21:06:09 PlexConnect: started: 21:06:09
21:06:09 PlexConnect: Version: 0.5-dev
21:06:09 PlexConnect: Python: 2.7.8 (default, Jun 30 2014, 16:03:49) [MSC v.1500 32 bit (Intel)]
21:06:09 PlexConnect: Host OS: win32
21:06:09 PlexConnect: PILBackgrounds: Is PIL installed? False
21:06:09 Settings: getsetting enable_plexconnect_autodetect=True
21:06:09 PlexConnect: IP_self: 10.1.0.2
21:06:09 Settings: getsetting hosttointercept=trailers.apple.com
21:06:09 Settings: getsetting enable_dnsserver=True
21:06:09 Settings: getsetting enable_webserver_ssl=True
21:06:10 DNSServer: started: 21:06:10
21:06:10 Settings: getsetting port_dnsserver=53
21:06:10 Settings: getsetting ip_dnsmaster=8.8.8.8
21:06:10 Settings: getsetting prevent_atv_update=True
21:06:10 DNSServer: ***
21:06:10 DNSServer: DNSServer: Serving DNS on 10.1.0.2 port 53.
21:06:10 DNSServer: intercept: ['trailers.apple.com'] => 10.1.0.2
21:06:10 WebServer: started: 21:06:10
21:06:10 Settings: getsetting port_webserver=80
21:06:10 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
21:06:10 DNSServer: forward other to higher level DNS: 8.8.8.8
21:06:10 WebServer: ***
21:06:10 WebServer: WebServer: Serving HTTP on 10.1.0.2 port 80.
21:06:10 Settings: getsetting port_ssl=443
21:06:10 Settings: getsetting certfile=./assets/certificates/trailers.pem
21:06:10 WebServer: WebServer: Serving HTTPS on 10.1.0.2 port 443.
21:06:13 DNSServer: DNS request received!
21:06:13 DNSServer: Source: ('10.1.0.10', 56735)
21:06:13 DNSServer: Domain: trailers.apple.com
21:06:13 DNSServer: ***intercept request
21:06:13 DNSServer: -> DNS response: 10.1.0.2
21:06:13 WebServer: http request header:
Host: trailers.apple.com
Accept-Encoding: gzip, deflate
Accept: /
Accept-Language: en;q=0.9
Cookie: mz_at0-557860959=AwQAAAEMAADEfAAAAABUQE27bQrThC63mk6afmC0RBhnERjKbcU=; mz_at_ssl-557860959=AwUAAAEMAADEfAAAAABUQE27I9j3DmXkCdK5OBWXSunr4Y6JcZI=; s_vi=[CS]v1|2857702305163178-60000198C00317A0[CE]; X-Dsid=557860959
Connection: keep-alive
X-Apple-TV-Resolution: 1080
X-Apple-TV-Version: 7.0.2
User-Agent: AppleTV/7.0.2 iOS/8.1.1 AppleTV/7.0.2 model/AppleTV3,1 build/12B435 (3; dt:12)
21:06:13 WebServer: http request path:
/appletv/us/js/application.js
21:06:13 Localize: aTVLanguage: en
21:06:13 WebServer: pms address:
21:06:13 WebServer: cleaned path:
21:06:13 WebServer: PlexConnect options:
{‘aTVScreenResolution’: ‘1080’, ‘aTVFirmwareVersion’: ‘7.0.2’, ‘aTVLanguage’: ‘en’, ‘aTVAddress’: ‘10.1.0.10’}
21:06:13 WebServer: additional arguments:
21:06:13 WebServer: serving /js/application.js
X-Apple-Store-Front: 143455-6,19
Accept: /
Cookie: mz_at0-557860959=AwQAAAEMAADEfAAAAABUQE27bQrThC63mk6afmC0RBhnERjKbcU=; s_vi=[CS]v1|2857702305163178-60000198C00317A0[CE]; X-Dsid=557860959
/&PlexConnect=Discover&PlexConnectUDID=DY4JG3J2DRHN
