager: Time to connect to username84.username05.username48.82 was 86 ms.
Oct username3, 2020 07:username8:53.52username [username6940] DEBUG - PubSubManager: Time to connect to username72.username05.99.32 was username29 ms.
Oct username3, 2020 07:username8:53.52username [username6940] DEBUG - PubSubManager: Time to connect to username72.username04.2username8.username0username was username8username ms.
Oct username3, 2020 07:username8:53.52username [username6940] DEBUG - PubSubManager: Time to connect to 45.56.usernameusername6.228 was username88 ms.
Oct username3, 2020 07:username8:53.52username [username6940] DEBUG - PubSubManager: Time to connect to 72.username4.username79.64 was username9username ms.
Oct username3, 2020 07:username8:53.52username [username6940] DEBUG - PubSubManager: Time to connect to username39.username62.username20.52 was 234 ms.
Oct username3, 2020 07:username8:53.52username [username6940] DEBUG - PubSubManager: Time to connect to username39.username62.2username5.242 was 32username ms.
Oct username3, 2020 07:username8:53.52username [username6940] DEBUG - PubSubManager: Time to connect to 82.94.username68.25 was 326 ms.
Oct username3, 2020 07:username8:53.52username [username6940] DEBUG - PubSubManager: Time to connect to username72.username04.username52.89 was 342 ms.
Oct username3, 2020 07:username8:53.52username [username6940] DEBUG - PubSubManager: Time to connect to username39.username62.20.username20 was 463 ms.
Oct username3, 2020 07:username8:53.52username [username6940] DEBUG - PubSubManager: Updating best ping time for username84.username05.username48.82 to 86 ms.
Oct username3, 2020 07:username8:53.52username [username6940] DEBUG - EventSource: Stopping.
Oct username3, 2020 07:username8:53.522 [username6940] DEBUG - EventSource: Stopping.
Oct username3, 2020 07:username8:54.65username [username6456] DEBUG - HTTP 200 response from POST http://username27.0.0.username:32600/devices/discover
Oct username3, 2020 07:username8:55.734 [8username56] DEBUG - Grabber: Cleaning up orphaned grabs.
Oct username3, 2020 07:username8:55.735 [8username56] DEBUG - Grabber: Cleaned up 0 decrepit directories in 0.0 sec.
Oct username3, 2020 07:username8:55.735 [8username56] DEBUG - Activity: registered new activity f4083aac-ffusername4-452c-bfaf-f97fc0489d55 - Processing subscriptions
Oct username3, 2020 07:username8:55.735 [8username56] DEBUG - Subscription: Scheduling subscriptions.
Oct username3, 2020 07:username8:55.735 [8username56] DEBUG - Subscription: Initialized 0 schedulers.
Oct username3, 2020 07:username8:55.735 [8username56] DEBUG - Subscription: Starting with 0 grabs, scheduled 0 active ones preemptively.
Oct username3, 2020 07:username8:55.735 [8username56] DEBUG - Subscription: Scheduled all subscriptions in 0 ms.
Oct username3, 2020 07:username8:55.735 [8username56] DEBUG - Activity: Ended activity f4083aac-ffusername4-452c-bfaf-f97fc0489d55.
Oct username3, 2020 07:username8:55.735 [8username56] DEBUG - Subscription: There are 0 active grabs at the end.
Oct username3, 2020 07:username8:55.735 [8username56] DEBUG - Activity: Ended activity 84bbusername2fd-096b-434e-aae0-7a76b0bd27db.
Oct username3, 2020 07:username8:55.735 [8username56] DEBUG - Subscription: Refreshed all content in 0 ms.
Oct username3, 2020 07:username8:57.username24 [8username56] DEBUG - HTTP requesting GET https://plex.tv/api/resources.xml?includeHttps=username&includeRelay=username&auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:57.824 [8username56] DEBUG - HTTP 200 response from GET https://plex.tv/api/resources.xml?includeHttps=username&includeRelay=username&auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username8:57.825 [8username56] DEBUG - Media Server: Tested all servers in 0.0 seconds.
