Hi all.
Since the last two revisions 1.1.2.2680 & 1.1.2.2680 I keep getting this error when I’m logging with my ATV2 & 3. I tried to install an updated version of PLEXCONNECT still same issue…if I revert back to 1.0.3.2461 plexconnect works fine.
My firewall settings hasn’t changed I can connect to my plex server on my ipad and Apple tv4 units. Under settings of the Trailer on the AppleTV2 I do see the server found.
here is the errors.
12:45:28 PlexConnect: ***
12:45:28 PlexConnect: PlexConnect
12:45:28 PlexConnect: Press CTRL-C to shut down.
12:45:28 PlexConnect: started: 12:45:28
12:45:28 PlexConnect: Version: 0.5-dev-101215
12:45:28 PlexConnect: Python: 2.7.6 (default, Nov 10 2013, 19:24:18) [MSC v.1500 32 bit (Intel)]
12:45:28 PlexConnect: Host OS: win32
12:45:28 PlexConnect: PILBackgrounds: Is PIL installed? False
12:45:28 PlexConnect: IP_self: 192.168.2.18
12:45:28 DNSServer: started: 12:45:28
12:45:28 DNSServer: ***
12:45:28 DNSServer: DNSServer: Serving DNS on 192.168.2.18 port 53.
12:45:28 DNSServer: intercept: [‘trailers.apple.com’] => 192.168.2.18
12:45:28 DNSServer: restrain: [‘mesu.apple.com’, ‘appldnld.apple.com’, ‘appldnld.apple.com.edgesuite.net’] => 127.0.0.1
12:45:28 DNSServer: forward other to higher level DNS: 8.8.8.8
12:45:28 WebServer: started: 12:45:28
12:45:28 WebServer: ***
12:45:28 WebServer: WebServer: Serving HTTP on 192.168.2.18 port 80.
12:45:29 WebServer: started: 12:45:29
12:45:29 WebServer: ***
12:45:29 WebServer: WebServer: Serving HTTPS on 192.168.2.18 port 443.
12:45:47 DNSServer: DNS request received!
12:45:47 DNSServer: Source: (‘192.168.2.27’, 50467)
12:45:47 DNSServer: Domain: trailers.apple.com
12:45:47 DNSServer: ***intercept request
12:45:47 DNSServer: -> DNS response: 192.168.2.18
12:45:47 WebServer: serving /js/application.js
12:45:47 WebServer: serving .xml: /
12:45:47 ATVSettings: add section C07H14Q3DDR5
12:45:47 PlexAPI: ***
12:45:47 PlexAPI: PlexGDM - looking up Plex Media Server
12:45:48 PlexAPI: GDM: Servers discovered: 1
12:45:48 PlexAPI: Servers (local, plex.tv, MyPlex): 2
12:45:48 WebServer: serving .xml: /PlexConnect.xml
12:45:49 WebServer: serving /js/utils.js
12:45:49 WebServer: serving /js/handlePlexConnectNavbar.js
12:45:49 WebServer: serving .xml: /library/sections
12:45:49 PlexAPI: No Response from Plex Media Server
12:45:49 PlexAPI: We failed to reach a server. Reason: Unauthorized
12:45:49 PlexAPI: Traceback:
Traceback (most recent call last):
File “C:\Users\Seeder\Desktop\Plex Connect old\PlexConnect-master\PlexAPI.py”, line 406, in getXMLFromPMS
response = urllib2.urlopen(request, timeout=20)
File “C:\Python27\lib\urllib2.py”, line 127, in urlopen
return _opener.open(url, data, timeout)
File “C:\Python27\lib\urllib2.py”, line 410, in open
response = meth(req, response)
File “C:\Python27\lib\urllib2.py”, line 523, in http_response
‘http’, request, response, code, msg, hdrs)
File “C:\Python27\lib\urllib2.py”, line 448, in error
return self._call_chain(*args)
File “C:\Python27\lib\urllib2.py”, line 382, in _call_chain
result = func(*args)
File “C:\Python27\lib\urllib2.py”, line 531, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 401: Unauthorized
12:45:49 WebServer: serving /js/sectionHoldSelect.js
