Thanks. I pushed another possible fix. Would you mind testing it and letting me know your results.
Fixed! Thanks so much!!
Nice, I'll update the build version. Thanks for testing :)
Thanks, eleese! This is awesome.
I am running this on OSX Mavericks and it took me some time to get it setup. I am new to creating a webserver on my computer and so went through several guides online that never got me to the point where I could easily drop the plexWatch/Web folder somewhere and then get it working through my browser. For anybody as novice at this as I am, here is a link to the guide I used to finally get everything up and running: http://www.maclife.com/article/howtos/how_make_your_mac_web_server?page=0,0
I was not able to get the images working from outside my server, even with the suggestions to add the ip/subnetmask to the authorized networks in PMS. So, I anxiously look forward to when you can add myPlex authentication to this.
Thanks again!
Thanks again!
Thanks Brgiles for using plexWatch/Web and sharing your web server setup experience. You are welcome to try out the development branch if you need myPlex support. I am anticipating the current dev version will be merged with the master branch by the end of the week if no additional bugs are found.
Now Available: plexWatch/Web (v1.4.0)
Major changes to this version include:
Note:
The default installation of some web servers do not bundle CA certs. Because of this, myPlex authentication may not work correctly without first fixing this issue. I have documented a quick how-to for XAMPP users on the plexWatch/Web wiki. Please ensure you add this support to your web server before installing this version of plexWatch/Web.
Anyone get PlexWatchWeb up and working on their synology DS? If so please let me know. Thanks!
New release looks really good!! Thanks for all the work!!!
Cheers!
Yes / no. I have it running on my synology DS1511+, but not everything is working, im using version 1.4.0, and plexwatch 1.6.
I can see recently added, and whats currently being watched but the watch history, users and charts do not populate. settings page stops working after initial setup.
also added the curl.cainfo = "PATH_TO/cacert.pem to my php.ini file.
I have the database on my local desktop where i run plex, and i'm using cloud station to sync the directory so that plexwatch web can see the database on the synology integrated web rather then use another local web server.
i'm looking for help getting the rest of plexwatch web working. also my plexwatch update scripts could use work.... they dont update unless i run the task schedule manually.
You are not setting the path correctly for your database file. I think the easiest way to find this would be to ssh into your Synology Diskstation and physically look for the file. I'm running a VM of DSM4.1 currently and the path to my database file where I'm testing is:
/volume1/web/plexWatch/db/plexWatch.db
Your path will differ since you are using Cloudstation but it is possible to sync the web folder with Cloudstation if you wanted. Just do a quick browse via ssh to find the location of your database file and then issue a "pwd" command to get the full path location.
Having some issues with my plexwatch app. It seems that plexwatch cannot connect to the plex web server, even they are on the same server.
Look at my server error log:
[Sun Nov 03 19:09:21 2013] [error] [client someip] PHP Warning: simplexml_load_file(http://192.168.0.1:32400/status/sessions?query=c&X-Plex-Token=pKmrMGGsSxmksPVaCy8s): failed to open stream: HTTP request failed! HTTP/1.0 403 Forbidden in /var/www/domain.tld/plexwatch/index.php on line 80, referer: http://domain.tld/plexwatch [Sun Nov 03 19:09:21 2013] [error] [client someip] PHP Warning: simplexml_load_file(): I/O warning : failed to load external entity "http://192.168.0.1:32400/status/sessions?query=c&X-Plex-Token=pKmrMGGsSxmksPVaCy8s" in /var/www/domain.tld/plexwatch/index.php on line 80, referer: http://usikret.net/plexwatch
Everything running on a Debian Squeeze server with the latest software.
Edit: the plexWatch.db is empty if that counts. And I have it saved in the plexwatch folder, the config.php correctly reflects thas as well.
Edit2: Just noticed I need plexwatch as well, and I have now installed this package and I now are getting this error when I try to run /opt/plexWatch/plexWatch.pl:
Final edit: Discovered this is not the correct thread, sorry.
