Server Version#: v1.40.2.8395-c67dce28e
Plex Server log
Apr 27, 2024 16:46:24.053 [140535296322360] INFO - Plex Media Server v1.40.2.8395-c67dce28e - Gentoo PC x86_64 - build: linux-x86_64 debian - GMT 02:00
Apr 27, 2024 16:46:24.054 [140535296322360] INFO - Linux version: default/linux/amd64/23.0/no-multilib/systemd, language: en-US
Apr 27, 2024 16:46:24.054 [140535296322360] INFO - Processor: 12-core Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Apr 27, 2024 16:46:24.054 [140535296322360] INFO - Compiler is - Clang 11.0.1 (https://plex.tv 9b997da8e5b47bdb4a9425b3a3b290be393b4b1f)
Apr 27, 2024 16:46:24.054 [140535296322360] INFO - /usr/lib/plexmediaserver/Plex Media Server
Apr 27, 2024 16:46:24.149 [140535298886288] INFO - [CERT/OCSP] Successfully retrieved response from cache.
Apr 27, 2024 16:46:24.251 [140535298886288] INFO - Running migrations. (EPG 0)
Apr 27, 2024 16:46:24.307 [140535298886288] INFO - Running migrations. (EPG 0)
Apr 27, 2024 16:46:26.524 [140535225350968] ERROR - BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:46:26.524 [140535225350968] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we're killing it.
Apr 27, 2024 16:46:26.524 [140535225350968] ERROR - Error received reading configuration for com.plexapp.system
Apr 27, 2024 16:46:26.524 [140535294118712] WARN - JobManager: Could not find job for handle 151238
Apr 27, 2024 16:46:27.087 [140535289310008] WARN - [EventSourceClient/pubsub/139.162.215.242:443] MyPlex: attempted a reachability check but we're not yet mapped.
Apr 27, 2024 16:46:28.663 [140535225350968] ERROR - BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:46:28.663 [140535225350968] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we're killing it.
Apr 27, 2024 16:46:28.663 [140535225350968] ERROR - Error received reading configuration for com.plexapp.system
Apr 27, 2024 16:46:28.663 [140535294118712] WARN - JobManager: Could not find job for handle 151259
Apr 27, 2024 16:46:30.406 [140535175158584] INFO - [Req#25] AutoUpdate: no updates available
Apr 27, 2024 16:46:30.809 [140535183727416] ERROR - BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:46:30.809 [140535183727416] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.themoviedb], we're killing it.
Apr 27, 2024 16:46:30.809 [140535183727416] ERROR - Error received reading configuration for com.plexapp.agents.themoviedb
Apr 27, 2024 16:46:30.809 [140535294118712] WARN - JobManager: Could not find job for handle 151296
Apr 27, 2024 16:46:30.837 [140535201569592] ERROR - BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:46:30.837 [140535201569592] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.plexthememusic], we're killing it.
Apr 27, 2024 16:46:30.837 [140535201569592] ERROR - Error received reading configuration for com.plexapp.agents.plexthememusic
Apr 27, 2024 16:46:30.837 [140535294118712] WARN - JobManager: Could not find job for handle 151299
Apr 27, 2024 16:46:30.844 [140535185836856] ERROR - BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:46:30.844 [140535185836856] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.thetvdb], we're killing it.
Apr 27, 2024 16:46:30.844 [140535185836856] ERROR - Error received reading configuration for com.plexapp.agents.thetvdb
Apr 27, 2024 16:46:30.844 [140535294118712] WARN - JobManager: Could not find job for handle 151297
Apr 27, 2024 16:46:32.935 [140535231757112] ERROR - BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:46:32.935 [140535231757112] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we're killing it.
Apr 27, 2024 16:46:32.935 [140535231757112] ERROR - Error received reading configuration for com.plexapp.system
Apr 27, 2024 16:46:32.935 [140535294118712] WARN - JobManager: Could not find job for handle 151312
Apr 27, 2024 16:46:35.082 [140535183727416] ERROR - BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:46:35.082 [140535183727416] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.imdb], we're killing it.
