Hi
Can i use the database from Plexpy 1.4.25 with tautulli?
Hi
All Plexpy and beta Tautulli support is given here -
https://forums.plex.tv/discussion/169591/plexpy-another-plex-monitoring-program/p1
And the answer to your question so you don’t have to repeat it there is ‘yes’.
However, if you experience bugs that cause you to want to go back, you can’t copy the Tautulli db or configs back to plexpy 1.4, as tautulli stores different/more information in the db.
Those wishing to ensure beta and production running good are running both as I am, but on different ports.
