PlexEmail - Email Recently Added Media
  1. 32 bit DLL for SQLite version 3.8.8.3 - http://www.sqlite.or...x86-3080803.zip (Put this into the DLLs folder of the Python installation)
I HAVE to have Python installed on my machine (I use it for Sick Beard), but for the life of me I cannot find this DLL folder. Any ideas where I can look?
Running the script at this point gets me this error:
Traceback (most recent call last):
  File "plexEmail.py", line 509, in
    con = sqlite3.connect(DATABASE_FILE)
sqlite3.OperationalError: unable to open database file
Windows?  If yes, then run the following on the command line:
where python
That should tell you where the installation is located.
Thanks,
Still no go though. Had to compile Python2.7.9 using these instructions (otherwise it compiles without zlib): http://stackoverflow.com/a/27132584
sqlite3 still not the correct version though:
I'm going to try to get a dev box this weekend up and running so I can install CentOS and try to get it working.
where python
Sorry, I'm on Mac (Yosemite).
You might be the first to test on Mac (or it works flawlessly and no one has commented).  I'm excited to get this working for you so I can change it to tested!
This might already be installed.  Could you try skipping this step?
EDIT: I think the default location for the lib folder is here: /usr/lib/python2.7
Hi there,
What version of Python are you running?
python -V
Looks like I was running 2.6.6
The latest version i could find on unraid was 2.7.3 . I'm now getting this error:
  File "plexEmail.py", line 778, in
    emailTVEpisodes += '
S' + str(tvEpisodes[episode]['season_index']) + ' E' + str(tvEpisodes[episode]['index']) + ': ' + title + '
' UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in position 40: ordinal not in range(128)
I guess I'll have to switch to windows instead.
No, because of the aforementioned error when I try to run the script:
Actually that is good news.  Your setup is now where it should be.  This error is actually a bug fix that I put in this morning (haven't pushed a new release yet).
Try this file: plexEmail.zip (9.07 KB)
EDIT: After looking closer at the error, it might be a problem with the path to the database file.  Could you give me the value for plex_data_folder in the config file?
Sorry, juggling a few different issues at the same time.  Could you try downloading and putting it here: /usr/lib/python2.7 (that is the default location on Mac)
Actually the Mac file is this: http://www.sqlite.org/2015/sqlite-shell-osx-x86-3080803.zip
Found the folder and moved the sqlite3 file into it (it was already there, so I just replaced). Now seeing this:
  File "plexEmail.py", line 1, in
    import sqlite3
ImportError: No module named sqlite3
    import sqlite3
Shoot.  My edit must have not been in time.  It looks like the previous version might have been working.
To fix it, could you download this and put the lib folder inside that tar into /usr/lib/python2.7/sqlite3/:
https://pypi.python.org/packages/source/p/pysqlite/pysqlite-2.6.3.tar.gz#md5=7ff1cedee74646b50117acff87aa1cfa
The other file you downloaded should have gone into /usr/bin/
Could you also give me the value you have for plex_data_folder  in the config folder?
Sorry for the inconvenience!
There is no folder called 'sqlite3 ' in /usr/lib/python2.7, and when I tried to create one, it said the name was already taken.
/Library/Application Support/Plex Media Server
That's because of the previous file you put in there (I gave you the wrong location).  Could you delete the file sqlite3 in that folder? Then try to create it and put those files in.
If we can't get it working, I'll bring a mac home from work to try and get it working over the weekend.
OK, done. Same error.
Darn, I'm going to start installing PMS on the mac I have here then try it out myself.
Just to clarify: the sqlite3 file you originally sent me you wanted in the usr/bin/ folder, correct? Because it was already there, and I replaced it.
Try this file: attachicon.gifplexEmail.zip
Woohoo, looks like the web and email is now working on my Unraid Server now.
Unrelated, but is there a way to just display the latest movies and not tv seasons/episodes?
Good news!
Not right now, but that's a good idea and I will add that in later.
A more few ideas :)
  1. Genre in Movie Description
  2. Filter based on Genre (Email with just new Horror Movies this week)
  3. Filter based on Content Rating (So we can have a Plex Email just for Kids)
Thank you, this is great.
