.plexignore problem
I think there may be a problem with .plexignore. In most of my photo subfolders, I have hidden folders called [Originals] with the unedited versions that I want to exclude.
My .plexignore file is in the root (top-level) folder and contains the line:
[Originals]/*
However, Plex DOES NOT exclude files from these folders.
I know my .plexignore file is being recognized and used because Plex is excluding other files and subfolder including these:
Originals/*
I think the problem may be with the brackets used “”. I have seen other support posts with people with similar problems using [subfolders] as well as with subfolders with russian characters (non-ASCII) etc. Unfortunately, the square brackets are used with my photo editing program, ACDSee, and I don’t think that I can change them.
Can you please verify this?
Edited by sa2000 replacing # with * and putting the text within code markdown characters
Yes, further testing shows that it is a bug. If I rename the folders to Originals instead of [Originals], everything works as expected. How do we report a bug?
This has already been reported as an issue. I will add a note to that issue and add link to your forum topic
Thanks @trumpy81
@bmorgy - please let us know if that gets round the problem
PS
#recycle should be skipped without need for entry in .plexignore
@sa2000 - Yes @trump81’s suggestion works. Thank you for that. However, I think that this will also exclude any photos with “Originals” in the filename. Fortunately, this doesn’t impact me, but I hope that Plex continues to fix this bug in .plexignore so that it works as documented.
@bmorgy so did you have the following syntax to get round the problem to exclude folder names in square brackets
*[Originals]/*
@sa2000, no, I used the following lines:
*Originals*
Originals/*
[Originals]/*
Probably overkill, but it works. I will try to narrow it down to *[Originals]/* tonight.