{‘aTVAddress’: ‘10.1.0.10’, ‘aTVScreenResolution’: ‘1080’, ‘PlexConnectUDID’: ‘DY4JG3J2DRHN’, ‘aTVLanguage’: ‘en’, ‘aTVFirmwareVersion’: ‘7.0.2’, ‘PlexConnect’: ‘Discover’}
21:06:13 WebServer: serving .xml: /
21:06:13 XMLConverter: ---------------------------------------------
21:06:13 XMLConverter: Input: /
21:06:13 XMLConverter: Initial Command: Discover
21:06:13 Settings: getsetting enable_plexgdm=True
21:06:13 PlexAPI: ***
21:06:13 PlexAPI: looking up Plex Media Server
21:06:13 PlexAPI: Sending discovery message: M-SEARCH * HTTP/1.0
21:06:13 PlexAPI: Received data from (‘10.1.0.2’, 32414)
21:06:13 PlexAPI: Data received:
HTTP/1.0 200 OK
Content-Type: plex/media-server
Resource-Identifier: 33a084a62dff225cd8483e1f2d2772df8b704f09
Port: 32400
Updated-At: 1428973470
Version: 0.9.11.7.803-87d0708
21:06:14 PlexAPI: GDM: Servers discovered: 1
21:06:14 PlexAPI: Fred-Plex 10.1.0.2:32400
21:06:14 PlexAPI: Servers (local+MyPlex): 1
21:06:14 PlexAPI: {‘name’: u’Fred-Plex’, ‘accesstoken’: ‘’, ‘address’: ‘10.1.0.2:32400’, ‘ip’: ‘10.1.0.2’, ‘scheme’: ‘http’, ‘local’: ‘1’, ‘port’: ‘32400’, ‘owned’: ‘1’, ‘baseURL’: ‘http://10.1.0.2:32400’}
21:06:14 WebServer: http request header:
Accept: /
Accept-Language: en
Cookie: ns-mzf-inst=36-77-80-109-80-8302-92417-9-st11; xp_ci=3z15nBNXz6XOz4YizA3Bz92SQKmEA; s_vi=[CS]v1|285777AA850101B6-6000010E60014F23[CE]; itspod=9; mz_at0-557860959=AwQAAAEMAAE45QAAAABVLFl0YtP1nCB+GD1X31bYoKYkfR2ThIA=; TrPod=3; X-Dsid=557860959
21:06:14 WebServer: http request path:
/PlexConnect.xml?PlexConnectUDID=DY4JG3J2DRHN&PlexConnectATVName=ATV%20living%20room
21:06:14 Localize: aTVLanguage: en
21:06:14 WebServer: pms address:
21:06:14 WebServer: cleaned path:
/PlexConnect.xml
21:06:14 WebServer: PlexConnect options:
{‘aTVAddress’: ‘10.1.0.10’, ‘aTVScreenResolution’: ‘1080’, ‘PlexConnectUDID’: ‘DY4JG3J2DRHN’, ‘aTVLanguage’: ‘en’, ‘aTVFirmwareVersion’: ‘7.0.2’, ‘PlexConnectATVName’: ‘ATV living room’}
21:06:14 WebServer: additional arguments:
21:06:14 WebServer: serving .xml: /PlexConnect.xml
Accept: /
/&PlexConnectATVLogLevel=1&PlexConnectLog=atv.onGenerateRequest%20done%3A%20http%3A%2F%2Ftrailers.apple.com%2FPlexConnect.xml%3FPlexConnectUDID%3DDY4JG3J2DRHN%26PlexConnectATVName%3DATV%2520living%2520room
21:06:14 XMLConverter: XMLTemplate: PlexConnect.xml
21:06:14 XMLConverter: XML_ExpandNode: None - done
{‘aTVAddress’: ‘10.1.0.10’, ‘aTVScreenResolution’: ‘1080’, ‘PlexConnectATVLogLevel’: ‘1’, ‘PlexConnectLog’: ‘atv.onGenerateRequest done: http://trailers.apple.com/PlexConnect.xml?PlexConnectUDID=DY4JG3J2DRHN&PlexConnectATVName=ATV%20living%20room’, ‘aTVFirmwareVersion’: ‘7.0.2’, ‘aTVLanguage’: ‘en’}
21:06:14 XMLConverter: XML_ExpandNode: {{TEXT(Playlists)}}
