few errors when I have vpn enabled
Hey
first of all, I browsed / search the forum quite some times now but I cant seem to figure this one out.
this is my log if it makes sense to any of you guys.
10:35:20 PlexConnect: started: 10:35:20
10:35:20 PlexConnect: ***
10:35:20 PlexConnect: PlexConnect
10:35:20 PlexConnect: Press ENTER to shut down.
10:35:20 PlexConnect: IP_self: 10.4.48.218
10:35:20 DNSServer: started: 10:35:20
10:35:20 DNSServer: ***
10:35:20 DNSServer: Starting up.
10:35:20 DNSServer: intercept trailers.apple.com: 10.4.48.218
10:35:20 DNSServer: forward other to higher level DNS: 8.8.8.8
10:35:20 WebServer: started: 10:35:20
10:35:20 WebServer: ***
10:35:20 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
10:35:20 PlexGDM: ***
10:35:20 PlexGDM: looking up Plex Media Server
Process Process-2:
Traceback (most recent call last):
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/multiprocessing/process.py", line 258, in _bootstrap
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/multiprocessing/process.py", line 114, in run
  File "/Users/yesme/Desktop/PlexConnect-XML_templates/WebServer.py", line 191, in Run
    XMLConverter.discoverPMS()
  File "/Users/yesme/Desktop/PlexConnect-XML_templates/XMLConverter.py", line 211, in discoverPMS
    if PlexGDM.Run()>0:
  File "/Users/yesme/Desktop/PlexConnect-XML_templates/PlexGDM.py", line 59, in Run
    GDM.sendto(Msg_PlexGDM, (IP_PlexGDM, Port_PlexGDM))
error: [Errno 49] Can't assign requested address
10:35:20 PlexConnect: WebServer not alive. Shutting down.
10:35:25 DNSServer: Shutting down.
If I disable VPN, it works perfect like this.
10:28:16 PlexConnect: started: 10:28:16
10:28:16 PlexConnect: ***
10:28:16 PlexConnect: PlexConnect
10:28:16 PlexConnect: Press ENTER to shut down.
10:28:16 PlexConnect: IP_self: 10.0.0.87
10:28:16 DNSServer: started: 10:28:16
10:28:16 DNSServer: ***
10:28:16 DNSServer: Starting up.
10:28:16 DNSServer: intercept trailers.apple.com: 10.0.0.87 (dns I have put in ATV, I realized this one is different when I have enabled VPN, but I tried mess with settings.cfg without any luck, It seems like whatever I try edit the changes doesnt apply.).
10:28:16 DNSServer: forward other to higher level DNS: 8.8.8.8
10:28:16 WebServer: started: 10:28:16
10:28:46 WebServer: ***
10:28:46 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
10:28:46 PlexGDM: ***
10:28:46 PlexGDM: looking up Plex Media Server
10:28:47 PlexGDM: servers discovered: 1
10:28:47 XMLConverter: PlexGDM - PMS: 10.0.0.87:32400
Im obviously not to much of a plex wiz yet, but hopefully there is someone who can help me out, thanks in advance...
nekiw,
I have the same problem.  I also feel like I've read on this forum people troubleshooting the issue but in a couple quick glances I didn't see anything.  I'm far from an expert but I suspect the issue has to do with PlexConnect's DNS server and/or web server being confused by the VPN altering your private IP to something public.
My way around the issue is to start PlexConnect before I start my VPN.  Without the VPN running, as you note, PlexConnect runs fine.  Then, once PlexConnect is running, you can connect your VPN and PlexConnect should continue to run properly.
It may well be the routing getting messed up but if you are using a VPN to get round geoblocking is there any reason you cannot switch to a DNS based service instead (these work fine with PlexConnect)?
I have the same problem. When using the VPN the script uses the VPN ip address instead of the host machine. There doesn't seem to be a way to configure this in the settings file.
It is not a supported configuration.
Why do you need to run a VPN?
