Hello,
I’ve installed (manually, because the repo was not working, don’t know why) PlexKodiConnect:
PlexKodiConnect-1.2.3.zip
plugin.video.plexkodiconnect.movies.zip
plugin.video.plexkodiconnect.tvshows.zip
The plugin is able to connect to Plex account and download the Database. The first issue is that the images are not downloaded. I got a lot of those errors:ERROR: CCurlFile::Exists - Failed: Error(1) for https://.plex.direct:32400/library/metadata/2507/thumb/1461943570?X-Plex-Token=
ERROR: CCurlFile::Exists - Failed: Error(1) for https://.plex.direct:32400/library/metadata/2507/art/1461943570?X-Plex-Token=
Then, if I try to play anything, I got:
11:44:55 T:2793493584 ERROR: Previous line repeats 9 times.
11:44:55 T:2793493584 NOTICE: Thread LanguageInvoker start, auto delete: false
11:44:55 T:2937058384 NOTICE: PlexKodiConnect KodiMonitor -> Method: Playlist.OnClear Data: {"playlistid":1}
11:44:55 T:2793493584 NOTICE: -->Python Interpreter Initialized<--
11:44:56 T:2793493584 NOTICE: Using Image Cache Thread Count: 5 -> 1
11:44:56 T:2793493584 NOTICE: Parameter string: ?dbid=30&mode=play&id=2949&filename=Better.Call.Saul.1x05.Il.Pastorello.Delle.Alpi.ITA.BDMux.x264-UBi.mkv
11:44:56 T:2793493584 NOTICE: PlexKodiConnect DownloadUtils -> Request session does not exist: start one
11:44:56 T:2793493584 NOTICE: PlexKodiConnect DownloadUtils -> Verify SSL certificates set to: true
11:44:56 T:2793493584 NOTICE: PlexKodiConnect DownloadUtils -> SSL client side certificate set to: None
11:44:56 T:2793493584 NOTICE: PlexKodiConnect DownloadUtils -> Set server: https://<SNIP>.plex.direct:32400
11:44:56 T:2793493584 NOTICE: PlexKodiConnect DownloadUtils -> Set token: xxxxxxx
11:44:56 T:2793493584 NOTICE: PlexKodiConnect DownloadUtils -> Set userId: <SNIP>
11:44:56 T:2793493584 NOTICE: PlexKodiConnect DownloadUtils -> Set username: <SNIP>
11:44:56 T:2793493584 NOTICE: PlexKodiConnect DownloadUtils -> Requests session started on: https://<SNIP>.plex.direct:32400
11:44:56 T:2991445072 ERROR: CecLogMessage - Write: write failed !
11:48:30 T:2716943440 NOTICE: Using Image Cache Thread Count: 5 -> __init__ : 1
11:48:30 T:2716943440 NOTICE: PlexKodiConnect PlaybackUtils -> play : Play called.
11:48:30 T:2716943440 NOTICE: PlexKodiConnect PlayUtils -> mustTranscode : videoCodec: {'width': '720', 'videocodec': 'h264', 'container': 'mkv', 'bitrate': '1283', 'aspectratio': None, 'resolution': 'sd', 'bitDepth': None, 'height': '404'}
11:48:30 T:2716943440 NOTICE: PlexKodiConnect PlayUtils -> isDirectPlay : Kodi cannot access file None - no direct play
11:48:30 T:2716943440 NOTICE: PlexKodiConnect PlayUtils -> isNetworkSufficient : The add-on settings bitrate is: 4000, the video bitraterequired is: 1283
11:48:30 T:2716943440 NOTICE: PlexKodiConnect PlayUtils -> getPlayUrl : File is direct streaming.
11:48:30 T:2716943440 NOTICE: PlexKodiConnect PlayUtils -> getPlayUrl : The playurl is: https://<SNIP>.plex.direct:32400/library/parts/4780/file.mkv?X-Plex-Platform=Linux&X-Plex-Client-Platform=Linux&Connection=keep-alive&X-Plex-Device-Name=Kodi+%28le-pc%29&X-Plex-Provides=player&X-Plex-Token=<SNIP>&X-Plex-Client-Identifier=333dd48d-1fa7-4c08-a9f3-1e5c0ff1e814&Accept=%2A%2F%2A&X-Plex-Device=PlexKodiConnect&X-Plex-Product=PlexKodiConnect&Content-Type=application%2Fx-www-form-urlencoded&X-Plex-Version=0.01
11:48:30 T:2716943440 NOTICE: PlexKodiConnect PlaybackUtils -> play : Playlist start position: 0
11:48:30 T:2716943440 NOTICE: PlexKodiConnect PlaybackUtils -> play : Playlist plugin position: 0
11:48:30 T:2716943440 NOTICE: PlexKodiConnect PlaybackUtils -> play : Playlist size: 1
11:48:30 T:2716943440 NOTICE: PlexKodiConnect PlaybackUtils -> play : Resetting properties playback flag.
11:48:30 T:2716943440 NOTICE: PlexKodiConnect API -> externalSubs : Found external subs: []
11:48:30 T:2716943440 NOTICE: PlexKodiConnect PlaybackUtils -> play : Play as a regular item.