21:06:14 ATVLogger: atv.onGenerateRequest done: http://trailers.apple.com/PlexConnect.xml?PlexConnectUDID=DY4JG3J2DRHN&PlexConnectATVName=ATV%20living%20room
21:06:14 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Playlists)}}
21:06:14 XMLConverter: XML_ExpandNode: {{URL(:/PMS(all)/playlists::PlexConnect=Playlists_View)}}
21:06:14 XMLConverter: XML_ExpandNode - Stumbled over URL in line {{URL(:/PMS(all)/playlists::PlexConnect=Playlists_View)}}
21:06:14 XMLConverter: XML_ExpandNode: {{CUT($showplaylists:CUT:False=CUT|List=)}}
21:06:14 XMLConverter: CCmds_getParam: $showplaylists, CUT:False=CUT|List=
21:06:14 XMLConverter: CCmds_getParam: CUT, False=CUT|List=
21:06:14 XMLConverter: CCmds_getKey: False,False=CUT|List=,False
21:06:14 XMLConverter: CCmds_getParam: False=CUT|List=,
21:06:14 XMLConverter: CCmds_getConversion: [(‘False’, ‘CUT’), (‘List’, ‘’)],
21:06:14 XMLConverter: CCmds_applyConversion: CUT
21:06:14 XMLConverter: XML_ExpandNode: {{TEXT(Library)}}
21:06:14 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Library)}}
21:06:14 XMLConverter: XML_ExpandNode: {{URL(:/PMS(owned)/library/sections::PlexConnect=Main_Library)}}
21:06:14 XMLConverter: XML_ExpandNode - Stumbled over URL in line {{URL(:/PMS(owned)/library/sections::PlexConnect=Main_Library)}}
21:06:14 XMLConverter: XML_ExpandNode: {{TEXT(Channels)}}
21:06:14 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Channels)}}
21:06:14 XMLConverter: XML_ExpandNode: {{URL(:/PMS(owned)/channels/all::PlexConnect=Channels_View)}}
21:06:14 XMLConverter: XML_ExpandNode - Stumbled over URL in line {{URL(:/PMS(owned)/channels/all::PlexConnect=Channels_View)}}
21:06:14 XMLConverter: XML_ExpandNode: {{TEXT(Shared Libraries)}}
21:06:14 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Shared Libraries)}}
21:06:14 XMLConverter: XML_ExpandNode: {{URL(:/PMS(shared)/library/sections::PlexConnect=Main_Library)}}
21:06:14 XMLConverter: XML_ExpandNode - Stumbled over URL in line {{URL(:/PMS(shared)/library/sections::PlexConnect=Main_Library)}}
21:06:14 XMLConverter: XML_ExpandNode: {{CUT($myplex_auth:CUT:=CUT| =)}}{{CUT($showsharedlibraries:CUT:False=CUT|True=)}}
21:06:14 XMLConverter: CCmds_getParam: $myplex_auth, CUT:=CUT| =
21:06:14 XMLConverter: CCmds_getParam: CUT, =CUT| =
21:06:14 XMLConverter: CCmds_getKey: ,=CUT| =,False
21:06:14 XMLConverter: CCmds_getParam: =CUT| =,
21:06:14 XMLConverter: CCmds_getConversion: [(’’, ‘CUT’), (’ ', ‘’)],
21:06:14 XMLConverter: XML_ExpandNode: {{TEXT(Settings)}}
21:06:14 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Settings)}}
21:06:14 XMLConverter: XML_ExpandNode: {{URL(:/::PlexConnect=Settings_Main)}}
21:06:14 XMLConverter: XML_ExpandNode - Stumbled over URL in line {{URL(:/::PlexConnect=Settings_Main)}}
21:06:14 XMLConverter: XML_ExpandLine: {{URL(:/js/utils.js)}}
