Plexinc/pms-docker:plexpass is failing to start
Help. After recreating my docker plex media server, it starts downloading PMS and just hangs eventually timing out and failing. I don’t think its my internet connection.
Attempting to upgrade to: 1.18.0.1846-f62172e99
curl: (56) GnuTLS recv error (-54): Error in the pull function.
Failed to fetch update
[cont-init.d] 50-plex-update: exited 1.
I successfully upgraded to 1.18.0.1846-f62172e99 last week sometime but saw a notification for a new version today and a restart attempted to downgrade. Here’s an excerpt from the docker log:
[cont-init.d] 50-plex-update: executing...
/config/Library/Application Support/Plex Media Server/Preferences.xml:1.1: Document is empty
Attempting to upgrade to: 1.17.0.1841-d42cfa161
dpkg: warning: downgrading plexmediaserver from 1.18.0.1846-f62172e99 to 1.17.0.1841-d42cfa161
(Reading database ... 10673 files and directories currently installed.)
Preparing to unpack /tmp/plexmediaserver.deb ...
Unpacking plexmediaserver (1.17.0.1841-d42cfa161) over (1.18.0.1846-f62172e99) ...
Setting up plexmediaserver (1.17.0.1841-d42cfa161) ...
#  NOTE: Your system does not have udev installed. Without udev  #
#        you won't be able to use DVBLogic's TVButler for DVR    #
#        or for LiveTV                                           #
#        Please install udev and reinstall Plex Media Server to  #
#        to enable TV Butler support in Plex Media Server.       #
#        To install udev run: sudo apt-get install udev          #
Processing triggers for libc-bin (2.23-0ubuntu10) ...
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Starting Plex Media Server.
Error in command line:the argument for option '--serverUuid' should follow immediately after the equal sign
Crash Uploader options (all are required):
  --directory arg       Directory to scan for crash reports
  --serverUuid arg      UUID of the server that crashed
I also noticed that the docker tag has now changed from plexpass to beta but there’s no sign of the 1.18.0.1846-f62172e99 tag!
Tried it again and it looks like it successfully starts ( version 1.17.0.1841-d42cfa161) but I haven’t been able to connect. I’m guessing that this may have something to do with the DB being upgraded with the 1.18 release (including me manually updating the music libraries) and is no longer compatible with version 1.17.
