I'm note sure it's related to this project or any previous attempt :)
But i can't login in to my photo station anymore LAN: 10.0.1.2/photo => Page couldn't be find, same error for 10.0.1.2/web/index.html
I have checked every thing i could think of incl. that Apace is running. Could I have change something like the DNS, web on 81 that I now have to reset.
I tried to uninstall this packages but still have the same problem.
Pls help :)
If you changed the Apache port to a differnt port number rather than setting up a reverse proxy you may have caused it.
The best thing might be to reverse it and then use the reverse proxy setup to avoid any issues with e.g. Photo Station.
I have a DS1812 and an ATV3 and I didn't install plexconnect yet since I read that there were issues in the beginning with Synology and plexconnect. Now I wanna give it a try and to be honest when I read thru this thread it is very confusing.
Is there a tutorial how to install the new package or can someone summarize real quick (copy+paste with links) how to start from scratch with the latest release?
I'm having problems using AppleTV 3, Plex Media Server 0.9.7.22 (Synology Package), and plexconnect_noarch_0.1-1 on my DiskStation DS213.
I've set up PMS with several channels, but when I go to Channels > The Daily Show, I get the error "Plex Connect - No response from Plex Media Server".
13:52:46 PlexConnect: started: 13:52:46
13:52:46 PlexConnect: ***
13:52:46 PlexConnect: PlexConnect
13:52:46 PlexConnect: Press CTRL-C to shut down.
13:52:46 PlexConnect: IP_self: 10.0.1.64
13:52:46 DNSServer: started: 13:52:46
13:52:46 DNSServer: ***
13:52:46 DNSServer: Starting up.
13:52:46 DNSServer: intercept trailers.apple.com: 10.0.1.64
13:52:46 DNSServer: forward other to higher level DNS: 8.8.8.8
13:52:46 WebServer: started: 13:52:46
13:52:46 WebServer: ***
13:52:46 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 81.
13:52:46 PlexGDM: ***
13:52:46 PlexGDM: looking up Plex Media Server
13:52:47 PlexGDM: servers discovered: 1
13:52:47 XMLConverter: PlexGDM - PMS: 10.0.1.64:32400
13:53:09 DNSServer: DNS request received!
13:53:09 DNSServer: Source: ('10.0.1.13', 49212)
13:53:09 DNSServer: Domain: p3-buy.itunes.apple.com.akadns.net
13:53:09 DNSServer: ***forward request
13:53:09 DNSServer: -> DNS response from higher level
13:53:11 DNSServer: DNS request received!
14:26:07 DNSServer: DNS request received!
14:26:07 DNSServer: Source: ('10.0.1.13', 59577)
14:26:07 DNSServer: Domain: trailers.apple.com
14:26:07 DNSServer: ***intercept request
14:26:07 DNSServer: -> DNS response: 10.0.1.64
14:26:07 ATVLogger: loadURL (override): http://trailers.apple.com/video/thedailyshow
14:26:07 WebServer: serving .xml: /video/thedailyshow
14:26:17 XMLConverter: Unable to connect to 10.0.1.64:32400
Reason: timed out
14:26:17 XMLConverter: No Response from Plex Media Server
If I go directly to http:// 10.0.1.64:32400 /video/thedailyshow in my computers web browser, the page will take a little while to load, but it will load and display the xml file for the show. Any ideas why the XMLConverter is seeing no response, but everything else on the network is able to get a response? Thanks!
- Manually installed PlexConnect 0.1-1 (entered 8.8.8.8 at setup)
- Changed DNS at ATV3 to PMS
Problem is if I try to run it, it runs for about 2 seconds and then goes back to status "stopped". Here is the log:
Failed to create socket on UDP port 53: [Errno 98] Address Already in use
If I take a look in the settings.cfg, i get this:
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_dnsmaster = 8.8.8.8
ip_webserver = 0.0.0.0
loglevel = Normal
enable_dnsserver = True
ip_pms = 0.0.0.0
port_webserver = 81
So if I wanna change ip_pms to 192.168.1.10, it says permission denied (readonly file), if I then wanna change the permission with chmod it tells me operation not permitted.
Please some help, I'm a noob in ssh, but something is wrong here
Reason: timed out
Not all channels are supported at the moment, you may want to check in the channel sticky about specifics.
It looks as if you already have a DNS server running, have you installed the Synology DNS package?
Thanks for the reply. I'm able to load the Daily Channel, ABC, and other channels on my AppleTV if I run PlexConnect directly from my Mac. Unless there is something specific about Synology -> AppleTV, my issue does not appear to be a channel specific issue. Any other thoughts?
They might require transcoding by the PMS. Your Mac is powerful enough but your NAS is not (check the Plex wiki on NAS devices; there is also a link at the bottom to an Excel sheet that will tell you your NAS's capabilities).