21:06:14 XMLConverter: CCmds_getParam: , /js/utils.js
21:06:14 XMLConverter: CCmds_getParam: /js/utils.js,
21:06:14 XMLConverter: CCmds_getKey: /js/utils.js,True
21:06:14 XMLConverter: XML_ExpandLine: http://trailers.apple.com/js/utils.js - done
21:06:14 XMLConverter: XML_ExpandLine: {{URL(:/js/handlePlexConnectNavbar.js)}}
21:06:14 XMLConverter: CCmds_getParam: , /js/handlePlexConnectNavbar.js
21:06:14 XMLConverter: CCmds_getParam: /js/handlePlexConnectNavbar.js,
21:06:14 XMLConverter: CCmds_getKey: /js/handlePlexConnectNavbar.js,True
21:06:14 XMLConverter: XML_ExpandLine: http://trailers.apple.com/js/handlePlexConnectNavbar.js - done
21:06:14 XMLConverter: XML_ExpandLine: {{VAL($showplaylists:0:False=0|True=1)}}
21:06:14 XMLConverter: CCmds_getParam: $showplaylists, 0:False=0|True=1
21:06:14 XMLConverter: CCmds_getParam: 0, False=0|True=1
21:06:14 XMLConverter: CCmds_getKey: False,False=0|True=1,False
21:06:14 XMLConverter: CCmds_getParam: False=0|True=1,
21:06:14 XMLConverter: CCmds_getConversion: [(‘False’, ‘0’), (‘True’, ‘1’)],
21:06:14 XMLConverter: CCmds_applyConversion: 0
21:06:14 XMLConverter: XML_ExpandLine: 0 - done
21:06:14 XMLConverter: XML_ExpandLine: {{TEXT(Library)}}
21:06:14 XMLConverter: XML_ExpandLine: Library - done
21:06:14 XMLConverter: XML_ExpandLine: {{URL(:/PMS(owned)/library/sections::PlexConnect=Main_Library)}}
21:06:14 XMLConverter: CCmds_getParam: , /PMS(owned)/library/sections::PlexConnect=Main_Library
21:06:14 XMLConverter: CCmds_getParam: /PMS(owned)/library/sections, :PlexConnect=Main_Library
21:06:14 XMLConverter: CCmds_getKey: /PMS(owned)/library/sections,:PlexConnect=Main_Library,True
21:06:14 XMLConverter: CCmds_getParam: , PlexConnect=Main_Library
21:06:14 XMLConverter: CCmds_getParam: PlexConnect=Main_Library,
21:06:14 XMLConverter: XML_ExpandLine: http://trailers.apple.com/PMS(owned)/library/sections?PlexConnect=Main_Library - done
21:06:14 XMLConverter: XML_ExpandLine: {{TEXT(Channels)}}
21:06:14 XMLConverter: XML_ExpandLine: Channels - done
21:06:14 XMLConverter: XML_ExpandLine: {{URL(:/PMS(owned)/channels/all::PlexConnect=Channels_View)}}
21:06:14 XMLConverter: CCmds_getParam: , /PMS(owned)/channels/all::PlexConnect=Channels_View
21:06:14 XMLConverter: CCmds_getParam: /PMS(owned)/channels/all, :PlexConnect=Channels_View
21:06:14 XMLConverter: CCmds_getKey: /PMS(owned)/channels/all,:PlexConnect=Channels_View,True
21:06:14 XMLConverter: CCmds_getParam: , PlexConnect=Channels_View
21:06:14 XMLConverter: CCmds_getParam: PlexConnect=Channels_View,
21:06:14 XMLConverter: XML_ExpandLine: http://trailers.apple.com/PMS(owned)/channels/all?PlexConnect=Channels_View - done
21:06:14 XMLConverter: XML_ExpandLine: {{TEXT(Settings)}}
21:06:14 XMLConverter: XML_ExpandLine: Settings - done
