plexWatch - Windows Branch
I should be up for a while, I can test the update once you get it rebuilt. Just let me know. Feel free to shoot me an email directly: nick [dot] heidke [at] gmail [dot] com
pushed an update through.. next post will have details
PlexWatch v0.1.6 Released
Downloads: plexWatch.exe and config.pl-dist
GitHub: https://github.com/l...tch/tree/v0.1.6
*  JSON fixup for windows
Thanks for the update! i updated this and plexwatchweb and i get errors.
on home screen
Warning: fsockopen() expects parameter 2 to be long, string given in C:\xampp\htdocs\plexWatchWeb\index.php on line 99
amd the other tabs say
Fatal error: Call to undefined function dbconnect() in C:\xampp\htdocs\plexWatchWeb\history.php on line 95
Or i get this if i turn off grouping......i unchecked and rechecked grouping. now it just says no results on anything. when its unchecked it says
Notice: Trying to get property of non-object in C:\xampp\htdocs\plexWatchWeb\includes\functions.php on line 28
Notice: Trying to get property of non-object in C:\xampp\htdocs\plexWatchWeb\includes\functions.php on line 29
Notice: Trying to get property of non-object in C:\xampp\htdocs\plexWatchWeb\includes\functions.php on line 32
Notice: A session had already been started - ignoring session_start() in C:\xampp\htdocs\plexWatchWeb\includes\functions.php on line 11
Doubt plexWatchWeb dev is ready. But try going to the settings page and re-saving. That might fix this missing function.
Edit: If you were using the dev version, you should try and revert to the previous copy. The new web dev is not ready.
Previous comment is still correct as the DEV channel is being worked on, however I made some more commits tonight. This might fix some of your errors. Remember though, this is a dev version or plexWatch/Web
You can try my branch until this gets merged into the main repo: https://github.com/ljunkie/plexWatchweb/tree/ljunkie-friendly-names
of course. i just wanted to help out any way i can. friendly names are coming up now. there is a new error under the now playing picture. which displays the now playing info.
Notice: Trying to get property of non-object inC:\xampp\htdocs\plexWatchWeb\includes\functions.phpon line 28
and with grouping checked i get a message that says no results. with unchecked i now just get this a few hundered times under history. and under users. charts work fine. Thanks for all your hard work. will be donating soon for everything you have done.
Good deal. I’ll check into this today. Should be two “easy” fixes. Thanks for the appreciation!
pull another new version:  https://github.com/ljunkie/plexWatchweb/tree/ljunkie-friendly-names
It should fix those warnings, however I was unable to replicate the the issue with grouping. I am wondering if your plexWatch.db is missing required table. It should be automatically added with the new version of plexWatch. I will verify the windows version is adding that table.
EDIT: verified the windows plexWatch v0.1.6 is adding the required table for plexWatchWeb to work with grouping. Please verify you are running the plexWatch v0.1.6 version and report back.
Good deal. I'll check into this today. Should be two "easy" fixes. Thanks for the appreciation!
The new version works great witht the errors. Now everything works fine with grouping off. Yes, I am using 1.6 plexwatch.
Just downloaded and installed the latest version and its working great except for the .vbs script to run every minute. From a command prompt running plexWatch.exe it sends and email perfectly however with the script it seems to never send. Is this correct for the .vbs script?
Set WshShell = CreateObject("WScript.Shell")
WshShell.Run "C:\plexWatch\plexWatch.exe --notify", 0, True
Set WshShell = Nothing
Thanks for the help
Right, but you should test it with grouping on -- that works fine for me. Can you test with grouping on?
Thanks for the help
Yes.
* You must set the start dir to c:\plexWatch in the scheduled job
* you can test the script by running the vbs after you " cd c:\plexwatch"
If you need to debug it more, you can run this VBS instead: It will show you the cmd prompt popup and wait for your input after it runs"
Set WshShell = CreateObject(“WScript.Shell”)
WshShell.Run “%comspec% /k ““C:\plexWatch\plexWatch.exe --notify”””, 1, True
That did the trick, Thanks!
with grouping on. On history and users and charts says No Results.
that is just odd, what does plexWatch.exe --version say?
It says 1.4
that is the one downloaded from github and the one you posted
nope :) http://forums.plexapp.com/index.php/topic/79616-plexwatch-windows-branch/page-6#entry484678
i downloaded that one. still says 1.4
