PM4K / PlexMod for Kodi (18, 19, 20, 21, 22+)
I have files which has only DV format, without HDR10 meta.
In doing so it will not play those files.
I mean, it is common in the market that Samsung Brand TV = HDR10+ / HDR10 & Sony Brand TV = DV / HDR10
Major OTT Player like Netflix, Amazon, Disney, Hulu, Apple have the same problem to support both the contents.
Hmm. Kodi should let you disable hybrid DV not just DV in general. I’d wager this setting will eventually make it into the player video settings of omega final.
Not sure if I’d want to implement this right now because of that.
Sidenote: my LG OLED from 2018 handles all DV formats perfectly, but doesn’t support HDR10+ sadly.
0.7.5-beta15: script.plexmod.zip (3.5 MB)
Changelog (Diff to beta10):
  • Movies/Preplay: Show writers besides directors as well
  • Episodes: Add directors/writers to episode view
  • Episodes: Wait for full episode data to be loaded before enabling playback
  • Movies/TV/Episodes: Support ratings from non-legacy agents (also when primary provider is IMDB)
  • Movies/Preplay: Move userRating/stars in line with other ratings
  • Movies: Scroll long titles as well
  • Episodes: Adjust ratings/userratings positioning and label widths; add autoscroll to show and episode titles
  • Episodes/Seasons/Shows: Calculate and show season watched percentage including in-progress episodes
  • Shows: More accurately show progress bar including in progress episodes
  • Home: Sections: Increase section select timeout from 300 to 500ms
  • InfoScreen: Add DV stream metadata info
  • SeekDialog: Hide once-manually-skipped markers and move them to the OSD as well
  • SeekDialog: Fix 0.7.5-beta8+ marker issues
Hello Everyone,
Odroid N2, CoreELEC 20.
Can someone tell me now to get rid of this:
Only started happening recently and a Exit and Starting of PM4K will usually fix it.
TIA
Not without Logs, no.
Thanks for the reply.
Have enabled debug and will get it soon.
I want to know regarding connection for plex server with PM4K, i am facing a issue from past few days.
The IP Address of Plex for plex.tv are blacklisted in Abuseipdb
34.251.5.225
52.214.72.228
So my existing setup of PM4K which is already configured connects to my plex server after some tries, but when I configure fresh setup i.e. New Kodi installation and PM4K, it does not connect to plex server.
Is there a way, in which a fresh installation of PM4K connects to my offline plex server, which is fire-walled and only accessible to LAN?
0.7.5-prerelease1: script.plexmod.zip (3.5 MB)
Please check for general stability (especially playback, seekdialog)
Pinging The Squadā„¢: @sonofdibnah @ecsjjgg @jamal2367 @THGhost @bowlingbeeg @Buttzy10169 @SmarthyMcFly @pl37919
Successfully tested and found to be good.
Thank you, the addon is really fast.
I can say for myself that it is worth a release.
Edit:
IMDb rating is now showing.
And the DV stream metadata info works fine too.
Looks good. Tested seeking with the deactivated ā€œauto confirmā€ when seeking - that option I always use. (in the kodi addon settings of PM4K),
Standard / default where it is activated works also flawlessly.
Checked seeking via Buttons (ui and on remote), selection on Timeline (set marker and confirm) and Chapter selection.
Ratings are also working on movies, concerts and series / episodes (using non legacy scrapper on server side and IMDB / TMDB as rating source)
Sorry to be negative but I’ve noticed audio sync issues which are cured by stopping and restarting the film. Too soon to be definitive cause I’m watching something with my wife.
No worries. Can’t be PM4K, though, we don’t do anything playback related. That’s all kodi.
That’s good to know especially as I’m having a hard time recreating the issue. I had seen it twice tho ( on the beta before this pre release and on the prerelease) so I thought I should report it.
All good on my end :+1: How do I get IMDB ratings for TV shows though? I’m currently getting TMDB and I don’t see an option for it in my Plex server’s settings.
I have installed 0.7.5 release first time after a long time, as 0.7.4 was very stable.
I noticed one issue while navigation to TV Section>Season only where there are multiple version files of episodes.
I am unable to move any keys in the page to select/focus , its like i have to use only mouse.
Even escape key is not working, so i have to use mouse, the UI is not freezed just keys are not working, only on the screen of episodes where there are multiple version files.
Also while exiting the addon, its stuck on this screen mostly 3 out of 5 times
Here is the Log while addon not exiting, and I have to forcefully kill kodi
2024-02-02 12:31:03.848 T:12180    info <general>: script.plex: API: GET https://xxx-xxx-xx-xx.redacted.plex.direct:32400/library/metadata/967229?X-Plex-Token=****
2024-02-02 12:31:16.687 T:11272    info <general>: Loading skin file: C:\Users\Administrator\AppData\Roaming\Kodi\addons\script.plexmod\resources\skins\Main\1080i\script-plex-options_dialog.xml, load type: LOAD_ON_GUI_INIT
2024-02-02 12:31:18.722 T:12180    info <general>: script.plex: Cron: Receiver canceled: <lib.windows.home.HomeWindow object at 0x000002C02EE36B30>
2024-02-02 12:31:18.723 T:12180    info <general>: script.plex: Storing BG for <Hub:home.television.recent>, "Percy Jackson and the Olympians"
2024-02-02 12:31:18.764 T:12180    info <general>: script.plex: Main: SHUTTING DOWN...
2024-02-02 12:31:18.764 T:12180    info <general>: script.plex: API: DEBUG: Closing server...
2024-02-02 12:31:18.764 T:12180    info <general>: script.plex: BGThreader: thread (queue.0:worker.0): Waiting...
2024-02-02 12:31:18.824 T:12280    info <general>: script.plex: Player: Closed
2024-02-02 12:31:18.824 T:12764    info <general>: script.plex: Cron stopped
2024-02-02 12:33:14.635 T:7372     info <general>: CActiveAESink::OpenSink - initialize sink
2024-02-02 12:35:11.884 T:7372     info <general>: CActiveAESink::OpenSink - initialize sink
2024-02-02 12:35:13.528 T:11272    info <general>: Stopping the application...
2024-02-02 12:35:13.528 T:11272    info <general>: Stopping player
2024-02-02 12:35:13.528 T:11272    info <general>: Storing total System Uptime
2024-02-02 12:35:13.529 T:11272    info <general>: Saving settings
2024-02-02 12:35:13.541 T:11272    info <general>: Saving skin settings
2024-02-02 12:35:13.543 T:11272    info <general>: Stopping all
Also I am frequently getting this error:
2024-02-02 12:43:15.246 T:8988     info <general>: script.plex: Episodes: Moving too fast through paginator, throttling.
2024-02-02 12:43:15.253 T:12548   error <general>: Control 301 in window 13003 has been asked to focus, but it can't
Did/do you experience the same in 0.7.5-beta15?
No, I checked it right now with 0.7.5-beta15, and it is working fine with that version
Thank you, please try 0.7.5-prerelease3: script.plexmod.zip (3.5 MB)
Edit: Updated to prerelease3; pressing BACK while a section is highlighted now goes to Home instead of offering to exit the addon. Enabled UI ā€œfastbackā€ AddonSetting by default.
Nope this is the same, this is not working with multiple file version on episode screen. i still have no button control though keys, only mouse works.
Interesting. This happens immediately once you visit an item with multiple versions? Or after coming back from playback.