Oct username3, 2020 07:username9:username2.233 [username8username24] DEBUG - HTTP requesting GET https://plex.tv/api/v2/shared_sources/owned?machineIdentifier=39aa7usernameda8b24fbe826a8usernamebb3cf7usernamec0fa69ae0b86
Oct username3, 2020 07:username9:username2.950 [username8username24] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/shared_sources/owned?machineIdentifier=39aa7usernameda8b24fbe826a8usernamebb3cf7usernamec0fa69ae0b86
Oct username3, 2020 07:username9:username2.950 [username8username24] DEBUG - HTTP requesting GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username9:username3.675 [username8username24] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username9:username3.676 [username8username24] DEBUG - MyPlex: updating with 8 access tokens
Oct username3, 2020 07:username9:username3.676 [username8username24] DEBUG - HTTP requesting GET https://plex.tv/api/v2/server/users?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username9:username3.676 [username7332] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username9:username4.42username [username7332] DEBUG - HTTP 200 response from GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:username9:username4.43username [username8username24] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/server/users?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct username3, 2020 07:20:02.username45 [3720] DEBUG - Auth: authenticated user username as username1@gmail.com
Oct username3, 2020 07:20:02.username45 [5880] DEBUG - Request: [username0.0.username.username7:556username4 (Allowed Network (Subnet))] GET /media/providers (2 live) TLS GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:20:02.username48 [username8644] DEBUG - Completed: [username0.0.username.username7:556username4] 200 GET /media/providers (2 live) TLS GZIP 2ms 3username7username bytes (pipelined: username)
Oct username3, 2020 07:20:02.2username9 [3720] DEBUG - Auth: authenticated user username as username1@gmail.com
Oct username3, 2020 07:20:02.2username9 [5880] DEBUG - Request: [username0.0.username.username7:556username4 (Allowed Network (Subnet))] GET /updater/status (3 live) TLS GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:20:02.220 [3720] DEBUG - Completed: [username0.0.username.username7:556username4] 200 GET /updater/status (4 live) TLS GZIP 0ms 526 bytes (pipelined: 2)
Oct username3, 2020 07:20:02.224 [3720] DEBUG - Auth: authenticated user username as username1@gmail.com
Oct username3, 2020 07:20:02.224 [5880] DEBUG - Request: [username0.0.username.username7:556username6 (Allowed Network (Subnet))] GET /status/sessions (4 live) TLS GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:20:02.224 [5880] DEBUG - [Now] Adding 0 sessions.
Oct username3, 2020 07:20:02.224 [3720] DEBUG - Completed: [username0.0.username.username7:556username6] 200 GET /status/sessions (4 live) TLS GZIP 0ms 429 bytes (pipelined: username)
Oct username3, 2020 07:20:02.227 [3720] DEBUG - Auth: authenticated user username as username1@gmail.com
Oct username3, 2020 07:20:02.227 [5880] DEBUG - Request: [username0.0.username.username7:556username5 (Allowed Network (Subnet))] GET /:/websockets/notifications (4 live) TLS GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:20:02.228 [5880] DEBUG - WebSocket: Performing handshake from origin https://app.plex.tv
Oct username3, 2020 07:20:02.228 [5880] DEBUG - Beginning read from WebSocket
Oct username3, 2020 07:20:02.232 [username8644] DEBUG - Auth: authenticated user username as username1@gmail.com
Oct username3, 2020 07:20:02.233 [5880] DEBUG - Request: [username0.0.username.username7:556username4 (Allowed Network (Subnet))] GET /activities (4 live) TLS GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:20:02.233 [3720] DEBUG - Completed: [username0.0.username.username7:556username4] 200 GET /activities (4 live) TLS GZIP 0ms 429 bytes (pipelined: 3)
Oct username3, 2020 07:20:02.236 [3720] DEBUG - Auth: authenticated user username as username1@gmail.com
Oct username3, 2020 07:20:02.236 [5880] DEBUG - Request: [username0.0.username.username7:556username4 (Allowed Network (Subnet))] GET /:/prefs (4 live) TLS GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:20:02.237 [9484] DEBUG - Request: [username0.0.username.username7:556username6 (Allowed Network (Subnet))] OPTIONS /updater/check?download=0 (4 live) TLS GZIP Signed-in Token ()
Oct username3, 2020 07:20:02.238 [3720] DEBUG - Completed: [username0.0.username.username7:556username6] 200 OPTIONS /updater/check?download=0 (4 live) TLS GZIP 0ms 330 bytes (pipelined: 2)
