PlexEmail - Email Recently Added Media
I think I figured it out.  Could you add http:// to the start of web_domain?
You are the man!!! i added http:// also did:
python -V
And version of the python sqlite:
python
import sqlite3
sqlite3
.version
sqlite3
.sqlite_version
And :
apt-get install python-virtualenv
apt-get install python-pip
http://thuis.darkonline.nl:10002/plexemail/
The layout is fine or ?
Move the contents of the /plexemail/web folder up one level into /plexemail.
Is it possible to add a name instance of a e-mail adres where is come from?
and how about the images of one week ? after this it will be deleted ? when the new week has been created ?
Also on hotmail the images not working.. no spam no block so far i can see on my .nl domain it works fine now
If i let send the python script the mail the images getting this as images info:
https://dub120.mail.live.com/Handlers/ImageProxy.mvc?bicild=&canary=i7wXUIO0%2bTtD0MJJGoMlWJcJKt3xG2N0xVjX1p%2baC14%3d0&url=http%3a%2f%2fthuis.darkonline.nl%3a10002%2fplexemail%2fimages%2fb6938463cc8cb255a09190de26d8d65add6757f1.jpg
This don't work
If i send a email with the location of the link online in a mail then it will work on hotmail
https://dub120.afx.ms/att/GetInline.aspx?messageid=61f35509-c678-11e4-9bfb-002264c249b4&attindex=0&cp=-1&attdepth=0&imgsrc=cid%3apart1.07040400.00070902%40beeksoft.nl&cid=89698f9c7a391d2d&shared=1&hm__login=*******&hm__domain=hotmail.com&ip=10.111.8.8&d=d1278&mf=0&hm__ts=Mon%2c%2009%20Mar%202015%2016%3a24%3a32%20GMT&st=robert212&hm__ha=01_1cd0e7e5643e1f58890718ee8fbe3cab7cecd3b29d7cb918987f417f316ec3e2&oneredir=1
I edited this link because my e-mail is on it :)
This can now be configured in the new field: email_from_name
Find it in the latest release: https://github.com/jakewaldron/PlexEmail/releases/tag/v0.2.5
This can now be configured in the new field: web_delete_previous_images
Note: If emails are using direct links to your site, old emails will have broken links if this setting is set as True
This don't work
It appears this is a known issue with hotmail, but I can't find a solution.  It might have to do with hotmail blocking the port.
hey eadwyn there is some problem with the pictures attached in the mail, in website is perfect
Hotmail account :
Some pictures arent showing
Outlook :
All pictures are showing but some are huge some are normal
Hotmail account :
Outlook :
Hotmail seems to have a lot of issues.  Are you trying to attach the images to the email or using the images from your web server?
For the outlook issue, I think I have fixed it in the latest release: https://github.com/jakewaldron/PlexEmail/archive/v0.2.6.zip
1 images working on hotmail other 15 not
What's the URL of the one image that is working?
Working for me:
https://dub120.mail.live.com/Handlers/ImageProxy.mvc?bicild=&canary=i07LRQONyzflKUwZjJ%2bgPpSgZIpmZwEl0R2xZdhbbAA%3d0&url=http%3a%2f%2fimage.tmdb.org%2ft%2fp%2foriginal%2fe0etqHTsH7kSKR5orkUM5TjHXmy.jpg
Working not :
https://dub120.mail.live.com/Handlers/ImageProxy.mvc?bicild=&canary=i07LRQONyzflKUwZjJ%2bgPpSgZIpmZwEl0R2xZdhbbAA%3d0&url=http%3a%2f%2fthuis.darkonline.nl%3a10002%2fplexemail1%2fimages%2f8d0cf10e781dff0016df0ea628e3b1c8bec22e1e.jpg
As I thought.  The first image is hosted elsewhere.  I think the hotmail image proxy doesn't like the port you are using for your website and is not getting the image.  I'm not sure what can be done with hotmail right now since it seems to have issue with attaching a large amount of images directly and their image proxy being super strict.
I'll look into implementing a third option for images: Uploading to an image hosting site (i.e. Imgur) then using those in the email.
I will test port 80 instance of 10002 i will let you know in few seconds
ok i tested with port 80 and working fine!!!
https://dub120.mail.live.com/Handlers/ImageProxy.mvc?bicild=&canary=i07LRQONyzflKUwZjJ%2bgPpSgZIpmZwEl0R2xZdhbbAA%3d0&url=http%3a%2f%2fthuis.darkonline.nl%2fplexemail1%2fimages%2f7e2a80b7aeb357be6170cf4720abf3c2dc25a0ac.jpg
https://dub120.mail.live.com/Handlers/ImageProxy.mvc?bicild=&canary=i07LRQONyzflKUwZjJ%2bgPpSgZIpmZwEl0R2xZdhbbAA%3d0&url=http%3a%2f%2fthuis.darkonline.nl%2fplexemail1%2fimages%2f72613899f39cb06b8a727401c1d3251548c978cc.jpg
https://dub120.mail.live.com/Handlers/ImageProxy.mvc?bicild=&canary=i07LRQONyzflKUwZjJ%2bgPpSgZIpmZwEl0R2xZdhbbAA%3d0&url=http%3a%2f%2fthuis.darkonline.nl%2fplexemail1%2fimages%2face0b1360c4ef71044fde31fd12d52b4ffa8d0c0.jpg
All codes are now the same and displaying
Awesome!  Wasn't sure you had access to the default http port, but glad you do and it's working.  I think I will still implement the option to upload to imgur for people who do not have that option or a web server.
haha ;) i have a local nas and dedicated server located in a datacenter so can test like hell :P
v0.3.0 Released
Added the ability to use external image hosting (Cloudinary) for email and web images.  Added the following configuration options to the config file:
Cloudinary - Sign up for a free account at: http://cloudinary.com/
  • upload_use_cloudinary - Use Cloudinary image hosting
  • upload_cloudinary_cloud_name - Cloudinary cloud name
  • upload_cloudinary_api_key - Cloudinary api key
  • upload_cloudinary_api_secret - Cloudinary api secret
Release: https://github.com/jakewaldron/PlexEmail/releases/tag/v0.3.0
Zip: https://github.com/jakewaldron/PlexEmail/archive/v0.3.0.zip
Tar: https://github.com/jakewaldron/PlexEmail/archive/v0.3.0.tar.gz
This might be outside the scope of what you envisioned this for but would there be a way to configure it to gather recently added based on the number hours instead (or in addition to) of days?
Currently I'm using it to send a daily update, there are 2 options, setting the days to 1 or 0. If I set it to 1 there is overlap everyday, if I set it to 0 anything added after the email is sent will never get included in an email as the next one will be the next day. Does that make sense?
I envision being able to set it to 24 hours, and if I send a daily update out at 5:00pm, it would only include things added since yesterday at 5:00pm.
Like I said if it's out of scope no biggie, just curious it if was possible.
I'm really digging being able to notify my friends about what's been added recently like this. It's great. Thank you for all the hard work you put into this.
Good idea, didn't really cross my mind for daily newsletters when I was doing this.  Here is the latest release:
https://github.com/jakewaldron/PlexEmail/releases/tag/v0.3.1
Relevant new config fields for you are:
  • date_use_hours
  • date_hours_back_to_search
v0.3.1 Released
New feature and code cleanup
  • Can now search backwards by hours instead of just days
  • Will not display categories if empty