21:06:14 XMLConverter: XML_ExpandLine: {{URL(:/::PlexConnect=Settings_Main)}}
21:06:14 XMLConverter: CCmds_getParam: , /::PlexConnect=Settings_Main
21:06:14 XMLConverter: CCmds_getParam: /, :PlexConnect=Settings_Main
21:06:14 XMLConverter: CCmds_getKey: /,:PlexConnect=Settings_Main,True
21:06:14 XMLConverter: CCmds_getParam: , PlexConnect=Settings_Main
21:06:14 XMLConverter: CCmds_getParam: PlexConnect=Settings_Main,
21:06:14 XMLConverter: XML_ExpandLine: http://trailers.apple.com/PMS()/?PlexConnect=Settings_Main - done
21:06:14 XMLConverter: ====== generated aTV-XML ======
Library
Channels
Settings
21:06:14 XMLConverter: ====== aTV-XML finished ======
Accept: /
/&PlexConnectATVLogLevel=1&PlexConnectLog=atv.onGenerateRequest%20done%3A%20http%3A%2F%2Ftrailers.apple.com%2Fjs%2Futils.js%3FPlexConnectUDID%3DDY4JG3J2DRHN%26PlexConnectATVName%3DATV%2520living%2520room
{‘aTVAddress’: ‘10.1.0.10’, ‘aTVScreenResolution’: ‘1080’, ‘PlexConnectATVLogLevel’: ‘1’, ‘PlexConnectLog’: ‘atv.onGenerateRequest done: http://trailers.apple.com/js/utils.js?PlexConnectUDID=DY4JG3J2DRHN&PlexConnectATVName=ATV%20living%20room’, ‘aTVFirmwareVersion’: ‘7.0.2’, ‘aTVLanguage’: ‘en’}
Accept: /
21:06:14 ATVLogger: atv.onGenerateRequest done: http://trailers.apple.com/js/utils.js?PlexConnectUDID=DY4JG3J2DRHN&PlexConnectATVName=ATV%20living%20room
/js/utils.js
21:06:14 WebServer: serving /js/utils.js
Accept: /
/&PlexConnectATVLogLevel=1&PlexConnectLog=atv.onGenerateRequest%20done%3A%20http%3A%2F%2Ftrailers.apple.com%2Fjs%2FhandlePlexConnectNavbar.js%3FPlexConnectUDID%3DDY4JG3J2DRHN%26PlexConnectATVName%3DATV%2520living%2520room
Accept: /
/js/handlePlexConnectNavbar.js?PlexConnectUDID=DY4JG3J2DRHN&PlexConnectATVName=ATV%20living%20room
{‘aTVAddress’: ‘10.1.0.10’, ‘aTVScreenResolution’: ‘1080’, ‘PlexConnectATVLogLevel’: ‘1’, ‘PlexConnectLog’: ‘atv.onGenerateRequest done: http://trailers.apple.com/js/handlePlexConnectNavbar.js?PlexConnectUDID=DY4JG3J2DRHN&PlexConnectATVName=ATV%20living%20room’, ‘aTVFirmwareVersion’: ‘7.0.2’, ‘aTVLanguage’: ‘en’}
21:06:14 ATVLogger: atv.onGenerateRequest done: http://trailers.apple.com/js/handlePlexConnectNavbar.js?PlexConnectUDID=DY4JG3J2DRHN&PlexConnectATVName=ATV%20living%20room
21:06:14 WebServer: serving /js/handlePlexConnectNavbar.js
Accept: /
Accept: /
/&PlexConnectATVLogLevel=1&PlexConnectLog=loadMenuPage%3A%20itemid%3DLibrary
21:06:15 Localize: aTVLanguage: en
h:
/PMS(owned)/library/sections?PlexConnect=Main_Library&PlexConnectUDID=DY4JG3J2DRHN
21:06:15 WebServer: pms address:
21:06:15 WebServer: cleaned path:
21:06:15 WebServer: PlexConnect options:
{‘aTVAddress’: ‘10.1.0.10’, ‘aTVScreenResolution’: ‘1080’, ‘PlexConnectATVLogLevel’: ‘1’, ‘PlexConnectLog’: ‘loadMenuPage: itemid=Library’, ‘aTVFirmwareVersion’: ‘7.0.2’, ‘aTVLanguage’: ‘en’}
