Plexconnect won't start after reboot
This morning I updated plex server to the latest version on my Mac. I rebooted the Mac and now plexconnect won't start. I included the log. I noticed reference to an IP address - 10.178.1.6. I have no idea what that IP is.
Log
Media-Hub:PlexConnect authorized$ sudo ./PlexConnect.py
21:46:12 PlexConnect: ***
21:46:12 PlexConnect: PlexConnect
21:46:12 PlexConnect: Press CTRL-C to shut down.
21:46:12 Settings: add option port_dnsserver=53
21:46:12 PlexConnect: started: 21:46:12
21:46:12 PlexConnect: IP_self: 10.178.1.6
21:46:12 DNSServer: started: 21:46:12
21:46:12 DNSServer: ***
21:46:12 DNSServer: DNSServer: Serving DNS on port 53.
21:46:12 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 10.178.1.6
21:46:12 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
21:46:12 DNSServer: forward other to higher level DNS: 8.8.8.8
21:46:12 WebServer: started: 21:46:12
21:46:12 WebServer: ***
21:46:12 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
21:46:12 PlexGDM: ***
21:46:12 PlexGDM: looking up Plex Media Server
Process Process-2:
Traceback (most recent call last):
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/multiprocessing/process.py", line 258, in _bootstrap
    self.run()
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/multiprocessing/process.py", line 114, in run
    self._target(*self._args, **self._kwargs)
  File "/Users/authorized/PlexConnect/WebServer.py", line 185, in Run
    XMLConverter.discoverPMS()
  File "/Users/authorized/PlexConnect/XMLConverter.py", line 221, in discoverPMS
    PMS_list = PlexGDM.Run()
  File "/Users/authorized/PlexConnect/PlexGDM.py", line 61, in Run
    GDM.sendto(Msg_PlexGDM, (IP_PlexGDM, Port_PlexGDM))
error: [Errno 49] Can't assign requested address
21:46:12 PlexConnect: WebServer not alive. Shutting down.
21:46:12 PlexConnect: Shutting down.
21:46:13 DNSServer: DNS request received!
21:46:13 DNSServer: Source: ('192.168.50.53', 62045)
21:46:13 DNSServer: Domain: phobos.apple.com
21:46:13 DNSServer: ***forward request
21:46:13 DNSServer: -> DNS response from higher level
21:46:13 DNSServer: Shutting down.
21:46:13 PlexConnect: shutdown
Figured it out. I also installed a VPN - Private Internet Access and that was the problem. Not sure why, but I disabled it and plexconnect works.
Brilliant, thanks.  I was having the exact same problem, but now that I've switched off my VPN it is working fine. Cheers.
It is because the VPN confuses things by introducing other IP addresses for your devices for its tunnel.