Apr 27, 2024 16:46:35.082 [140535183727416] ERROR - Error received reading configuration for com.plexapp.agents.imdb
Apr 27, 2024 16:46:35.082 [140535294118712] WARN - JobManager: Could not find job for handle 151334
Apr 27, 2024 16:46:35.093 [140535227530040] ERROR - BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:46:35.093 [140535227530040] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we're killing it.
Apr 27, 2024 16:46:35.093 [140535294118712] WARN - JobManager: Could not find job for handle 151336
Apr 27, 2024 16:46:35.093 [140535227530040] ERROR - Error received reading configuration for com.plexapp.system
Apr 27, 2024 16:46:37.209 [140535214803768] ERROR - Unknown metadata type:
Apr 27, 2024 16:46:37.226 [140535242312504] ERROR - BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:46:37.226 [140535242312504] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we're killing it.
Apr 27, 2024 16:46:37.226 [140535242312504] ERROR - Error received reading configuration for com.plexapp.system
Apr 27, 2024 16:46:37.226 [140535294118712] WARN - JobManager: Could not find job for handle 151354
Apr 27, 2024 16:46:37.277 [140535227530040] ERROR - Unknown metadata type:
Apr 27, 2024 16:46:56.541 [140535219022648] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we're killing it.
Apr 27, 2024 16:46:56.542 [140535219022648] ERROR - Error received reading configuration for com.plexapp.system
Apr 27, 2024 16:46:56.542 [140535294118712] WARN - JobManager: Could not find job for handle 151516
Apr 27, 2024 16:46:56.557 [140535235975992] ERROR - [Req#4b] BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:46:56.557 [140535235975992] ERROR - [Req#4b] Timeout or error reading status line from plug-in pipe [com.plexapp.agents.imdb], we're killing it.
Apr 27, 2024 16:46:56.557 [140535235975992] ERROR - [Req#4b] Error received reading configuration for com.plexapp.agents.imdb
Apr 27, 2024 16:46:56.557 [140535294118712] WARN - JobManager: Could not find job for handle 151519
Apr 27, 2024 16:46:56.557 [140535235975992] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 27, 2024 16:46:56.557 [140535235975992] ERROR - IVA: failed to get IMDB prefs
Apr 27, 2024 16:49:01.117 [140535208442680] ERROR - [Req#71] BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:49:01.117 [140535208442680] ERROR - [Req#71] Timeout or error reading status line from plug-in pipe [com.plexapp.system], we're killing it.
Apr 27, 2024 16:49:01.117 [140535208442680] ERROR - [Req#71] Error received reading configuration for com.plexapp.system
Apr 27, 2024 16:49:01.117 [140535294118712] WARN - JobManager: Could not find job for handle 151644
Apr 27, 2024 16:49:05.893 [140535208442680] ERROR - [Req#73] BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:49:05.893 [140535208442680] ERROR - [Req#73] Timeout or error reading status line from plug-in pipe [com.plexapp.system], we're killing it.
Apr 27, 2024 16:49:05.893 [140535208442680] ERROR - [Req#73] Error received reading configuration for com.plexapp.system
Apr 27, 2024 16:49:05.893 [140535294118712] WARN - JobManager: Could not find job for handle 151683
Apr 27, 2024 16:49:12.898 [140535208442680] ERROR - [Req#74] BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:49:12.898 [140535208442680] ERROR - [Req#74] Timeout or error reading status line from plug-in pipe [com.plexapp.system], we're killing it.
Apr 27, 2024 16:49:12.898 [140535208442680] ERROR - [Req#74] Error received reading configuration for com.plexapp.system
Apr 27, 2024 16:49:12.898 [140535294118712] WARN - JobManager: Could not find job for handle 151695
Apr 27, 2024 16:49:34.151 [140535208442680] ERROR - [Req#75] BufferingLineReader: failed to read line (error: -1)
Apr 27, 2024 16:49:34.151 [140535208442680] ERROR - [Req#75] Timeout or error reading status line from plug-in pipe [com.plexapp.system], we're killing it.