21:06:15 WebServer: additional arguments:
owned
/library/sections
21:06:15 ATVLogger: loadMenuPage: itemid=Library
{‘aTVAddress’: ‘10.1.0.10’, ‘aTVScreenResolution’: ‘1080’, ‘PlexConnectUDID’: ‘DY4JG3J2DRHN’, ‘aTVLanguage’: ‘en’, ‘aTVFirmwareVersion’: ‘7.0.2’, ‘PlexConnect’: ‘Main_Library’}
21:06:15 WebServer: serving .xml: /library/sections
21:06:15 XMLConverter: ---------------------------------------------
21:06:15 XMLConverter: Input: owned /library/sections
21:06:15 XMLConverter: Initial Command: Main_Library
21:06:15 XMLConverter: Split Directory: Main Command: Library
21:06:15 XMLConverter: PlexConnectChannelsSearch:
21:06:15 XMLConverter: XMLTemplate: Main/Library.xml
21:06:15 PlexAPI: URL: http://10.1.0.2:32400/library/sections
21:06:15 PlexAPI: xargs: {‘X-Plex-Platform’: ‘iOS’, ‘X-Plex-Model’: ‘3,1’, ‘X-Plex-Client-Platform’: ‘iOS’, ‘X-Plex-Client-Identifier’: ‘DY4JG3J2DRHN’, ‘X-Plex-Device’: ‘AppleTV’, ‘X-Plex-Product’: ‘PlexConnect’, ‘X-Plex-Platform-Version’: ‘7.0.2’, ‘X-Plex-Version’: ‘0.5-dev’}
21:06:15 PlexAPI: No Response from Plex Media Server
21:06:15 PlexAPI: We failed to reach a server. Reason: Unauthorized
21:06:15 PlexAPI: ====== Local Server/Sections XML ======
21:06:15 PlexAPI:
21:06:15 PlexAPI: ====== Local Server/Sections XML finished ======
21:06:15 XMLConverter: viewGroup: None
21:06:15 XMLConverter: XML_ExpandNode: None - done
{{VAR(sections:NoKey:FALSE)}}
21:06:15 XMLConverter: CCmds_getParam: sections, NoKey:FALSE
21:06:15 XMLConverter: CCmds_getParam: NoKey, FALSE
21:06:15 XMLConverter: CCmds_getParam: FALSE,
21:06:15 XMLConverter: CCmds_getKey: FALSE,True
21:06:15 XMLConverter: CCmds_getParam: ,
21:06:15 XMLConverter: CCmds_getConversion: [],
{{CUT($libraryview::=CUT|List=|List =CUT)}}
21:06:15 XMLConverter: CCmds_getParam: $libraryview, :=CUT|List=|List =CUT
21:06:15 XMLConverter: CCmds_getParam: , =CUT|List=|List =CUT
21:06:15 XMLConverter: CCmds_getKey: List,=CUT|List=|List =CUT,False
21:06:15 XMLConverter: CCmds_getParam: =CUT|List=|List =CUT,
21:06:15 XMLConverter: CCmds_getConversion: [(’’, ‘CUT’), (‘List’, ‘’), ('List ', ‘CUT’)],
21:06:15 XMLConverter: CCmds_applyConversion:
21:06:15 XMLConverter: XML_ExpandNode: {{TEXT(Plex Library)}}
21:06:15 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Plex Library)}}
{{COPY(Server:@main/size::0=|1=COPY)}}
21:06:15 XMLConverter: CCmds_getParam: Server, @main/size::0=|1=COPY
21:06:15 XMLConverter: CCmds_getParam: @main/size, :0=|1=COPY
21:06:15 XMLConverter: CCmds_getParam: , 0=|1=COPY
21:06:15 XMLConverter: CCmds_getKey: 1,0=|1=COPY,False
21:06:15 XMLConverter: CCmds_getParam: 0=|1=COPY,
21:06:15 XMLConverter: CCmds_getConversion: [(‘0’, ‘’), (‘1’, ‘COPY’)],
21:06:15 XMLConverter: CCmds_applyConversion: COPY
