Error after upgrading plexinc/pms-docker plexpass to 1.15.0.647-67e950f12
Server Version#:1.15.0.647-67e950f12
This morning my pms-docker running on synology started an upgrade and it’s inaccessible in an error loop ever since.
Posting a log here. Can you please help how to resolve it?
Thank you, Matus
2019-02-07 05:02:18,stdout,/usr/lib/plexmediaserver/Plex Media Server: error while loading shared libraries: libva.so.2: cannot open shared object file: No such file or directory
2019-02-07 05:02:18,stdout,Starting Plex Media Server.
2019-02-07 05:02:17,stdout,/usr/lib/plexmediaserver/Plex Media Server: error while loading shared libraries: libva.so.2: cannot open shared object file: No such file or directory
2019-02-07 05:02:17,stdout,Starting Plex Media Server.
2019-02-07 05:02:17,stdout,[services.d] done.
2019-02-07 05:02:17,stdout,[services.d] starting services
2019-02-07 05:02:17,stdout,[cont-init.d] done.
2019-02-07 05:02:17,stdout,[cont-init.d] 50-plex-update: exited 0.
2019-02-07 05:02:17,stdout,Processing triggers for systemd (229-4ubuntu19) …
2019-02-07 05:02:16,stdout,Processing triggers for libc-bin (2.23-0ubuntu9) …
2019-02-07 05:02:16,stdout,##################################################################
2019-02-07 05:02:16,stdout,# #
2019-02-07 05:02:16,stdout,# To install udev run: sudo apt-get install udev #
2019-02-07 05:02:16,stdout,# to enable TV Butler support in Plex Media Server. #
2019-02-07 05:02:16,stdout,# Please install udev and reinstall Plex Media Server to #
2019-02-07 05:02:16,stdout,# or for LiveTV #
2019-02-07 05:02:16,stdout,# you won’t be able to use DVBLogic’s TVButler for DVR #
2019-02-07 05:02:16,stdout,# NOTE: Your system does not have udev installed. Without udev #
2019-02-07 05:02:16,stdout,Installing new version of config file /etc/init/plexmediaserver.conf …
2019-02-07 05:02:16,stdout,Setting up plexmediaserver (1.15.0.647-67e950f12) …
2019-02-07 05:02:03,stdout,Unpacking plexmediaserver (1.15.0.647-67e950f12) over (1.14.1.5488-cc260c476) …
2019-02-07 05:02:02,stdout,Preparing to unpack /tmp/plexmediaserver.deb …
2019-02-07 05:02:02,stdout,(Reading database …
(Reading database … 5%
(Reading database … 10%
(Reading database … 15%
(Reading database … 20%
(Reading database … 25%
(Reading database … 30%
(Reading database … 35%
(Reading database … 40%
(Reading database … 45%
(Reading database … 50%
(Reading database … 55%
(Reading database … 60%
(Reading database … 65%
(Reading database … 70%
(Reading database … 75%
(Reading database … 80%
(Reading database … 85%
(Reading database … 90%
(Reading database … 95%
(Reading database … 100%
(Reading database … 10721 files and directories currently installed.)
2019-02-07 05:02:00,stdout,
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0
6 77.5M 6 4958k 0 0 3014k 0 0:00:26 0:00:01 0:00:25 5054k
11 77.5M 11 9294k 0 0 3512k 0 0:00:22 0:00:02 0:00:20 4687k
19 77.5M 19 15.4M 0 0 4341k 0 0:00:18 0:00:03 0:00:15 5307k
28 77.5M 28 21.7M 0 0 4804k 0 0:00:16 0:00:04 0:00:12 5606k
35 77.5M 35 27.4M 0 0 4988k 0 0:00:15 0:00:05 0:00:10 5653k
43 77.5M 43 33.3M 0 0 5142k 0 0:00:15 0:00:06 0:00:09 5843k
49 77.5M 49 38.7M 0 0 5184k 0 0:00:15 0:00:07 0:00:08 6068k
58 77.5M 58 45.1M 0 0 5350k 0 0:00:14 0:00:08 0:00:06 6086k
67 77.5M 67 52.4M 0 0 5572k 0 0:00:14 0:00:09 0:00:05 6284k
76 77.5M 76 59.2M 0 0 5704k 0 0:00:13 0:00:10 0:00:03 6512k
83 77.5M 83 64.4M 0 0 5670k 0 0:00:14 0:00:11 0:00:03 6371k
89 77.5M 89 69.5M 0 0 5633k 0 0:00:14 0:00:12 0:00:02 6320k
98 77.5M 98 76.2M 0 0 5724k 0 0:00:13 0:00:13 --:–:-- 6369k
100 77.5M 100 77.5M 0 0 5726k 0 0:00:13 0:00:13 --:–:-- 6079k
2019-02-07 05:01:46,stdout,
100 188 0 188 0 0 410 0 --:–:-- --:–:-- --:–:-- 410
2019-02-07 05:01:46,stdout, Dload Upload Total Spent Left Speed
2019-02-07 05:01:46,stdout, % Total % Received % Xferd Average Speed Time Time Time Current
2019-02-07 05:01:46,stdout,Attempting to upgrade to: 1.15.0.647-67e950f12
2019-02-07 05:01:40,stdout,[cont-init.d] 50-plex-update: executing…
2019-02-07 05:01:40,stdout,[cont-init.d] 40-plex-first-run: exited 0.
