Hello,
I’m trying to download the last available PlexMediaServer (I believe would be version 0.9.x) for ARMv5 architecture (for a DLink DNS-325 NAS). The old download links provided by the plex website are no longer available. Would anyone know where I could find these ? They used to be under:
Much thanks for your help!
Patrick
Moderator: Links Removed
Previous version links are no longer valid. Company policy regarding this has changed
If there is an ARM v5 version to be found, it will be from a user here or out on the open internet.
If this can help anyone else, I finally managed to find working copies of Plex Media Server for ARMv5 Architecture!.
For my NAS (DNS-325), because it’s running GLIBC v. 2.5, the last plex server working is version 0.9.9.10. If you’ve got GLIBC 2.7 and up installed, then you could install a more recent version of the Plex Server. Just run ‘/lib/libc.so.6’ to see which version you’ve got.
If anyone knows a place where I could find more recent versions of PlexServer compiled against GLIBC 2.5, I’d like to hear about it.
Cheers all ! Pat
Moderator: Links removed
Hi, i’,m trying to install Plex on a QNap TS-412 with arm v5. can you send me the working copy you found for this arm version? thanks a lot
ARMv5 has not been supported for 2+ years. ARMv5 does not have enough CPU power to run PMS. None of the clients are compatible.
None of PMS from those versions can even talk to Plex.tv
This thread was previously closed and somehow re-opened in the forum relocation.
Closing now.
