I have tried single "\" and double "\\" to no avail. Here is a copy of my config file. I only uploaded the parts that I have touched. Everything below the Filtering has been untouched.
# This Python file uses the following encoding: utf-8##Folder Paths# Windows Example: 'C:\\Users\\{User Name}\\AppData\\Local\\'# Linux Example: '/var/lib/plexmediaserver/Library/Application Support/'# Mac Example: '/Users/{User Name}/Library/Application Support/'plex_data_folder = 'C:\\Users\\Luke\\AppData\\Local\\'# Windows Example: 'C:\\wamp\\www\\'# Linux/Mac Example: '/var/www/'web_folder = 'C:\\xampp\\htdocs\\PlexEmail'##Generaldate_format = '%m/%d/%y'date_days_back_to_search = 1date_hours_back_to_search = 0date_minutes_back_to_search = 0##Image Upload - If this option is enabled, image hosting will be used for web and email#Cloudinary - Sign up for a free account at: http://cloudinary.com/upload_use_cloudinary = Trueupload_cloudinary_cloud_name = '*****'upload_cloudinary_api_key = '*****'upload_cloudinary_api_secret = '*****'##Webweb_enabled = True#This will not create the index.html file, but will still save the images to the images folder. (Useful for when you only want to send an email)web_only_save_images = Falseweb_domain = 'http://www.plexwebserver.info'web_path = 'plexemail'web_delete_previous_images = Trueweb_skip_if_no_additions = Trueemail_enabled = Trueemail_individually = False# ['email1@gmail.com', 'email2@hotmail.com']email_to = ['*****@gmail.com']email_from = '*****@gmail.com'email_from_name = 'Plex Server'email_smtp_address = 'smtp.gmail.com'email_smtp_port = 587email_use_ssl = False #Port must be an SSL port i.e. 465email_username = '*****@gmail.com'email_password = '*****'# Only valid if web_enabled = True and upload_use_cloudinary = Trueemail_use_web_images = Trueemail_skip_if_no_additions = True##Filteringfilter_include_plex_web_link = Truefilter_show_movies = Truefilter_show_shows = Truefilter_show_seasons = Truefilter_show_episodes = True#Name of libraries to filter out - ['Home Videos', 'Private']filter_libraries = []#The sections to include and ordering - tagline, summary, content_rating, duration, year, rating, studio, tags_genre, tags_director, tags_star
Hmm that looks good to me. Of the fields you masked (cloudinary fields and email info) do any of the values include a \
If so, could you add one more \ to it? If you don't, I can upload a new file with your info minus the filtered out stuff.
No "\"'s at all. The Cloudinary secret has 2 underscores(_) in it, but no slashes. I would be happy to send you my full config file if you could take a look at it? If you want send an email to plexwebserver@gmail.com and I will reply with the full file.
Thanks!
I think I found one that was missing. I now get the following error:
C:\xampp\htdocs\PlexEmail\scripts>plexEmail.pyTraceback (most recent call last):File "C:\xampp\htdocs\PlexEmail\scripts\plexEmail.py", line 689, indeleteImages()File "C:\xampp\htdocs\PlexEmail\scripts\plexEmail.py", line 159, in deleteImagesfor file in os.listdir(folder):WindowsError: [Error 3] The system cannot find the path specified: 'C:\\xampp\\htdocs\\PlexEmail\\plexemail\\images\\*.*'
Ok, that's good news!
The web_folder should be the path to the web directory, so in your case it should be 'C:\\xampp\\htcdocs\\
web_path under the Web section will automatically add it to the path (although if you want it in PlexEmail instead of plexemail, you will want to set web_path to PlexEmail).
I removed the PlexEmail from the web_folder and still had the same results. I then changed the web_path to PlexEmail and still no go. Same error:
Hmm, the error still indicates that plexemail is in both the web_folder and the web_path.
Set web_folder to: 'C:\\xampp\\htdocs\\'
and web_path to: 'PlexEmail'
Also, did you extract the web folder to C:\xampp\htcdocs\PlexEmail\?
I deleted everything and I am starting from scratch again because I believe there was something just out whack with my install. Question though. Do I need to put the contents of the web folder in the PlexEmail folder? Or just leave everything in the web folder nested under the PlexEmail folder?