11:44:56 T:2937058384 NOTICE: PlexKodiConnect KodiMonitor -> Method: Playlist.OnRemove Data: {"playlistid":1,"position":1}
11:44:56 T:2793493584 NOTICE: PlexKodiConnect PlaybackUtils -> Processed as a playlist. First item is skipped.
11:44:56 T:3053056000 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.plexkodiconnect.tvshows/2943/?dbid=30&mode=play&id=2949&filename=Better.Call.Saul.1x05.Il.Pastorello.Delle.Alpi.ITA.BDMux.x264-UBi.mkv]
11:44:56 T:2659185744 NOTICE: Thread LanguageInvoker start, auto delete: false
11:44:56 T:2659185744 NOTICE: -->Python Interpreter Initialized<--
11:44:57 T:2659185744 NOTICE: Using Image Cache Thread Count: 5 -> 1
11:44:57 T:2659185744 NOTICE: Parameter string: ?dbid=30&mode=play&id=2949&filename=Better.Call.Saul.1x05.Il.Pastorello.Delle.Alpi.ITA.BDMux.x264-UBi.mkv
11:44:57 T:2659185744 NOTICE: PlexKodiConnect DownloadUtils -> Request session does not exist: start one
11:44:57 T:2659185744 NOTICE: PlexKodiConnect DownloadUtils -> Verify SSL certificates set to: true
11:44:57 T:2659185744 NOTICE: PlexKodiConnect DownloadUtils -> SSL client side certificate set to: None
11:44:57 T:2659185744 NOTICE: PlexKodiConnect DownloadUtils -> Set server: https://<SNIP>.plex.direct:32400
11:44:57 T:2659185744 NOTICE: PlexKodiConnect DownloadUtils -> Set token: xxxxxxx
11:44:57 T:2659185744 NOTICE: PlexKodiConnect DownloadUtils -> Set userId: <SNIP>
11:44:57 T:2659185744 NOTICE: PlexKodiConnect DownloadUtils -> Set username: <SNIP>
11:44:57 T:2659185744 NOTICE: PlexKodiConnect DownloadUtils -> Requests session started on: https://<SNIP>.plex.direct:32400
11:44:57 T:2991445072 ERROR: CecLogMessage - Write: write failed !
11:44:57 T:2659185744 NOTICE: PlexKodiConnect PlaybackUtils -> Play called.
11:44:57 T:2659185744 NOTICE: PlexKodiConnect PlayUtils -> Kodi cannot access file None - no direct play
11:44:57 T:2659185744 NOTICE: PlexKodiConnect PlayUtils -> The add-on settings bitrate is: 4000, the video bitraterequired is: 1288
11:44:57 T:2659185744 NOTICE: PlexKodiConnect PlayUtils -> File is direct streaming.
11:44:57 T:2659185744 NOTICE: PlexKodiConnect PlayUtils -> The playurl is: https://<SNIP>.plex.direct:32400/library/parts/4774/file.mkv?X-Plex-Platform=Linux&X-Plex-Client-Platform=Linux&Connection=keep-alive&X-Plex-Device-Name=Kodi+%28le-pc%29&X-Plex-Provides=player&X-Plex-Token=<SNIP>&X-Plex-Client-Identifier=333dd48d-1fa7-4c08-a9f3-1e5c0ff1e814&Accept=%2A%2F%2A&X-Plex-Device=PlexKodiConnect&X-Plex-Product=PlexKodiConnect&Content-Type=application%2Fx-www-form-urlencoded&X-Plex-Version=0.01
11:44:57 T:2659185744 NOTICE: PlexKodiConnect API -> Found external subs: []
11:44:57 T:2659185744 NOTICE: PlexKodiConnect PlaybackUtils -> Play as a regular item.
