Install plex Apple TV 3 help
Hey friends I need help for install plex on my Apple TV with windows when I open the carpet plex connect in ms dos and type sudo ._plexconnect I received a error helpme please
No "sudo" for windows. :-D
In the correct directory, try "python PlexConnect.py".
Or just right click on PlexConnect.py and "open with" Python.
Sorry the guide Is for Mac And i have windows
Soñé body has a guide for windows
There is a link to install guides (OSX and Windows) in the sticky at the top of this forum.
Direct link: https://github.com/iBaa/PlexConnect/wiki/Windows-7-and-ATV-with-5.2-firmware-and-ethernet-internet-connection-installation-guide
I tryed the Python command And doesnt work ante body has a Windows guide please
That is a Windows guide.
Thanks for the guide letra try
In cmd How can i change the director y to plex Connect folder?
I have to change the dns?
Hello i did everything like the tutorial but when i open the app trailers in the Apple TV doesn work can any body help me ny fb please
You need to provide more information before anyone can help, see this:
https://github.com/iBaa/PlexConnect/wiki/How-to-report-an-issue
I have the Apple TV 3 firmware 5.1 my pc has Windows 7
In the DNs manual of the atv i change And put the ip oh my computer
Please copy and paste the questions on the link i gave you and fill all of the details in, not just some or "i put the IP address of my computer". It is extremely hard to see what error, if any you have made otherwise.
Also did you create a rule for python.exe in any firewall you run or disable it to see if that was an issue?
I dont create a rule for python.exe If nesesarry do that?
If you have a firewall running
Can any body helpme ny Facebook please
I must use Python?
