PlexConnect, Unblock-US and unRAID
Hi all
I´m having issues with PlexConnect (running on my unRAID server) and Unblock-US (DNS to change netflix regions).
My Unblock has been working when I used it directly in my Apple TV and its DNS settings. However, I can't get it to work when I use the following settings.cfg on my unRAID server and in my PlexConnect setup.
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 208.122.23.23
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = Normal
logpath = .
Could it be that I´m changing the wrong cfg file?
IP dnsmaster is what you change but make sure you reboot the ATV to get rid of any cached DNS entries.
Just wanted to chime in that it finally worked after rebooting my unRAID multiple times. Now all is working great.