Oct username3, 2020 07:20:02.239 [3720] DEBUG - Auth: authenticated user username as username1@gmail.com
Oct username3, 2020 07:20:02.239 [9484] DEBUG - Request: [username0.0.username.username7:556username6 (Allowed Network (Subnet))] PUT /updater/check?download=0 (4 live) TLS GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:20:02.239 [9484] DEBUG - AutoUpdate: requesting check endpoint: /updater/products/5/check.xml?build=windows-x86&channel=username6&distribution=windows&version=username.20.2.3402-0fecusername4d92, download: NO
Oct username3, 2020 07:20:02.239 [9484] DEBUG - Downloading document https://plex.tv/updater/products/5/check.xml?build=windows-x86&channel=username6&distribution=windows&version=username.20.2.3402-0fecusername4d92
Oct username3, 2020 07:20:02.239 [9484] DEBUG - HTTP requesting GET https://plex.tv/updater/products/5/check.xml?build=windows-x86&channel=username6&distribution=windows&version=username.20.2.3402-0fecusername4d92
Oct username3, 2020 07:20:02.244 [username8644] DEBUG - Completed: [username0.0.username.username7:556username4] 200 GET /:/prefs (4 live) TLS GZIP 8ms 7079 bytes (pipelined: 4)
Oct username3, 2020 07:20:02.930 [9484] DEBUG - HTTP 200 response from GET https://plex.tv/updater/products/5/check.xml?build=windows-x86&channel=username6&distribution=windows&version=username.20.2.3402-0fecusername4d92
Oct username3, 2020 07:20:02.930 [9484] INFO - AutoUpdate: no updates available
Oct username3, 2020 07:20:02.930 [3720] DEBUG - Completed: [username0.0.username.username7:556username6] 200 PUT /updater/check?download=0 (4 live) TLS GZIP 69usernamems 274 bytes (pipelined: 3)
Oct username3, 2020 07:20:04.username89 [3720] DEBUG - Auth: authenticated user username as username1@gmail.com
Oct username3, 2020 07:20:04.username89 [9484] DEBUG - Request: [username0.0.username.username7:556username4 (Allowed Network (Subnet))] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=username (4 live) TLS GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:20:04.username89 [9484] DEBUG - [CompanionProxy] registered new player: 087rctmb6gguz09mgfff34am (username0.0.username.username7)
Oct username3, 2020 07:20:04.username89 [9484] DEBUG - Content-Length is -username (of total: -username).
Oct username3, 2020 07:20:05.usernameusername4 [3720] DEBUG - Auth: authenticated user username as username1@gmail.com
Oct username3, 2020 07:20:05.usernameusername4 [5880] DEBUG - Request: [username0.0.username.username7:556username6 (Allowed Network (Subnet))] GET /accounts/username (4 live) TLS GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:20:05.usernameusername4 [username8644] DEBUG - Completed: [username0.0.username.username7:556username6] 200 GET /accounts/username (4 live) TLS GZIP 0ms 605 bytes (pipelined: 4)
Oct username3, 2020 07:20:05.usernameusername5 [username8644] DEBUG - Auth: authenticated user username as username1@gmail.com
Oct username3, 2020 07:20:05.usernameusername5 [5880] DEBUG - Request: [username0.0.username.username7:556username6 (Allowed Network (Subnet))] GET /:/prefs (4 live) TLS GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:20:05.usernameusername9 [3720] DEBUG - Auth: authenticated user username as username1@gmail.com
Oct username3, 2020 07:20:05.usernameusername9 [9484] DEBUG - Request: [username0.0.username.username7:55622 (Allowed Network (Subnet))] GET /myplex/account (6 live) TLS GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:20:05.username20 [3720] DEBUG - Completed: [username0.0.username.username7:55622] 200 GET /myplex/account (6 live) TLS GZIP 0ms 20username8 bytes (pipelined: username)
Oct username3, 2020 07:20:05.username2username [3720] DEBUG - Auth: authenticated user username as username1@gmail.com
Oct username3, 2020 07:20:05.username2username [9484] DEBUG - Request: [username0.0.username.username7:55623 (Allowed Network (Subnet))] GET /system/:/prefs (6 live) TLS GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:20:05.username2username [9484] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/:/prefs
Oct username3, 2020 07:20:05.username2username [9484] DEBUG - HTTP requesting GET http://username27.0.0.username:55395/system/:/prefs
Oct username3, 2020 07:20:05.username23 [username8644] DEBUG - Completed: [username0.0.username.username7:556username6] 200 GET /:/prefs (6 live) TLS GZIP 8ms 7079 bytes (pipelined: 5)
Oct username3, 2020 07:20:05.username25 [9484] DEBUG - HTTP 200 response from GET http://username27.0.0.username:55395/system/:/prefs
Oct username3, 2020 07:20:05.username25 [9484] DEBUG - [com.plexapp.system] HTTP reply status 200, with 4username8 bytes of content.
