Hi all,
I'm running PlexConnect on Ubuntu 13.10 using the Trailers app on Apple TV 3. I updated to the Apple TV 7.0 software this week, and.. PlexConnect no longer wants to work. I downloaded the latest version, as well as the patched .py files from earlier in this thread and still no go.
When I launch the Trailers app, it finds my Plex library, and I'm able to browse it with no problems. But as soon as I try to play anything, I get "Trailers is unavailable. Please try again later."
Here's what I get at the command prompt when running PlexConnect.py.. anyone have any ideas?
$ sudo python /usr/local/lib/PlexConnect-master/PlexConnect.py
11:25:33 PlexConnect: ***
11:25:33 PlexConnect: PlexConnect
11:25:33 PlexConnect: Press CTRL-C to shut down.
11:25:33 PlexConnect: started: 11:25:33
11:25:33 PlexConnect: Version: 0.4-dev
11:25:33 PlexConnect: Python: 2.7.5+ (default, Sep 19 2013, 13:48:49)
[GCC 4.8.1]
11:25:33 PlexConnect: Host OS: linux2
11:25:33 PlexConnect: IP_self: 192.xxx.xxx.50
11:25:33 DNSServer: started: 11:25:33
11:25:33 DNSServer: ***
11:25:33 DNSServer: DNSServer: Serving DNS on 192.xxx.xxx.50 port 53.
11:25:33 DNSServer: intercept: ['trailers.apple.com'] => 192.xxx.xxx.50
11:25:33 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
11:25:33 DNSServer: forward other to higher level DNS: 192.xxx.xxx.1
11:25:33 WebServer: started: 11:25:33
11:25:33 WebServer: ***
11:25:33 WebServer: WebServer: Serving HTTP on 192.xxx.xxx.50 port 80.
11:25:33 WebServer: WebServer: Serving HTTPS on 192.xxx.xxx.50 port 443.
11:25:40 DNSServer: DNS request received!
11:25:40 DNSServer: Source: ('192.xxx.xxx.163', 55784)
11:25:40 DNSServer: Domain: trailers.apple.com
11:25:40 DNSServer: ***intercept request
11:25:40 DNSServer: -> DNS response: 192.xxx.xxx.50
11:25:40 WebServer: serving /js/application.js
11:25:40 WebServer: serving .xml: /
11:25:40 PlexAPI: ***
11:25:40 PlexAPI: looking up Plex Media Server
11:25:40 DNSServer: Source: ('192.xxx.xxx.163', 50703)
11:25:40 DNSServer: Domain: p6-buy.itunes.apple.com
11:25:40 DNSServer: ***forward request
11:25:41 DNSServer: -> DNS response from higher level
11:25:41 PlexAPI: GDM: Servers discovered: 1
11:25:41 PlexAPI: Servers (local+MyPlex): 1
11:25:41 WebServer: serving .xml: /PlexConnect.xml
11:25:41 WebServer: serving /js/utils.js
11:25:41 WebServer: serving .xml: /library/sections
11:25:42 WebServer: serving /js/utils.js
11:25:42 WebServer: serving /js/sectionHoldSelect.js
11:25:42 WebServer: serving .xml: /library/sections/1/recentlyAdded
11:25:48 WebServer: serving .xml: /library/sections/1
11:25:48 WebServer: serving /js/utils.js
11:25:49 WebServer: serving .xml: /library/sections/1/recentlyAdded/recentlyAdded
11:25:52 WebServer: serving .xml: /library/sections/1/recentlyAdded
11:25:53 WebServer: serving /js/utils.js
11:25:56 WebServer: serving .xml: /library/metadata/13287
11:25:56 XMLConverter: XML_ExpandLine - Found unknown cmd SVAL in line playTrailer('{{SVAL(Video/title)}}','{{VAL(Video/year)}}')
11:25:57 WebServer: serving /js/utils.js
11:25:57 WebServer: serving /js/selectAudioAndSubs.js
11:26:00 WebServer: serving .xml: /library/metadata/13287
11:26:00 WebServer: serving /js/utils.js
11:26:03 WebServer: serving .xml: /library/metadata/13287
11:26:03 XMLConverter: XML_ExpandLine - Found unknown cmd SVAL in line playTrailer('{{SVAL(Video/title)}}','{{VAL(Video/year)}}')
11:26:03 WebServer: serving /js/utils.js
11:26:03 WebServer: serving /js/selectAudioAndSubs.js
11:27:39 DNSServer: DNS request received!
11:27:39 DNSServer: Source: ('192.xxx.xxx.163', 55204)
11:27:39 DNSServer: Domain: 33-courier.push.apple.com
11:27:39 DNSServer: ***forward request
11:27:39 DNSServer: -> DNS response from higher level