21:06:15 XMLConverter: XML_ExpandNode: {{VAL(name)}}{{VAL(local::0= <{{TEXT(remote)}}>|0 =)}}
21:06:15 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(name)}}{{VAL(local::0= <{{TEXT(remote)}}>|0 =)}}
21:06:15 XMLConverter: XML_ExpandNode: {{CUT(@main/size:CUT:0=CUT|1=CUT|2=)}}
21:06:15 XMLConverter: CCmds_getParam: @main/size, CUT:0=CUT|1=CUT|2=
21:06:15 XMLConverter: CCmds_getParam: CUT, 0=CUT|1=CUT|2=
21:06:15 XMLConverter: CCmds_getKey: 1,0=CUT|1=CUT|2=,False
21:06:15 XMLConverter: CCmds_getParam: 0=CUT|1=CUT|2=,
21:06:15 XMLConverter: CCmds_getConversion: [(‘0’, ‘CUT’), (‘1’, ‘CUT’), (‘2’, ‘’)],
21:06:15 XMLConverter: CCmds_applyConversion: CUT
{{COPY(Directory)}}
{{VAR(sections:NoKey:TRUE)}}
21:06:15 XMLConverter: CCmds_getParam: Directory,
21:06:15 XMLConverter: XML_ExpandNode: {{TEXT(Search)}}
21:06:15 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Search)}}
21:06:15 XMLConverter: XML_ExpandLine: atv.loadURL(’{{URL(searchKey)}}’)
21:06:15 XMLConverter: CCmds_getParam: searchKey,
21:06:15 XMLConverter: CCmds_getKey: PMS(10.1.0.2)/Search/Entry.xml,False
21:06:15 XMLConverter: XML_ExpandLine: atv.loadURL(‘http://trailers.apple.com/PMS(10.1.0.2)/Search/Entry.xml’) - done
21:06:15 XMLConverter: XML_ExpandLine: {{VAL(searchKey)}}
21:06:15 XMLConverter: CCmds_applyConversion: PMS(10.1.0.2)/Search/Entry.xml
21:06:15 XMLConverter: XML_ExpandLine: PMS(10.1.0.2)/Search/Entry.xml - done
21:06:15 XMLConverter: XML_ExpandLine: {{TEXT(Search)}}
21:06:15 XMLConverter: XML_ExpandLine: Search - done
21:06:15 XMLConverter: XML_ExpandNode: {{CUT(#sections::FALSE=CUT|TRUE=)}}
21:06:15 XMLConverter: CCmds_getParam: #sections, :FALSE=CUT|TRUE=
21:06:15 XMLConverter: CCmds_getParam: , FALSE=CUT|TRUE=
21:06:15 XMLConverter: CCmds_getKey: FALSE,FALSE=CUT|TRUE=,False
21:06:15 XMLConverter: CCmds_getParam: FALSE=CUT|TRUE=,
21:06:15 XMLConverter: CCmds_getConversion: [(‘FALSE’, ‘CUT’), (‘TRUE’, ‘’)],
{{CUT($libraryview:CUT:=CUT|Grid=|Grid =CUT)}}
21:06:15 XMLConverter: CCmds_getParam: $libraryview, CUT:=CUT|Grid=|Grid =CUT
21:06:15 XMLConverter: CCmds_getParam: CUT, =CUT|Grid=|Grid =CUT
21:06:15 XMLConverter: CCmds_getKey: List,=CUT|Grid=|Grid =CUT,False
21:06:15 XMLConverter: CCmds_getParam: =CUT|Grid=|Grid =CUT,
21:06:15 XMLConverter: CCmds_getConversion: [(’’, ‘CUT’), (‘Grid’, ‘’), ('Grid ', ‘CUT’)],
{{CUT($libraryview:CUT:=CUT|Bookcase=|Bookcase =CUT)}}
21:06:15 XMLConverter: CCmds_getParam: $libraryview, CUT:=CUT|Bookcase=|Bookcase =CUT
21:06:15 XMLConverter: CCmds_getParam: CUT, =CUT|Bookcase=|Bookcase =CUT
21:06:15 XMLConverter: CCmds_getKey: List,=CUT|Bookcase=|Bookcase =CUT,False
21:06:15 XMLConverter: CCmds_getParam: =CUT|Bookcase=|Bookcase =CUT,
21:06:15 XMLConverter: CCmds_getConversion: [(’’, ‘CUT’), (‘Bookcase’, ‘’), ('Bookcase ', ‘CUT’)],
{{CUT(#sections::FALSE=|TRUE=CUT)}}
