No. You have to update on a different plexconnect host then sftp the new version over. I have been thinking about a way to make a have my .deb from another post that you can install from nitoTV but no eta or guarantee if & when that will happen if possible.
Looks like saurik or whomever maintains SQLite3 deb has updated the code for the ios 5.3 jb. Just type this in a terminal window:
apt-get -f install
This will correct the dependency that was missing so you can install any of the updated appletv flash black plugins or other nito-tv apps for ios 5.3 and properly installs python.
Now I can use rowmote to control plexconnect so I don’t have to search for a remote now I just have to find any ios device for controlling my entire atv2
-update
This also fixed the reboot issue on the 5.3 jb that would cause the atv to reboot a few times to load the main screen, it now boots up straight away nice!
If it removes your python just run these commands followed by a reinstall of python from the OP:
Cheers, I have managed to install Plexconnect on my apple tv2 and it has its own app on the screen it is not in the trailers app, Is there a myplex setting so I can enter a username and password or do you have to set it up different??
I found the settings file thank you, and I put my username and password in and rebooted my Atv, when I select the Plex Connect icon on the Atv’s home screen it says “not available please try later” do you access plex through the plex connect icon or the trailer icon because I am sure I read in previous posts it was through the trailer icon.
Anyway there is no plex library content in the trailer icon also.
Yes I have copied my settings, do I have to put the ip address of my pms or is just putting my user name and password in the settings file all I need??
connect via terminal to the apple tv and just type "Python" it will tell u which version u installed. my atv2 stays in my living room so i set the ip_pms to the ip adress of my mac running pms
@f00b4r just upgraded plexconnect on my atv to the latest build on github and everything works fine but in settings i get ((ERROR:SETTING)) on home video view and subtitle renderer and the version stills says 0.3.1+ can i fix this somehow ?
If I type Python in terminal I get this message -sh: Python: command not found
Also I have noticed when I am installing ./install.bash I get a certificate error, please find below
Apple-TV:/private/var/root/PlexConnect/support/OSX root# ./install.bash SSL certificate /private/var/root/PlexConnect/assets/certificates/trailers.pem not found. - is it stored in a different place? -> make sure to edit Settings.cfg and restart PlexConnect - did you already create one? -> run createcert.bash Installing PlexConnect… Starting PlexConnect… com.plex.plexconnect.bash: Already loaded - 127 com.plex.plexconnect.bash
Post #127 in this topic has a full tutorial for ios 5.3 which is what I assume you are running, it really doesn’t get much easier then that. All the questions you keep asking have been anwsered in that tutorial if you followed it.
