Server Version#: plex-media-server-plexpass 1.21.0.3616-1
Player Version#: plexmediaplayer 2.58.0.dev-38e019da
Can you please escalate this to your dev team - plex qt9.5 is now out of support. I suspect many linux systems will start having issues from this point forward
As of this morning I have an issue where starting the plex-media-player it tries to open the window and segment faults and aborts. The player was working last night.
It seems the problem is likely QT5 versions that plex supports are too old.
- I have tried to use the flatpak version (hoping it would containerize away the issue - no luck though (same error messages came through as per below)
➜ flatpak run tv.plex.PlexMediaPlayer
QSocketNotifier: Can only be used with threads started with QThread
libpng warning: iCCP: known incorrect sRGB profile
Logging to /home/stuart/.var/app/tv.plex.PlexMediaPlayer/data/plexmediaplayer/logs/plexmediaplayer.log
Logging to /home/stuart/.var/app/tv.plex.PlexMediaPlayer/data/plexmediaplayer/logs/pmphelper.log
Please note I am using the below running off gnome3 wayland
➜ uname -a
Linux 5.9.10-arch1-1 #1 SMP PREEMPT Sun, 22 Nov 2020 14:16:59 +0000 x86_64 GNU/Linux
Archlinux
It seems my archlinux system is using qt5.15 - the qt5.9.5 version that plex officially supports is now out of support.
Plex really needs to upgrade their qt5 library support and in the meantime it would be a great move to provide a docker image that people can use (versus just asking customers to organise one for themselves). If there is a plex provided docker image for the player - please provide a link and update github to reference it.
ref: Support of Qt 5.9 LTS Ends in May 2020
Building on Linux
Plex Media Player officially requires Qt 5.9.5. Our users have indicated that Qt 5.10 and Qt 5.11 also builds correctly. However, Qt 5.11.0 and 5.11.1 versions are incompatible and should be avoided. Qt 5.12 may work for you. Please consider building PMP within a dedicated VM or Docker container if your system has a Qt version installed newer than 5.9.5. Downgrading a system Qt will cause issues in other applications depending on a newer Qt version.
These instructions are for Ubuntu 16.04 LTS and up. They were tested on a fresh install without extra options and with auto-updates applied.
ref: GitHub - plexinc/plex-media-player: Next generation Plex Desktop/Embedded Client
My installed versions of qt5 are below
local/qt4 4.8.7-32
A cross-platform application and UI framework
local/qt5-base 5.15.2-1 (qt qt5)
Output from terminal when trying to start
➜ plexmediaplayer
Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
Logging to /home/stuart/.local/share/plexmediaplayer/logs/plexmediaplayer.log
Logging to /home/stuart/.local/share/plexmediaplayer/logs/pmphelper.log
[1] 9308 segmentation fault (core dumped) plexmediaplayer
History of plex installs (the last install is after the problem to try to brute-force troubleshoot the issue)
➜ less /var/log/pacman.log |grep plex
[2020-08-18T21:30:33+1200] [PACMAN] Running 'pacman -U --noconfirm --config /etc/pacman.conf -- /home/stuart/.cache/yay/plex-media-player/plex-media-player-2.58.0-3-x86_64.pkg.tar.zst'
[2020-08-18T21:30:33+1200] [ALPM] installed plex-media-player (2.58.0-3)
[2020-11-25T08:19:50+1300] [PACMAN] Running 'pacman --upgrade --noconfirm -- /home/stuart/.cache/paru/clone/plex-media-player/plex-media-player-2.58.0-3-x86_64.pkg.tar.zst'
[2020-11-25T08:19:54+1300] [ALPM] reinstalled plex-media-player (2.58.0-3)
Upgrades performed between plex-media-player working and not working
➜ less /var/log/pacman.log | grep 2020-11-24 | grep upgraded
[2020-11-24T21:42:25+1300] [ALPM] upgraded linux (5.9.9.arch1-1 -> 5.9.10.arch1-1)
[2020-11-24T21:42:25+1300] [ALPM] upgraded acpi_call (1.2.1-4 -> 1.2.1-5)
[2020-11-24T21:42:25+1300] [ALPM] upgraded alsa-card-profiles (13.99.3+14+geaa6d5d6c-1 -> 14.0-1)
[2020-11-24T21:42:25+1300] [ALPM] upgraded libpulse (13.99.3+14+geaa6d5d6c-1 -> 14.0-1)
[2020-11-24T21:42:25+1300] [ALPM] upgraded libxkbcommon (1.0.2-1 -> 1.0.3-1)
[2020-11-24T21:42:26+1300] [ALPM] upgraded electron9 (9.3.4-2 -> 9.3.5-1)
[2020-11-24T21:42:26+1300] [ALPM] upgraded libxkbcommon-x11 (1.0.2-1 -> 1.0.3-1)
[2020-11-24T21:42:31+1300] [ALPM] upgraded linux-headers (5.9.9.arch1-1 -> 5.9.10.arch1-1)
[2020-11-24T21:42:32+1300] [ALPM] upgraded linux-lts (5.4.78-1 -> 5.4.79-1)
[2020-11-24T21:42:36+1300] [ALPM] upgraded linux-lts-headers (5.4.78-1 -> 5.4.79-1)
[2020-11-24T21:42:36+1300] [ALPM] upgraded pulseaudio (13.99.3+14+geaa6d5d6c-1 -> 14.0-1)
[2020-11-24T21:42:36+1300] [ALPM] upgraded pulseaudio-bluetooth (13.99.3+14+geaa6d5d6c-1 -> 14.0-1)
I have attached the log as well.
(File removed)