21:06:15 XMLConverter: CCmds_getParam: #sections, :FALSE=|TRUE=CUT
21:06:15 XMLConverter: CCmds_getParam: , FALSE=|TRUE=CUT
21:06:15 XMLConverter: CCmds_getKey: FALSE,FALSE=|TRUE=CUT,False
21:06:15 XMLConverter: CCmds_getParam: FALSE=|TRUE=CUT,
21:06:15 XMLConverter: CCmds_getConversion: [(‘FALSE’, ‘’), (‘TRUE’, ‘CUT’)],
21:06:15 XMLConverter: XML_ExpandNode: {{TEXT(No Plex Library Sections Available)}}
21:06:15 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(No Plex Library Sections Available)}}
21:06:15 XMLConverter: XML_ExpandLine: {{URL(:/js/utils.js)}}
21:06:15 XMLConverter: CCmds_getParam: , /js/utils.js
21:06:15 XMLConverter: CCmds_getParam: /js/utils.js,
21:06:15 XMLConverter: CCmds_getKey: /js/utils.js,True
21:06:15 XMLConverter: XML_ExpandLine: http://trailers.apple.com/js/utils.js - done
21:06:15 XMLConverter: XML_ExpandLine: {{URL(:/js/sectionHoldSelect.js)}}
21:06:15 XMLConverter: CCmds_getParam: , /js/sectionHoldSelect.js
21:06:15 XMLConverter: CCmds_getParam: /js/sectionHoldSelect.js,
21:06:15 XMLConverter: CCmds_getKey: /js/sectionHoldSelect.js,True
21:06:15 XMLConverter: XML_ExpandLine: http://trailers.apple.com/js/sectionHoldSelect.js - done
21:06:15 XMLConverter: XML_ExpandLine: {{TEXT(No Plex Library Sections Available)}}
21:06:15 XMLConverter: XML_ExpandLine: No Plex Library Sections Available - done
21:06:15 XMLConverter: ====== generated aTV-XML ======
PlexConnect
21:06:15 XMLConverter: ====== aTV-XML finished ======
21:06:15 WebServer: http request header:
Accept: /
Accept: /
21:06:15 WebServer: http request path:
/js/utils.js
21:06:15 WebServer: serving /js/utils.js
21:06:15 ATVLogger: atv.onGenerateRequest done: http://trailers.apple.com/js/utils.js?PlexConnectUDID=DY4JG3J2DRHN&PlexConnectATVName=ATV%20living%20room
Accept: /
/&PlexConnectATVLogLevel=1&PlexConnectLog=atv.onGenerateRequest%20done%3A%20http%3A%2F%2Ftrailers.apple.com%2Fjs%2FsectionHoldSelect.js%3FPlexConnectUDID%3DDY4JG3J2DRHN%26PlexConnectATVName%3DATV%2520living%2520room
Accept: /
/js/sectionHoldSelect.js?PlexConnectUDID=DY4JG3J2DRHN&PlexConnectATVName=ATV%20living%20room
ons:
{‘aTVAddress’: ‘10.1.0.10’, ‘aTVScreenResolution’: ‘1080’, ‘PlexConnectATVLogLevel’: ‘1’, ‘PlexConnectLog’: ‘atv.onGenerateRequest done: http://trailers.apple.com/js/sectionHoldSelect.js?PlexConnectUDID=DY4JG3J2DRHN&PlexConnectATVName=ATV%20living%20room’, ‘aTVFirmwareVersion’: ‘7.0.2’, ‘aTVLanguage’: ‘en’}
21:06:15 ATVLogger: atv.onGenerateRequest done: http://trailers.apple.com/js/sectionHoldSelect.js?PlexConnectUDID=DY4JG3J2DRHN&PlexConnectATVName=ATV%20living%20room
21:06:15 WebServer: serving /js/sectionHoldSelect.js
21:06:20 WebServer: Shutting down (HTTPS).
21:06:20 WebServer: Shutting down (HTTP).
21:06:23 DNSServer: Shutting down.
