Unable to accèss Plex on ATV3 have installed PlexConnect on ubuntu and set required config along with certificate between ATV and the Server but still no joy. When I open up iMovie App it opens up as standard and does not switch to Plex..... I have set DNS as the PMS server IP.
Please see config and log:
view PlexConnect.log
22:43:25 PlexConnect: started: 22:43:25
22:43:25 PlexConnect: Version: 0.3.1+
22:43:25 PlexConnect: Python: 2.7.5+ (default, Sep 19 2013, 13:48:49)
[GCC 4.8.1]
22:43:25 PlexConnect: Host OS: linux2
22:43:25 PlexConnect: IP_self: 192.168.100.20
22:43:25 DNSServer: started: 22:43:25
22:43:25 DNSServer: ***
22:43:25 DNSServer: DNSServer: Serving DNS on 192.168.100.20 port 53.
22:43:25 WebServer: started: 22:43:25
22:43:25 WebServer: ***
22:43:25 WebServer: WebServer: Serving HTTP on 192.168.100.20 port 80.
22:43:25 WebServer: WebServer: Serving HTTPS on 192.168.100.20 port 443.
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.100.20
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 192.168.100.20
hosttointercept = icloud.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = /home/alancarslaw/PlexConnect/assets/certificates/trailers.pem
loglevel = Normal
logpath = .
ps -ef | grep -i plex
avahi 489 1 0 Feb15 ? 00:00:44 avahi-daemon: running [plexmediaserver.local]
plex 9082 9080 0 Feb20 ? 00:00:00 /bin/sh /usr/sbin/start_pms
plex 9083 9082 0 Feb20 ? 00:09:51 ./Plex Media Server
plex 9092 9083 0 Feb20 ? 00:08:49 Plex Plug-in [com.plexapp.system] /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 0.9.9.3.402-c7906ea /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/System.bundle
plex 9142 9083 0 Feb20 ? 00:01:18 /usr/lib/plexmediaserver/Plex DLNA Server
1000 11061 10844 0 17:33 pts/0 00:00:00 grep --color=auto -i plex
root 13048 1 0 Feb20 ? 00:00:00 python /home/alancarslaw/PlexConnect/PlexConnect.py 2>&1 >/dev/null
root 13051 13048 0 Feb20 ? 00:00:04 python /home/alancarslaw/PlexConnect/PlexConnect.py 2>&1 >/dev/null
root 13052 13048 0 Feb20 ? 00:00:25 python /home/alancarslaw/PlexConnect/PlexConnect.py 2>&1 >/dev/null
root 13053 13048 0 Feb20 ? 00:00:25 python /home/alancarslaw/PlexConnect/PlexConnect.py 2>&1 >/dev/null
Hope someone will be able to help me here
