Server Version#: v1.15.2.793-782228f99
After updating my Mac to Mojave i noticed that PMS crashed after startup. The logs showed me this:
Mar 19, 2019 22:41:41.988 [0x700004564000] INFO - Plex Media Server v1.15.2.793-782228f99 - Apple Mac x86_64 - build: darwin-x86_64 macos - GMT 01:00
Mar 19, 2019 22:41:41.990 [0x700004564000] INFO - MacOSX version: 10.14, language: en-BE
Mar 19, 2019 22:41:41.990 [0x700004564000] INFO - Processor Intel® Core™ i5-3210M CPU @ 2.50GHz
Mar 19, 2019 22:41:41.990 [0x700004564000] INFO - /Applications/Plex Media Server.app/Contents/MacOS/Plex Media Server
Mar 19, 2019 22:41:42.347 [0x700004876000] DEBUG - BPQ: [Idle] -> [Starting]
Mar 19, 2019 22:41:42.356 [0x700004876000] DEBUG - FeatureManager: Using cached data for features list
Mar 19, 2019 22:41:42.370 [0x700004876000] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.26.0, threadsafe=1
Mar 19, 2019 22:41:42.488 [0x700004876000] DEBUG - Running migrations. (EPG 0)
Mar 19, 2019 22:41:42.494 [0x700004876000] DEBUG - Running forward migration 20180501000000.
Mar 19, 2019 22:41:42.495 [0x700004876000] DEBUG - Captured session 0.
Mar 19, 2019 22:41:42.495 [0x700004876000] DEBUG - Captured session 1.
Mar 19, 2019 22:41:42.495 [0x700004876000] DEBUG - Captured session 2.
Mar 19, 2019 22:41:42.495 [0x700004876000] DEBUG - Captured session 3.
Mar 19, 2019 22:41:42.495 [0x700004876000] DEBUG - Captured session 4.
Mar 19, 2019 22:41:42.495 [0x700004876000] DEBUG - Captured session 5.
Mar 19, 2019 22:41:42.495 [0x700004876000] DEBUG - Captured session 6.
Mar 19, 2019 22:41:42.496 [0x700004876000] DEBUG - Captured session 7.
Mar 19, 2019 22:41:42.496 [0x700004876000] DEBUG - Captured session 8.
Mar 19, 2019 22:41:42.496 [0x700004876000] DEBUG - Captured session 9.
Mar 19, 2019 22:41:42.496 [0x700004876000] DEBUG - Captured session 10.
Mar 19, 2019 22:41:42.496 [0x700004876000] DEBUG - Captured session 11.
Mar 19, 2019 22:41:42.496 [0x700004876000] DEBUG - Captured session 12.
Mar 19, 2019 22:41:42.496 [0x700004876000] DEBUG - Captured session 13.
Mar 19, 2019 22:41:42.496 [0x700004876000] DEBUG - Captured session 14.
Mar 19, 2019 22:41:42.496 [0x700004876000] DEBUG - Captured session 15.
Mar 19, 2019 22:41:42.496 [0x700004876000] DEBUG - Captured session 16.
Mar 19, 2019 22:41:42.496 [0x700004876000] DEBUG - Captured session 17.
Mar 19, 2019 22:41:42.496 [0x700004876000] DEBUG - Captured session 18.
Mar 19, 2019 22:41:42.496 [0x700004876000] DEBUG - Captured session 19.
Mar 19, 2019 22:41:43.970 [0x7000049ff000] DEBUG - Job running: ‘/Applications/Plex Media Server.app/Contents/MacOS/CrashUploader’ ‘–directory=/Users/tmussche/Library/Application Support/Plex Media Server/Crash Reports/1.15.2.793-782228f99’ ‘–version=1.15.2.793-782228f99’ ‘–platform=MacOSX’ ‘–platformVersion=10.14’ ‘–serverUuid=4027ad86f6b9295ad8de4a870a28dc0058f0a899’ ‘–userId=tmussche@gmail.com’ ‘–sentryUrl=https://sentry.io/api/1233455/minidump’ ‘–sentryKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx’ ‘–vendor=Apple’ ‘–model=x86_64’ ‘–device=Mac’
Mar 19, 2019 22:41:43.971 [0x7000049ff000] DEBUG - Jobs: Starting child process with pid 1801
Mar 19, 2019 22:41:44.021 [0x70000497c000] DEBUG - Jobs: ‘/Applications/Plex Media Server.app/Contents/MacOS/CrashUploader’ exit code for process 1801 is 0 (success)
Mar 19, 2019 22:41:44.072 [0x700004876000] ERROR - SQLITE3:0x10d9b6118, 11, database corruption at line 64757 of [bf8c1b2b7a]
Mar 19, 2019 22:41:44.073 [0x700004876000] ERROR - SQLITE3:0x10d9b6118, 11, database corruption at line 64798 of [bf8c1b2b7a]
Mar 19, 2019 22:41:44.073 [0x700004876000] ERROR - SQLITE3:0x10d9b6118, 11, statement aborts at 19: [CREATE INDEX ‘index_title_sort_naturalsort’ ON ‘metadata_items’ (‘title_sort’ COLLATE naturalsort)] database disk image is malformed
Mar 19, 2019 22:41:44.075 [0x700004876000] ERROR - Exception inside transaction (inside=1) (…/Library/DatabaseMigrations.cpp:204): sqlite3_statement_backend::loadOne: database disk image is malformed
Mar 19, 2019 22:41:44.078 [0x700004876000] ERROR - Exception thrown during migrations, aborting: sqlite3_statement_backend::loadOne: database disk image is malformed
Mar 19, 2019 22:41:44.297 [0x700004876000] ERROR - SQLITE3:0x10d9b6118, 11, database corruption at line 64757 of [bf8c1b2b7a]
Mar 19, 2019 22:41:44.297 [0x700004876000] ERROR - SQLITE3:0x10d9b6118, 11, database corruption at line 64798 of [bf8c1b2b7a]
Mar 19, 2019 22:41:44.297 [0x700004876000] ERROR - SQLITE3:0x10d9b6118, 11, statement aborts at 10: [select max(max(metadata_items.changed_at),max(metadata_items.resources_changed_at)) from metadata_items] database disk image is malformed
Mar 19, 2019 22:41:44.299 [0x700004876000] ERROR - Database corruption: sqlite3_statement_backend::loadOne: database disk image is malformed
Mar 19, 2019 22:41:44.299 [0x700004876000] ERROR - Error: Unable to set up server: sqlite3_statement_backend::loadOne: database disk image is malformed (N4soci10soci_errorE)
After some googling i found the instructions to repair a corrupt database. The
sqlite3 com.plexapp.plugins.library.db “DROP index ‘index_title_sort_naturalsort’”
line gave the error:
Error: no such index: index_title_sort_naturalsort
If I continue with the repair i get a com.plexapp.plugins.library.db file of size 0. Obviously plex also crashes with that db file.
I also noticed the latest backup of the .db file is almost a year old, while i had setup to regularly take a backup of the db. I see that i have a recent backup (?) of the com.plexapp.plugins.library.blobs.db file,
Anything i can try before i rebuild my entire Library (or restore a year-old one)?
Thanks!
Tim