After deleting everything and running the script again, I get the following:
Put the contents of the web folder into the PlexEmail folder. So for example the images folder will go here: C:\xampp\htdocs\PlexEmail\images\
Also for your web_domain could you end it with /. i.e. 'http://www.somedomain.com/'(I'll update the code for the next version to handle it both ways, but it needs it now)
C:\xampp\htdocs\plexemail\scripts>plexEmail.pyTraceback (most recent call last):File "C:\xampp\htdocs\plexemail\scripts\plexEmail.py", line 926, inimageInfo = processImage(hash, imageInfo['thumb'], 'episode', tvEpisodes[episode]['season_index'], tvEpisodes[episode]['index'])File "C:\xampp\htdocs\plexemail\scripts\plexEmail.py", line 224, in processImageshutil.copy(imgLocation, img)File "C:\Python27\lib\shutil.py", line 119, in copycopyfile(src, dst)File "C:\Python27\lib\shutil.py", line 83, in copyfilewith open(dst, 'wb') as fdst:IOError: [Errno 2] No such file or directory: 'C:\\xampp\\htdocs\\plexemail\\plexemail\\images\\7b2ef48214a0438718e3cb91d808fe8684b41211_1724546b10dcfe956b5ae1c04d7d05002b560e7b.jpg'
It still looks like there is a plexemail in the web_folder and a plexemail in the web_path. Could you send me another email with the config file. I'll make sure it looks good and update it if it needs updating.
Sent via email.
Your changes you proposed earlier did the trick! Thanks for all of the help! I am super pumped about this program.
Hey,
Just wondering if I could make a request? Or if it is already implemented maybe someone can point me in the right direction.
Here is my idea, when I download a new Series, I might get 60-80 shows in one day (depending how long the show has been around of course). As it is now, the email that is sent out will have data for each and everyone of those shows making for a really, really long email. Is there anyway to group these episodes of the same show into one listing?
Hey,
The script already handles that in a way, When it is creating the item for each episode it will check if the season it is a part of is also new. If the season is also new it will not add each individual episode to the list. Depending on the frequency that the script is running, some of the episodes might be added the first run of the script and won't be shown, but all other episodes added on the next run will be shown (since the season is not new anymore).
OK, that makes sense. What brought this up was there was some missing shows in a existing S02 and S04 and Sonarr was able to find and download them this week. So all of them were listed.
Hey, eadwyn. So the script has been running fine for me for weeks now, but I recently reazlied it had stopped. When I ran the script manually from the command line, this was my result:
C:\Python27\Scripts>python plexemail.py
File "plexemail.py", line 794, in
imageInfo = processImage(hash, imageInfo['thumb'], 'season', tvSeasons[seaso
n]['index'], 0)
File "plexemail.py", line 204, in processImage
cloudinaryURL = uploadToCloudinary(imgLocation)
File "plexemail.py", line 248, in uploadToCloudinary
response = cloudinary.uploader.upload(imgToUpload)
File "C:\Python27\Scripts\cloudinary\uploader.py", line 16, in upload
return call_api("upload", params, file = file, **options)
File "C:\Python27\Scripts\cloudinary\uploader.py", line 223, in call_api
raise Error(result["error"]["message"])
cloudinary.api.Error: Invalid image file
Any notions on what's happening here?
C:\Python27\Scripts>python plexemail.py Traceback (most recent call last): File "plexemail.py", line 794, in imageInfo = processImage(hash, imageInfo['thumb'], 'season', tvSeasons[seaso n]['index'], 0) File "plexemail.py", line 204, in processImage cloudinaryURL = uploadToCloudinary(imgLocation) File "plexemail.py", line 248, in uploadToCloudinary response = cloudinary.uploader.upload(imgToUpload) File "C:\Python27\Scripts\cloudinary\uploader.py", line 16, in upload return call_api("upload", params, file = file, **options) File "C:\Python27\Scripts\cloudinary\uploader.py", line 223, in call_api raise Error(result["error"]["message"]) cloudinary.api.Error: Invalid image fileAny notions on what's happening here?
Looks like and error with the API call to cloudinary. I start by checking your creds and make sure that part is still working.
Just checked my credentials, and everything appears to be working fine. Cloud name, API key and API secret are correct, and I can even see the thumbnails for the recently added content in my Cloudinary account. I have no idea why this is all of a sudden not working...
Do you have any firewalls (peerblock?) that might block a connection?
Please try this modified script that will output some info regarding the files being uploaded. From the error it looks like the file might not be an actual image. Please give me the output after running the script.
plexEmail.zip (9.9 KB)