11:44:57 T:3053056000 ERROR: CCurlFile::Stat - Failed: Error(1) for https://<SNIP>.plex.direct:32400/library/parts/4774/file.mkv?X-Plex-Platform=Linux&X-Plex-Client-Platform=Linux&Connection=keep-alive&X-Plex-Device-Name=Kodi+%28le-pc%29&X-Plex-Provides=player&X-Plex-Token=<SNIP>&X-Plex-Client-Identifier=333dd48d-1fa7-4c08-a9f3-1e5c0ff1e814&Accept=%2A%2F%2A&X-Plex-Device=PlexKodiConnect&X-Plex-Product=PlexKodiConnect&Content-Type=application%2Fx-www-form-urlencoded&X-Plex-Version=0.01
11:44:57 T:3053056000 NOTICE: DVDPlayer: Opening: https://<SNIP>.plex.direct:32400/library/parts/4774/file.mkv?X-Plex-Platform=Linux&X-Plex-Client-Platform=Linux&Connection=keep-alive&X-Plex-Device-Name=Kodi+%28le-pc%29&X-Plex-Provides=player&X-Plex-Token=<SNIP>&X-Plex-Client-Identifier=333dd48d-1fa7-4c08-a9f3-1e5c0ff1e814&Accept=%2A%2F%2A&X-Plex-Device=PlexKodiConnect&X-Plex-Product=PlexKodiConnect&Content-Type=application%2Fx-www-form-urlencoded&X-Plex-Version=0.01
11:44:57 T:3053056000 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
11:44:57 T:2793493584 NOTICE: Thread DVDPlayer start, auto delete: false
11:44:57 T:2793493584 NOTICE: Creating InputStream
11:44:57 T:2793493584 ERROR: CCurlFile::Stat - Failed: Error(1) for https://<SNIP>.plex.direct:32400/library/parts/4774/file.mkv?X-Plex-Platform=Linux&X-Plex-Client-Platform=Linux&Connection=keep-alive&X-Plex-Device-Name=Kodi+%28le-pc%29&X-Plex-Provides=player&X-Plex-Token=<SNIP>&X-Plex-Client-Identifier=333dd48d-1fa7-4c08-a9f3-1e5c0ff1e814&Accept=%2A%2F%2A&X-Plex-Device=PlexKodiConnect&X-Plex-Product=PlexKodiConnect&Content-Type=application%2Fx-www-form-urlencoded&X-Plex-Version=0.01
11:44:57 T:2793493584 ERROR: CCurlFile::FillBuffer - Failed: Error(1)
11:44:57 T:2793493584 ERROR: CCurlFile::Open failed with code 0 for https://<SNIP>.plex.direct:32400/library/parts/4774/file.mkv?X-Plex-Platform=Linux&X-Plex-Client-Platform=Linux&Connection=keep-alive&X-Plex-Device-Name=Kodi+%28le-pc%29&X-Plex-Provides=player&X-Plex-Token=<SNIP>&X-Plex-Client-Identifier=333dd48d-1fa7-4c08-a9f3-1e5c0ff1e814&Accept=%2A%2F%2A&X-Plex-Device=PlexKodiConnect&X-Plex-Product=PlexKodiConnect&Content-Type=application%2Fx-www-form-urlencoded&X-Plex-Version=0.01
11:44:57 T:2793493584 ERROR: Open - failed to open source <https://<SNIP>.plex.direct:32400/library/parts/4774/file.mkv?X-Plex-Platform=Linux&X-Plex-Client-Platform=Linux&Connection=keep-alive&X-Plex-Device-Name=Kodi+%28le-pc%29&X-Plex-Provides=player&X-Plex-Token=<SNIP>&X-Plex-Client-Identifier=333dd48d-1fa7-4c08-a9f3-1e5c0ff1e814&Accept=%2A%2F%2A&X-Plex-Device=PlexKodiConnect&X-Plex-Product=PlexKodiConnect&Content-Type=application%2Fx-www-form-urlencoded&X-Plex-Version=0.01>
11:44:57 T:2793493584 ERROR: CDVDPlayer::OpenInputStream - error opening [<SNIP>.plex.direct:32400/library/parts/4774/file.mkv?X-Plex-Platform=Linux&X-Plex-Client-Platform=Linux&Connection=keep-alive&X-Plex-Device-Name=Kodi+%28le-pc%29&X-Plex-Provides=player&X-Plex-Token=<SNIP>&X-Plex-Client-Identifier=333dd48d-1fa7-4c08-a9f3-1e5c0ff1e814&Accept=%2A%2F%2A&X-Plex-Device=PlexKodiConnect&X-Plex-Product=PlexKodiConnect&Content-Type=application%2Fx-www-form-urlencoded&X-Plex-Version=0.01]
11:44:57 T:2793493584 NOTICE: CDVDPlayer::OnExit()
11:44:57 T:3053056000 ERROR: Playlist Player: skipping unplayable item: 1, path [plugin://plugin.video.plexkodiconnect.tvshows/2943/?dbid=30&mode=play&id=2949&filename=Better.Call.Saul.1x05.Il.Pastorello.Delle.Alpi.ITA.BDMux.x264-UBi.mkv]
11:44:57 T:2793493584 NOTICE: Thread BackgroundLoader start, auto delete: false
11:44:57 T:3053056000 NOTICE: CDVDPlayer::CloseFile()
11:44:57 T:3053056000 NOTICE: DVDPlayer: waiting for threads to exit
11:44:57 T:3053056000 NOTICE: DVDPlayer: finished waiting
11:44:58 T:2937058384 NOTICE: PlexKodiConnect Player -> ONPLAYBACK_STOPPED
11:44:58 T:2937058384 NOTICE: PlexKodiConnect Player -> Clear playlist properties.
11:44:58 T:2937058384 NOTICE: PlexKodiConnect KodiMonitor -> Method: Player.OnStop Data: {"end":false,"item":{"id":30,"type":"episode"}}
11:44:59 T:2991445072 ERROR: CecLogMessage - Write: write failed !
Seems more a CCurl error but don’t know how to check it.
My system is a debian 8 jessie (kernel 3.10.94) on armv7l arch with python 2.7.3.
Kodi version 15.2
Any suggestion? Maybe @croneter ?
Thanks a lot!
Simon