Sun Nov 3 19:37:18 2013: Failed to get request http://192.168.0.1:32400/status/sessions - The result:Forbidden
403 Forbidden
[Sun Nov 03 19:09:21 2013] [error] [client someip] PHP Warning: simplexml_load_file(http://192.168.0.1:32400/status/sessions?query=c&X-Plex-Token=pKmrMGGsSxmksPVaCy8s): failed to open stream: HTTP request failed! HTTP/1.0 403 Forbidden in /var/www/domain.tld/plexwatch/index.php on line 80, referer: http://domain.tld/plexwatch [Sun Nov 03 19:09:21 2013] [error] [client someip] PHP Warning: simplexml_load_file(): I/O warning : failed to load external entity "http://192.168.0.1:32400/status/sessions?query=c&X-Plex-Token=pKmrMGGsSxmksPVaCy8s" in /var/www/domain.tld/plexwatch/index.php on line 80, referer: http://usikret.net/plexwatchEverything running on a Debian Squeeze server with the latest software.
Sun Nov 3 19:37:18 2013: Failed to get request http://192.168.0.1:32400/status/sessions - The result:Forbidden403 Forbidden
Start by getting plexWatch fully working before attempting to use plexWatch/Web. The error appears to be some sort of access permissions problem so I would start by fully reading the plexWatch installation portion of the readme.
/volume1/web/plexWatch/db/plexWatch.dbYour path will differ since you are using Cloudstation but it is possible to sync the web folder with Cloudstation if you wanted. Just do a quick browse via ssh to find the location of your database file and then issue a "pwd" command to get the full path location.
Got everything up and running on the Synology. Thanks!
yes, my synology path is /volume1/homes/admin/CloudStation/plexWatch/plexWatch.db and thats what i enter for the path location.
I am unable to get it working. i tried installing plexwatch on my synology without luck. so i installed the windows version on the same machine i run my plex media server. that works, but plexwatch web cant see the database in c:/plexwatch/
Im looking for a way to get everything working on my synology, or be able to get the database to read from my /volume1/web/plexwatch/ directory like you have, just not sure how to do it right. any additional help here would be the best thing all day.....
Perhaps Cloudstation locks things down permission wise. Check access permissions for the database file and the folder structure. Also as test just try manually placing the file outside of the Cloudstation folder structure and into /volume1/web/plexWatch/ and see if it works from there. If I get a chance I will try Cloudstation and see what results I get.
Okay, so i put a copy of the plexWatch.db in /volume1/web/plexwatch/plexwatch.db and updated the path in plexwatch web, and it is working that way, so it must be permissions. so, how would i go about getting the whole thing working out of the /volume1/web/ directory?
I'll try any suggestions, but here's what i got setup right now:
on my windows machine that plex media center is installed, i have plexwatch in c:/Username/CloudStation/plexwatch/ synced with my synology to /volume1/homes/admin/CloudStation/plexwatch. the folder for plexwatch from the synology i have set to 0755 permissions for all files.
Edit: I also setup a symbolic link to the web folder, for just the database. I used c:\plexWatch\pw >> \\synology\web\pw (and the plexWatch.db is there)
The database writes, and is viewable in /volume1/web/pw/ for me. permissions for the files i have tried 0755 and 0777, but that is not working. if i copy the database to /volume1/web/pwdb/ and point plexwatch web to it, it works, but then the database wont get updated. so thats where im stuck.
I think i got my scripts updating.... maybe....
I have not personally tested this solution but it should work unless Cloudstation uses some form of data encryption.
:/volume1/homes/admin/CloudStation/plexWatch/
Update: I've now tested this solution with success. This is what I did.
I'd like to suggest adding the graphs down to the individual user. Exactly like the graphs under "History" Also, Top 10 by User like under "Charts" Thanks. Thanks for all the effort. The plexWatch & plexWatch/Web are well used by me. Appreciated.
EDIT: Thanks for all your help with plexwatch web. I followed everything you suggested, failed, and tried again. Eventually with the setup exactly as you instructed from your last post, it was not working so i removed the existing database and all associated files. I have plexwatch rebuild everything new for the database, and that got it working.
thanks again! this application is pretty awesome!
Glad to hear that cause I was out of suggestions! I had it working in under 5 minutes this morning so it sounds as though your database must have been corrupted. Enjoy!