Oct username3, 2020 07:20:05.username25 [username8644] DEBUG - Completed: [username0.0.username.username7:55623] 200 GET /system/:/prefs (6 live) TLS GZIP 4ms 8username3 bytes (pipelined: username)
Oct username3, 2020 07:20:06.457 [username8644] DEBUG - WebSocket: client initiated close
Oct username3, 2020 07:20:06.457 [3720] DEBUG - NotificationStream: Removing because of close
Oct username3, 2020 07:20:06.458 [username8644] DEBUG - handleStreamRead code 2: End of file
Oct username3, 2020 07:20:06.458 [username8644] DEBUG - Completed after connection close: [username0.0.username.username7:556username5] -3 GET /:/websockets/notifications (6 live) TLS GZIP 4230ms username38 bytes
Oct username3, 2020 07:20:06.473 [username8644] DEBUG - Auth: authenticated user username as username1@gmail.com
and part 3:
Oct username3, 2020 07:20:06.473 [9484] DEBUG - Request: [username0.0.username.username7:55628 (Allowed Network (Subnet))] GET /diagnostics/logs (6 live) TLS GZIP Signed-in Token (username1@gmail.com)
Oct username3, 2020 07:20:06.473 [9484] DEBUG - Diagnostics: Building logfile zip
@solipsik I would prefer the log file itself, or the zip containning the various PMS logs.
From logs Error parsing allowedNetworks '': An invalid argument was supplied so please correct it (it cannot contain any blanks, only digits, points, and commas) and your libraries should appear in PlexConnect.
You have to authorize two ip’s (PlexConnect and ATV), separated by a comma.
For correcting the above Error - is this done through a script or do I just configure the appropriate settings? Sorry, I’m OK at some of this stuff, but this current issue is outside my realm of competence.
I do seem to have my Plexconnect and ATV authorized (e.g. listed under List of IP addresses and networks that are allowed without auth) - or is that something different?
As for the zip - can I send that to you directly?
From the logs looks like you have not done it correctly. Can you pls post an image of your setting ?
You can send me the zip containning logs in a PM.
@alexandr.krpv, any news ?
@solipsik, now that you reinstalled PMS are you able to access it with another Plex client (via browser or via app) ?
In the ATV3, with PlexConnect active in your PC and DNS (in the ATV3) pointing to your PC, are you able to access YouTube (or another ATV app) ? If yes, pls delete the ATVSettings.cfg file in your PC, and login the ATV to plex.tv (menu PlexConnect Settings).
Thanks again for your continued help.
I can access PMS from another client (used a browser).
I am able to access other apps on the ATV.
I deleted the ATVSettings cfg file on the PC.
I confirmed DNS in the ATV is pointing to the PC.
I restarted the ATV.
I accessed plexconnect on the ATV3 and tried logging in: I logged out which produced the spinning wheel; I tried logging out again and then was able to re-enter my login info. Again, the same spinning wheel of waiting greeted me; I’m not sure if it’s actually logging in. 0 PMS servers discovered and no library content is seen. It’s something in this area off logging in/out that seems to be the issue.
@solipsik PlexConnect has two components, the DNS server and the Web server. As you are able to access other apps in the ATV this proves that the DNS component is working ok.
Let’s try to use PlexConnect locally. For this you need:
Settings.cfg so that ```3) Delete `ATVSettings.cfg`
4) Start PlexConnect
5) Navigate to YouTube, and then quit
6) Navigate to Trailers, and then go to Settings
7) Login to plex.tv
8) Close PlexConnect
9) Send me the `PlexConnect.log` file (via PM if you wish)
Then repeat above steps, but this time with `ip_pms = 127.0.0.1`
One more question, did you install a firewall (replacing the windows firewall) ?
Ok will do. submitting logs now by PM.
I did not install a firewall to replace the windows firewall.
One thing I just realized and manually turned off prior to sending the most recent logs is that I had plexconnect enabled as a service - so even though I was manually closing the desktop plexconnect app/python shortcut, plexconnect may have been running in the background. I have changed the services for plexconnect to manual and is no longer automatically started. Sorry about that and I hope it hasn’t confounded the issue.
OK great news; the PC was restarted (possibly after an update) and plexconnect is working as normal on the ATV. Sign in done and detected the one PMS; library loaded, video playback and function confirmed.
I can’t thank you enough for your patience and mentor-ship on this matter; I actually did learn a fair amount more about plexconnect. Everything you have done and suggested must have tweaked something (I did do a restart of the PC at the beginning of this without resolution, but I;ll take what I can). Thank you again for everything - it’s very much appreciated.
Let me know if you need additional information.
I’m happy that the problem is solved. Probably PlexConnect (service) was stuck because of PMS not being logged on to plex.tv. You have reinstalled PMS to fix it but did not restarted PlexConnect service. Also all updates in Settings.cfg were being ignored.
When you have PlexConnect as a service running, manual start of PlexConnect will fail because the service is using the same ports that manual start requires. But this did not show in your posts above so I was convinced that you did not have PlexConnect as a service installed. I have to think on how to not fall in the same trap again.