2019-02-07 05:01:39,stdout,[cont-init.d] 40-plex-first-run: executing…
2019-02-07 05:01:39,stdout,[cont-init.d] executing container initialization scripts…
2019-02-07 05:01:39,stdout,[fix-attrs.d] done.
2019-02-07 05:01:39,stdout,[fix-attrs.d] applying ownership & permissions fixes…
2019-02-07 05:01:39,stdout,[s6-init] ensuring user provided files have correct perms…exited 0.
2019-02-07 05:01:39,stdout,[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
make sure you pull the latest pms-docker:plexpass with docker pull - otherwise it doesn’t support the latest version of the server.
Yeah I use the LSIO docker and had the same issue.
Updated the container and viola back to working…
I am also experiencing issues with the last version of the PlexPass Docker —
As a result, all of my applications (Android, AndroidTV, iOS) crash immediately with no warnings or error messages. This goes on in a loop irregardless of network, device type, re-installing, etc.
OS: Unraid
Plex Type: Docker (plexinc/pms-docker:plexpass)
Plex Version: Version 1.15.0.659
Things attempted while troubleshooting:
  • Restart the Docker container
  • Restart the entire server itself
  • Restart the entire network
  • Release/renew IP’s
  • Nuked the Docker container and re-created it
  • Force updated the container to 15.x version
  • Signed out of Plex on the server and signed back in
  • Wipe data and cache for Plex apps
  • Shared crash reports via Google 20+ times
  • Enabled verbose and debug logging and dug through those (no errors or warnings found)
  • Dove into the config and deleted cert files so they would be re-created on Plex startup
  • Poured through Google results, plex forum threads, reddit posts, etc.
I’m running out of ideas. Could something be going on with either Plex auth token servers, my account or connections associated with it?
Thank you in advance for your review.
How do I do this? I am no expert.
I have stopped the docker container. should I start it?
docker pull plexinc/pms-docker or something like that depending on your setup.
and where on my synology? sorry I am a noobie
I have already done this step, yet my errors persist. :cry:
connected via putty, entered docker pull plexinc/pms-docker and this is my error:
Using default tag: latest
Warning: failed to get default registry endpoint from daemon (Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get http://%2Fvar%2Frun%2Fdocker.sock/v1.29/info: dial unix /var/run/docker.sock: connect: permission denied). Using system default: https://index.docker.io/v1/
Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post http://%2Fvar%2Frun%2Fdocker.sock/v1.29/images/create?fromImage=plexinc%2Fpms-docker&tag=latest: dial unix /var/run/docker.sock: connect: permission denied
[1]+ Done(127) Got permission denied while trying to connect to the Docker daemon socket at uni x:///var/run/docker.sock: Post http://%2Fvar%2Frun%2Fdocker.sock/v1.29/images/cr eate?fromImage=plexinc%2Fpms-docker
Put sudo in front of the command, then run it.
Post some logs and hopefully the devs that work on it can have a look. I am told it should work if you pull the latest container from the official place.
Thank you for having patience with me. Upgrading now. Will report back.
Still the same error:
/usr/lib/plexmediaserver/Plex Media Server: error while loading shared libraries: libva.so.2: cannot open shared object file: No such file or directory stdout
21:13:22
I’ve stopped the docker container, deleted all logs and then restarted the docker container. Once Plex was up, I tried opening Plex on my phone 1 time and it crashed immediately with no warnings or error messages. I too have sent this crash report to Google (if you can see them?).
Server logs for this attempt are attached.
Plex Media Server Logs_2019-02-07_13-13-19.zip (97.3 KB)
Yea, the official docker container is fishy, please fix it.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
exactly the same problem even after upgrade today.
please plex fix the problem.
I searched for logs, but there are no logs from today after upgrade to 1.15
thank you tobiashieta fairplay89 for your help
pulling the newest container as mentioned here: 1.15.0.647 - Fails to launch - Can't find libva.so.2 solved the problem…
somehow, it was the (auto) update corrupting my setup…
Thanks for the logs. I have located the Plex for Android crashes on the galaxy tablet. It is crashing whilst processing a server version number. It does not appear to do with the new build numbers 1.15.0.xxx-xxxxxxxxx
Could you get me the xml response to this request which you can put into a browser with adding your server security token
https://plex.tv/resources?includeHttps=1&includeRelay=1&X-Plex-Token=xxxxxxxxxx
Please copy the response into a text file and zip and send me by private message
You can find the server token from Preferences.xml - item PlexOnlineToken
I forgot to ask about iOS crashes. I cannot see any Plex for iOS crash events for your account. Could you confirm that this is happening and it is not just Android.
I mentioned Preferences.xml for finding the token - but you could also get it from Plex Web screen as outlined here https://support.plex.tv/articles/204059436-finding-an-authentication-token-x-plex-token/
I just had this same problem. As everyone said, you need to pull the latest image with docker pull plexinc/pms-docker:plexpass.
But next, you need to stop your running plex container. Mine is named ‘plex’. So docker stop plex.
Next, you need to delete that container, so you can then start a new one based on the new image you pulled.
So, for me, docker rm plex.
Next, you’d start your plex container like you previously did. For me, that looks like:
docker run -d \ --name plex \ --restart=always \ --security-opt apparmor:unconfined \ --net=host \ -e TZ="America/Chicago" \ -e PLEX_CLAIM="<MY_PLEX_CLAIM>" \ -v /mnt/extra/docker/plex/database:/config \ -v /mnt/extra/docker/plex/transcode:/transcode \ -v /mnt/md0/media:/data/media \ plexinc/pms-docker:plexpass
