Server Version#: 1.29.1.6276
Player Version#:N/A
Odd, but PMS was running fine last night - left a recording going. Got up today, to see it had crashed. Now, when I try to restart it … it just fires up and exits right away. Nothing in the logs (directory is empty), and of course can’t get to the web interface either (as it’s exiting right away).
I tried a full uninstall and reinstall, no joy.
Any thoughts? Is this a known issue?
Thanks!
OK, found a log file! Seems they have moved … perhaps due to the 64-bit install. Seems I have the same issue as reported a few other places / times?
Oct 14, 2022 12:15:23.412 [8804] ERROR - SQLITE3:0x7ff73176c4e0, 11, database corruption at line 67183 of [1b256d97b5]
Oct 14, 2022 12:15:23.412 [8804] ERROR - SQLITE3:0x7ff73176c4e0, 11, statement aborts at 21: [select min(begins_at, ends_at) as minimum_at from media_items where minimum_at > ? order by minimum_at limit 1] database disk image is malformed
Is there a fix for this?
Thanks!
That works - thanks! Could not fix it … but backup worked
Appreciate it!
