My plex user and group (plex:plex) comes from an LDAP directory. Everything works fine on 1.18.4.2171, but upgrading to 1.18.5.2260 results in the following error:
Unpacking plexmediaserver (1.18.5.2260-056ab4be9) over (1.18.5.2260-056ab4be9) ...
Setting up plexmediaserver (1.18.5.2260-056ab4be9) ...
PlexMediaServer install:
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Process Control: Systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: video
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /var/lib/plexmediaserver/tmp_transcoding
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: HW transcoding: Found
PlexMediaServer install: Completing final configuration.
useradd: user 'plex' already exists
dpkg: error processing package plexmediaserver (--install):
installed plexmediaserver package post-installation script subprocess returned error exit status 9
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Errors were encountered while processing:
plexmediaserver
ERROR: Failed to install update. Command 'dpkg --force-confnew -i /tmp/plexmediaserver_1.18.5.2260-056ab4be9_amd64.deb' returned error code 1
I forced an install of 1.18.4.2171 and everything is working fine again. This is on Ubuntu 18.04.
