Plexhtpc_1.15.0.863-070c3c4b_amd64.deb?
Does anyone still have the plexhtpc_1.15.0.863-070c3c4b_amd64.deb. installer? The flatpak and snap are not working properly.
I’m guessing that after I told you that HTPC was never released outside of a flatpak/snap, you figured I was wrong and started a new thread to try and find one.
The version number you are asking about does not correspond to any version of HTPC, ever made. While there was a 1.15.0 of HTPC in the past, it does not have the build number of 863. Furthermore, there is no commit 070c3c4b in the repository from which it is built.
What you are asking for is either not HTPC or it is fake.
After a reboot, everything started to work. I have no idea what actually was a problem since I’ve been troubleshooting for two days,but anyway it’s solved.
