PM4K / PlexMod for Kodi (18, 19, 20, 21, 22+)
Does it not scroll?
Yeah, you’d copy it as custom_bundle.crt and add your own.
It does not unfortunately.
Noted, thanks for reporting, mate :slight_smile:
Back!
0.8.0-beta2: script.plexmod.zip (2.8 MB)
Changelog:
  • Core/plexnet/http: Fix session cert bundle usage by using the correct attribute (verify vs cert); should fix kodi 18 connectivity and will actually use the correct bundle on Kodi 18+
  • Core/SSL: Replace default plex.direct certificate with ACME root bundle (Letsencrypt, ZeroSSL), valid until 2035
  • Core/AddonSettings: Adjust default plex.tv timeouts to 1s (connect), 2s (read); (was: 5s, 20s)
  • Core/KodiGUI: When broken template is detected, make sure to stop current playback as well
  • Core/Autostart: Harden autostart; only autostart when we’re at the home view and we have no dialogs active; stop trying to autostart after 120s
  • Core/Service: Add inline documentation
  • Core: Wait for properly-set properties if wanted/necessary
Most of these changes will probably be backported to 0.7.9-rev3, as that’s going to be PR’d to the official Kodi repository.
Edit: I’ve compiled a pretty huge list of bugs/changes for 0.8.0 while being on my break. Watchlist is still the top #1 feature for 0.8.0.
Edit 2: Updated zip (13.09. 15:25 CEST)
Welcome back panni :slight_smile:
I’ve downloaded your beta 2 twice and installed it but I’m still seeing beta1 in the about. Is it just me?
My bad, updated the zip :slight_smile:
Moien, the logo of my username always stays the same, even if I change it on Plex. I have already deleted Plex on Kodi and no change. Where is the image saved?
Thank you
In Kodi’s thumbnail cache, you need to clean that. https://kodi.wiki/view/Artwork/Cache
Pushed 0.7.9-rev3 to Don’t Panic, backported changes/fixes from 0.8.0-beta:
  • Player: Only send timeline events if playstate has changed or we haven’t sent one for 15 seconds; fixes #137
  • AddonSettings: Fix default cert bundle setting
  • Core/AddonSettings: Adjust proper defaults for plextv timeouts
  • Core/Networking/MyPlex: Don’t use custom certificate for plex.tv connections
0.7.9 PR open in the official Kodi repository (finally): [script.plexmod] 0.7.9 by pannal · Pull Request #2645 · xbmc/repo-scripts · GitHub
With 0.8.0 beta i get an error on kodi before pm4k starts. Plex error.
2024-09-13 17:43:47.303 T:23997 info : Skipped 1 duplicate messages…
2024-09-13 17:43:47.303 T:23997 error : EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<–
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <class ‘IndexError’>
Error Contents: list index out of range
Traceback (most recent call last):
File “/storage/emulated/0/Android/data/net.kodinerds.maven.kodi21/files/.kodi/addons/script.plexmod/default.py”, line 34, in
boot_delay = int(sys.argv[2])
IndexError: list index out of range
–>End of Python script error report<–
Did you restart Kodi? Seems like service.py is still running the old version.
Yessir, multiple times. When i revert to 0.7.9 rev 2 then no error.
Ah yeah, you’re not using a boot delay, do you? Let me fix that.
No sir.
Do you have PM4K autostart enabled?
Yes i do.
Does that fix it for you? script.plexmod.zip (2.8 MB)
Yessir, boots right in to pm4k now. No error.
Thank you much!