Apr 27, 2024 16:49:34.151 [140535208442680] ERROR - [Req#75] Error received reading configuration for com.plexapp.system
Apr 27, 2024 16:49:34.151 [140535294118712] WARN - JobManager: Could not find job for handle 151719
dmesg
[ +1.799060] Plex Script Hos[4296]: segfault at 2380 ip 0000000000002380 sp 00007fffbe446c28 error 14 likely on CPU 1 (core 1, socket 0)
[ +0.002532] Code: Unable to access opcode bytes at 0x2356.
[ +0.003905] Plex Script Hos[4297]: segfault at 2380 ip 0000000000002380 sp 00007ffc179aeeb8 error 14 likely on CPU 6 (core 0, socket 0)
[ +0.002521] Code: Unable to access opcode bytes at 0x2356.
[ +0.002804] Plex Script Hos[4295]: segfault at 2380 ip 0000000000002380 sp 00007fffdac41388 error 14 likely on CPU 10 (core 4, socket 0)
[ +0.002537] Code: Unable to access opcode bytes at 0x2356.
[ +1.768281] Plex Script Hos[4315]: segfault at 2380 ip 0000000000002380 sp 00007ffc663be358 error 14 likely on CPU 11 (core 5, socket 0)
[ +0.002510] Code: Unable to access opcode bytes at 0x2356.
[ +0.026296] Plex Script Hos[4320]: segfault at 2380 ip 0000000000002380 sp 00007fffbe34b948 error 14 likely on CPU 0 (core 0, socket 0)
[ +0.002494] Code: Unable to access opcode bytes at 0x2356.
[ +1.787343] Plex Script Hos[4346]: segfault at 2380 ip 0000000000002380 sp 00007ffc15a3d0a8 error 14 likely on CPU 8 (core 2, socket 0)
coredumpctl
PID: 14527 (Plex Script Hos)
UID: 103 (plex)
GID: 103 (plex)
Signal: 11 (SEGV)
Timestamp: Sun 2024-04-28 22:55:29 CEST (1h 24min ago)
Command Line: $'Plex Plug-in [com.plexapp.agents.fanarttv]' /usr/lib/plexmediaserver/Resources/Plug-ins-c67dce28e/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.40.2.8395-c67dce28e /usr/lib/plexmediaserver/Resources/Plug-ins-c67dce28e/Fanart-TV.bundle
Executable: /usr/lib/plexmediaserver/Plex Script Host
Control Group: /system.slice/plex-media-server.service
Unit: plex-media-server.service
Slice: system.slice
Boot ID: 9c3fb7afca914b83a4ff87ec5d964aa4
Machine ID: fd2bad813feff8c884b04a545d596770
Hostname: localhost
Storage: /var/lib/systemd/coredump/core.Plex\x20Script\x20Hos.103.9c3fb7afca914b83a4ff87ec5d964aa4.14527.1714337729000000.zst (present)
Size on Disk: 3.6M
Message: Process 14527 (Plex Script Hos) of user 103 dumped core.
Module libuuid.so.1 without build-id.
Module libc++.so.2 without build-id.
Module ld-musl-x86_64.so.1 without build-id.
Module libgcompat.so.0 without build-id.
Stack trace of thread 14527:
#0 0x0000000000002380 n/a (n/a + 0x0)
ELF object binary architecture: AMD x86-64
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x0000000000002380 in ?? ()
(gdb) bt
#1 0x00007f5004ddbabf in _dlstart () from /usr/lib/plexmediaserver/lib/ld-musl-x86_64.so.1
#2 0x0000000000000018 in ?? ()
#3 0x00007f500241edc0 in ?? ()
#4 0x0000000000000001 in ?? ()
#5 0x00007f5002400d70 in ?? ()
#6 0x000000001e907fee in ?? ()
#7 0x00000000000002d2 in ?? ()
#8 0x00000000000003d8 in ?? ()
#9 0x0000000000008fe8 in ?? ()
#10 0x0000000000000000 in ?? ()
